Bushings
Discussion in 'Suspension' started by goufcustom, Mar 23, 2012.
  1. Mar 23, 2012 at 5:56 PM
    goufcustom
    goufcustom [OP] 7.62x63mm
    MD
    2021 4x4 TRD Sport DCLB
    I want to go through and replace all the bushings in my front and rear suspension, I think that is causing my squeaks. What are the best aftermarket bushings and where?
    Also is there a how to guide on replacing them?
    I am going in to replace some leafs and my front strut, so it will all be apart anyway.
  2. Mar 24, 2012 at 3:55 PM
    surfrat
    surfrat Well-Known Member
    LI, NY
    icon coilover, total chaos UCA, allpr expo, icon 2.0 rear,wet okole
    stick with oem rubber bushings.. poly bushings are nice and all.. but to high mantience
  3. Mar 24, 2012 at 7:41 PM
    goufcustom
    MD
    Why are poly bushing high maintenance? Also where is the best place to get stock bushings? I hate going to the stealership. I am guessing one of the many parts places online will have them, any breakout manuals that list the part numbers?
    Thanks
    Rear Leaf Spring Bushings:
    http://www.trdparts4u.com/scripts/prodView.asp?idproduct=-8340
  4. Mar 27, 2012 at 9:09 AM
    goufcustom
    MD
    Anyone have the part numbers on the Lower Control Arm Bushings?
    When I went in to replace the strut the lower control arm on my passenger side had to be forced, with a crow bar, down and out of the way so I could replace the strut. So I started thinking, and I bet that the bushings are on their way to the crapper. From what I have read, replacing them sucks, and the bushings from Toyota are about $70 each, and the labor is about $300 to replace them on top of parts.
    Recommendations? I am thinking about buying the bushings for one side, and attempting it. I figure I can take the LCA and bushings someplace and have them do that part if I cant. But it seems like it is worth a try.
    I have my UCAs already, I bought a like new set of UCAs here with ~6k miles on them, figure they will replace my 105K mile ones nicely, rather than bother messing with bushings. Problem with LCAs is they are more expensive, harder to find, and heavy to ship.
  5. Mar 27, 2012 at 9:11 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Part numbers in this DIY thread:
    http://www.tacomaworld.com/forum/suspension/176250-diy-lca-bushing-replacement-2005-tacoma-4x4.html
  6. Mar 27, 2012 at 6:41 PM
    goufcustom
    MD
  7. Mar 28, 2012 at 5:29 AM
    Pugga
    Massachusetts
    No worries, I knew who made the thread so it was pretty easy to find that way :thumbsup:
  8. Mar 28, 2012 at 7:51 AM
    Fabulous
    Fabulous Well-Known Member
    Fabian
    Calgary, AB
    2017 Tacoma double-cab TRD Sport
    TRD Pro grill and fog lights, Toytec Boss lift, 265/70-17 Duratracs on 17 x 8.5 FN Verge wheels, LEER canopy, 30% tinted front windows.
    Make sure you put a lot of anti-sieze on the LCA bushing bolts. When I installed my lift I found out 3 of the 4 LCA bushings on my truck were siezed, and it cost me $1300 Canadian to have them replaced. Sucked! I guess this is common on the Tacoma as they don't lube them on assembly. Poopy design if you ask me.
