Bushwacker flares on a reg cab
Discussion in '5 Lug' started by PyroTaco, Apr 3, 2018.
  1. Apr 3, 2018 at 10:12 AM
    PyroTaco
    PyroTaco [OP] Well-Known Member
    2013 Reg Cab Tacoma
    Fat Bob's lift kit, 30's on stock steelies, lunchbox locker in the rear, and a ton of other general mods and additions to help the utility of the truck for my particular uses.
    Howdy!
    Been using the search function a ton and google, yet not finding what I'm looking for. Maybe someone here may be able to lend the assist. I'm trying to find a pic of a 2nd gen reg cab with bushwacker fender flares. Easy enough right? Here's the catch... trying to find a pics with them installed but on factory wheels and no spacers. Any one have any leads on such a pic? Trying to see what it would look like prior to purchase.
    -PyroTaco
  2. Apr 3, 2018 at 5:56 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    You might be out of luck, probably anyone here who has installed those have already gone to bigger rims and tires.
  3. Apr 4, 2018 at 4:01 PM
    HackD
    HackD Marching to the Beat of a Different Drum
    William
    Hamilton, Ontario, Canada, eh?
    2010 Base 4x2, 2.7L, 5 speed manual 5-lug Slug
    Gone over the Top for a 5-lug..
    Frankly, it's going to look awful. The nature of having inset wheels on the hub, and large wheel-wells.
    At one point, i was going to put a set of (not Bushwacker's) fender flares on mine. I tacked them onto the side of my truck, stood 20 feet back, and said.. "blech". I resold them off at a serious loss. To use mine, i would have had to go to a -20mm offset rim, which is seriously screwing with the wheel bearings, IMHO.
    These were 225/75R16's.. 29.3" diameter, vs OEM 26.9" diameter.
  4. Apr 4, 2018 at 4:05 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    You need bigger tires to make that work, flared fenders with stock tires will look funny.
  5. Apr 4, 2018 at 4:08 PM
    HackD
    William
    That wasn't stock tire sizing :D .. i think even my present 31.7" 235/85R16's would look overwhelmed, with fender flares of that size.
  6. Apr 4, 2018 at 4:12 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I like the extend a bush wackers, idk if they make that style for 2nd gens but 1st gens look good
  7. Apr 4, 2018 at 4:19 PM
    PyroTaco
    2013 Reg Cab Tacoma
    I decided against it. Ended up getting the ol girl some new shoes today. 30x9.5x15 on stock steelies. Looks sharp and no rubbing and doesn’t stick out at all thus no flares.
  8. Apr 4, 2018 at 4:23 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Yeah extend fender flares are only good when your wheel track gets extended, if your wheels aren’t sticking out hella far past the fenders no need for extended fender flares
  9. Apr 4, 2018 at 4:23 PM
    PyroTaco
    2013 Reg Cab Tacoma
  10. Apr 4, 2018 at 4:24 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    When you look like this is when you need extended fender flares lol
  11. Jan 12, 2020 at 1:13 PM
    Taco5rwd
    Taco5rwd Active Member
    Spencer
    Tacoma
    is your truck lifted with those 30's?
  12. Jan 12, 2020 at 1:29 PM
    PyroTaco
    2013 Reg Cab Tacoma
    Sure is. Used a fat Bob kit.
  13. Jan 12, 2020 at 1:36 PM
    Taco5rwd
    Spencer
    Tacoma
    Nice, looks clean m8
  14. Jan 12, 2020 at 1:49 PM
    PyroTaco
    2013 Reg Cab Tacoma
    Thanks man. Appreciate the prop
    -PyroTaco
