SOLD! Bussman RTMR $175
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by diverdale, Jan 31, 2018.
  1. Jan 31, 2018 at 3:00 PM
    diverdale
    diverdale [OP] #sosconceptscrew
    Dale
    Raleigh, NC
    2015 TRD OR DCSB
    Fox 2.5 Coilovers, Fox 2.0 Rear Resi, Icon 3 Leaf AAL
    Finally got around to making another RTMR with my leftover parts from building mine. This has everything to get it up into the overhead console. I left the ends a little long so you can attach to your switches however you want. Comes with 5 relays and 5 20a fuses as well as an add-a-fuse. All the main wires are 18g GXL wire and the jumpers and accessory pig-tails are 10g GXL.
    nastyneight, TacomaCody and seoulja99 like this.
  2. Feb 5, 2018 at 6:43 AM
    nastyneight
    nastyneight Well-Known Member
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    So you are selling them
  3. Feb 5, 2018 at 6:45 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
  4. Feb 5, 2018 at 6:47 AM
    nastyneight
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    @diverdale with your setup what else is needed, i will have to run power from my trunk (for the Miata) will i need anything else? going top be for mostly lights and extra power plug.
  5. Feb 5, 2018 at 6:49 AM
    nastyneight
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    wonder if could run just another complete battery cable to the front, to hook that too, and use it for the winch?
  6. Feb 5, 2018 at 7:01 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    There's nothing wrong with running power to the front, just make sure you use large enough battery cables.
    nastyneight[QUOTED] likes this.
  7. Feb 5, 2018 at 7:12 AM
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    The bussman cannot support a winch's AMP requirements. These boxes are only rated at 80amp maximum and most winches need somewhere around 250amp.
  8. Feb 5, 2018 at 7:14 AM
    nastyneight
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    Guess more question if run a OEM grade positives cable to the front, then to power block, could hook wince and this bussman to it?
  9. Feb 5, 2018 at 7:16 AM
    nastyneight
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    No sorry mean run positve battery cable to front for the winch and feed this off that line
    Sub_Par[QUOTED] likes this.
  10. Feb 5, 2018 at 7:17 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    I'd size the cables to just over what the winch needs, but yea should be fine.
    Sub_Par and nastyneight[QUOTED] like this.
  11. Feb 5, 2018 at 7:19 AM
    nastyneight
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    I have a WARN 4000 coming this week for it
    Sub_Par likes this.
  12. Feb 5, 2018 at 7:25 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    nastyneight[QUOTED] and Sub_Par like this.
  13. Feb 5, 2018 at 9:00 AM
    diverdale
    Dale
    Raleigh, NC
    2015 TRD OR DCSB
    Just get the proper size cable from the battery. You'll need a breaker or fuse however you decide to do it. I use an ANL style fuse. A lot of folks use the bluesea breaker (or similar)
    https://www.amazon.com/Absolute-ANL...=UTF8&qid=1517850021&sr=1-7&keywords=anl+fuse
    https://www.amazon.com/Blue-Sea-Sys...49836&sr=1-1-catcorr&keywords=bluesea+breaker
    Edit: And a ground bar of some sort. I used one like this.
    https://www.amazon.com/Sea-Dog-4267...TF8&qid=1517850164&sr=1-2&keywords=ground+bar
  14. Feb 5, 2018 at 10:27 AM
    nastyneight
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    on my truck i run about the same circuit breaker, is there really any neg or pos to runnning either
  15. Feb 5, 2018 at 10:29 AM
    diverdale
    Dale
    Raleigh, NC
    2015 TRD OR DCSB
    You can reset the breaker. I had the ANL fuse in my tool box so I used it. If/when it goes, I'll probably switch to a breaker
  16. Feb 5, 2018 at 10:32 AM
    nastyneight
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    well put me down for one, ill get assess what winch will draw and figure from there, next get the alternator upgraded
