Bussmann RTMR Relay/Fuse Block $215
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by Roo1041, May 19, 2016.
  1. Mar 27, 2017 at 11:36 AM
    vonellis
    vonellis Well-Known Member
    04 DLBC x4 S/C 97 2X 04 DBLC 4X S/C
    Some and some more
    Nice can't wait!
  2. Mar 30, 2017 at 9:45 PM
    Roo1041
    Roo1041 [OP] Well-Known Member
    Riley
    Tuscaloosa, AL
    2003 Toyota Tacoma Prerunner
    aFe CAI 3" OME Nitrocharger shocks w/ 883 Coils Rear OME Dakar Leaf Pack 17x8 ATX AX324 Assault Wheels 265/70R17 BFGoodrich Rugged Terrain T/A Tinted Windows to match stock rears
    Boxes are finished! PM me your address so I can ship it out tomorrow.
    Cfincke and drr like this.
  3. Apr 3, 2017 at 12:04 PM
    vonellis
    Some and some more
    Got mine today! Very very nice work!
    Roo1041[OP] likes this.
  4. Apr 3, 2017 at 2:38 PM
    3slowto4woah
    3slowto4woah Well-Known Member
    Lake Tahoe
    2015 Super White Tacoma DCSB TRD Sport
    Icon Stage 4 + Dakars
    Received mine as well. A real pro here. Saved me a lot of dough and time.
  5. Apr 3, 2017 at 5:07 PM
    Cfincke
    Cfincke Well-Known Member
    San Antonio TX
    2014 Tundra 1794 sunset bronze
    Icon front & rear shocks, icon UCA, Method Standards, Nitto Ridge Grapplers, Retrax cover, TRD sway bar
    Mine showed up also, very nicely set up
  6. Apr 3, 2017 at 5:19 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Last but not least, mine showed up as well. Looks great - can't wait to get it installed.
    Hey, @Roo1041, can you post up some quick instructions on wiring up the connectors, and where all the loose ends go? I'm guessing the free ends on the switch trigger harness are for power, ground, and dash illumination - where are the best spots to tie those in?
    Cfincke likes this.
  7. Apr 3, 2017 at 6:31 PM
    Roo1041
    Riley
    Tuscaloosa, AL
    Yes, the free ends on the switch trigger harness are for your switches to light up. The single red wire can be tapped into your in-cab fuse panel. I tapped mine into the "IGN 7.5A" (ignition) spot.
    As for the other two free wires (the pink and brown wire), you want to tap them into something that is dimmable. I tapped mine into the ash tray light, mainly because I had to pull the ash tray out for my switch holder plate and then the light was really bright so I just cut the lights wiring and tapped my wires from the switch trigger harness in there. The brown wire is the ground wire, and the pink wire is the positive wire.
    This write-up is what my builds are based off of, https://www.tacomaworld.com/threads...n-rtmr-fuse-relay-block.399454/#post-11086094 "Part 6- Installation" will explain a lot more detail about the wiring. And pretty much the only difference is he uses red/black wire where I use pink, and he uses blue where I used tan.
    As for wiring you accessories to the box, I included some male terminals that you will have to crimp to your accessories positive and negative wires. The plastic connector you need is already on the box with the plugs in the ends so water will not get up in your leads. These pictures should give you an idea of how you need to wire them, but let me know if you need more help.
    The ten loose ends coming off of the accessory leads on the box are for your grounds. I included some ring terminals for you to ground them to blue sea busbars. This picture might help with that.
    Also, there are two terminals on the box. The right one (where wires are already hooked up) is the negative internal busbar. The left one is the positive internal busbar. You can hook your battery power wire for the positive lead directly from your breaker to the left terminal. It will be easier to hook the battery ground wire to the blue sea busbars.
    drr[QUOTED] and Cfincke like this.
  8. Apr 3, 2017 at 8:13 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Awesome, thanks man. I'll let you know if I have any more questions.
  9. Apr 5, 2017 at 8:27 AM
    Pirhett
    Pirhett Instagram @pirhett_ship
    Rhett
    San Diego
    2014 TRD Sport 4x4 DCLB MGM
    Stock...
  10. Apr 8, 2017 at 9:54 AM
    Roo1041
    Riley
    Tuscaloosa, AL
    Bump, still have one left.
  11. Apr 13, 2017 at 3:36 PM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    Does it come with everything that you listed in the first post? I don't really need or want the switch back wiring.
  12. Apr 13, 2017 at 5:09 PM
    Misplaced Nebraskan
    Misplaced Nebraskan TTC #007 'First Gen Best Gen'
    Zach
    Austin
    2001 Taco & 16 T4R TPE
    Definitely saving for my list. Very nice!
  13. Aug 22, 2017 at 5:30 PM
    Roo1041
    Riley
    Tuscaloosa, AL
    Bump!! I know it's been awhile. But I've got 3, only need 1 more.
  14. Aug 27, 2017 at 5:06 PM
    Roo1041
    Riley
    Tuscaloosa, AL
