Busted a nut!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KodiakToyTRD, Aug 17, 2010.
  1. Aug 17, 2010 at 11:52 AM
    KodiakToyTRD
    KodiakToyTRD [OP] Well-Known Member
    CO
    2013 Scion FR-S Whiteout
    So in the process of removing and replacing my throw out bearing I had to remove the Y pipe to remove the transmission. It all went fine till I went to put it all back together...I broke 3 of the 4 bolts that attach the Y pipe to the exhaust manifolds, and and the 1 bolt that attaches the drivers transmission support to the exhaust manifold.
    Any ideas on how to fix this? I'm thinking right now of just drilling out the 4 studs and putting grade 5-7 bolts with crimped lock nuts thru the holes and replacing them that way. Are grade 5-7 bolt alright to use or should I use stainless?
  2. Aug 17, 2010 at 12:00 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    I would usae stainless.
  3. Aug 17, 2010 at 1:11 PM
    06redtacoma
    06redtacoma Well-Known Member
    Alabama
    06 Trd Offroad
    Lifted, Slider, stock rack, rear mounted winch in stock bumper, brush guard, Sound system, ipod to car, tint, wheel spacers, 285 bfg AT,
    I would use galvanized however idk how well it would take the heat. the reason those bolts broke was because of the heat. constant heating and cooling must have weakened them over time.
    btw love the busted a nut title.
  4. Aug 17, 2010 at 1:19 PM
    lilgerber
    lilgerber Well-Known Member
    Aaron
    Fresno, CA
    06 4x4 off road Speedway blue
    Front: Total Chaos 3.5 4x4 LT kit, Engage off-road one piece hood, Caged front end, TC gussets. Rear: Fiberworks fenders, King 14" 3.0 triple bypasses, boxed/braced frame, extended brake lines, 63" chevy leaf springs, U bolt flip kit, TC lower shock mounts. Preformance: URD intake, Doug Thorley headers, Flowmaster 40, 2.5 tubing. Interior: Weather techs, LED's, Double DIn, kicker 10" subs, Kicker componet speakers, Exterior: Method wheels with OMF beadlocks, Custom made bumpers, Retro headlights.
    ya i just broke one last night installing my y pipe :(
  5. Aug 17, 2010 at 1:35 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    damn, i read the thread title and came in here expecting all the wrong things
  6. Aug 17, 2010 at 2:31 PM
    flightcancled
    flightcancled Addicted
    Syracuse NY/ Nantucket MA
    Camper top with racks, Custom fogs behind lower bumper. Interior LED lighting, Rock Lights, Hella 500s with upraged bulbs behind black billet grill, AAL, Front 5100s
    Or this guy...
  7. Aug 17, 2010 at 5:16 PM
    KodiakToyTRD
    CO
    Well I figured I'd get creative with it! Fit my situation perfectly.
    Gerber, what Y pipe did you get?
  8. Aug 18, 2010 at 12:08 AM
    KodiakToyTRD
    CO
    And after I have replaced these bolts (I dont wanna drive around town with a leak for a long time) I'm goin to get DT long tube headers, Pipe Bomb Y pipe and MBRP XP dual exhaust. I have a sweet wish list of mods I just made in addition to the things i just mentioned.
    Light weight flywheel
    Stage II clutch
    URD Short throw shifter
    URD TCAI
    Trying to keep a low budget mod list going...:rolleyes:
  9. Aug 18, 2010 at 12:23 AM
    trib
    trib Well-Known Member
    Ugh exhaust work is the worst....rusty nuts suck :p
    Sounds like a good excuse for a new pair of headers...
  10. Aug 18, 2010 at 5:21 AM
    Peru
    Peru Well-Known Member
    Jonathan
    Redmond WA
    SR5 -- V6 -- 2005 -- 4X4
    none
    Use a good high temp antisieze and you'll never have a problem once you get them off the first time.
  11. Aug 18, 2010 at 5:53 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Galvanized is not good for those temperatures. Stainless in the way to go.
  12. Aug 18, 2010 at 6:11 PM
    KodiakToyTRD
    CO
    So I was told if i wanted to make it easy to take the manifold off the engine to remove the broken bolts. If I'm gonna do that I might as well put the headers on...in the mean time while I wait for cash to purchase the DT long tube's, whats the best idea...just drill out one bolt? The drivers side has both bolts broken and the passenger side has just one...my exhaust leak is obviously on the drivers side..lol
  13. Sep 3, 2010 at 5:27 PM
    KodiakToyTRD
    CO
    Got the leaks fixed. Went thru 4 cobalt drill bits. I don't ever wanna do that again, it was a freakin pain in the ass.
  14. Oct 29, 2010 at 3:19 PM
    MARC
    MARC Active Member
    Marc
    Lake Norman NC
    05 Tacoma
    i just got done replacing my to bearing and installing my stage 3 clutch with lw flywheel (i dont like the clutch chatter and should have just stuck with stock and the lw flywheel is nothing special either)......anyways i also broke 3 exhaust bolts. I cussed a lot and then I cut them off, drilled a small pilot hole, drilled them out and replaced with stainless.
  15. Oct 29, 2010 at 4:39 PM
    KodiakToyTRD
    CO
    ^^^ Exactly what I did...a few weeks later.
