Busted up Yota. Needs suspension upgraded. 3” or 6”
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rico808, Mar 18, 2023.
  1. Mar 18, 2023 at 9:52 PM
    Rico808
    Rico808 [OP] New Member
    15 Tacoma Sport
    3” spacer Bald 285s
    *First Post*
    2015 4x4 w/3” spacers & bald 285
    Currently: bad shocks & torn CV boot. Also smashed lower control arm mount due to big ass boulder ‍♂️
    Planning on doing it “proper” but I need help.
    3” suspension? Would a extended axle fix my CVs from tearing so often?
    Or
    6” lift kit? would it give me better angles to lessen the tearing?
    Goals:
    -Lessen the tearing.
    -Get a decent suspension.
    -Use a cheaper sized tire like a 33”… but 35s & 40s are nice too
    -Then maybe bend back that mount too
    Your thoughts?
    Also any shop suggestions? Located on Oahu.
    Mahalo
  2. Mar 18, 2023 at 10:12 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    I would suggest a set of quality coil overs and new leafs/shocks that give you 2” of lift. Skinny 33’s fit great. New aftermarket UCA and new OEM LCA. You’ll get some ground clearance, a smooth ride and the CV should last as long as they would stock.
    Rico808[OP] likes this.
  3. Mar 18, 2023 at 10:14 PM
    Sharpish
    Brian
    Also 35” and up tires mean major work unless you cut up your frame to put in a drop bracket lift and stack a body lift on top of that. Not worth it to me but many choose that route.
  4. Mar 18, 2023 at 11:13 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
