Buttons/Blanks on Dash
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MotorcycleJunky07, Jan 23, 2013.
  1. Jan 23, 2013 at 5:03 PM
    MotorcycleJunky07
    MotorcycleJunky07 [OP] Member
    Zach
    Utah
    2008 TRD Off Road SR5
    The '08 Tacoma TRD Off Road SR5 that I'm looking at buying has three blanks next to the mirror controls. I've seen Tacoma's with buttons in place. Traction Control, Downhill Assist (DAC), and Roll Stability Control (RSCA)... What determines if a tacoma has these buttons in place?
  2. Jan 23, 2013 at 6:01 PM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Someone can correct me if I'm wrong, but I think those options are on the TRD Off Roads, 2009 and up.
  3. Jan 23, 2013 at 6:22 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    I have a 2010 regular cab..mine has the Traction Control and the RSCA.
  4. Jan 23, 2013 at 6:23 PM
    MotorcycleJunky07
    Zach
    Utah
    Awesome! Thank you so much!
  5. Jan 23, 2013 at 6:23 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    DAC is a TRD Offroad option
    My '09 TRD Sport has the VSC and RSCA buttons
  6. Jan 23, 2013 at 6:26 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Here's what my 07 looks like... listed under optional equipment on the Offroad models back then.
    Hwntunda likes this.
  7. Jan 23, 2013 at 6:27 PM
    OZ-T
    Peter North
    British Columbia
    also RSCA is not Roll Stability Control , it's Roll Sensing Curtain Airbags
  8. Jan 23, 2013 at 6:39 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    I know I should know the systems in my truck, but does that button disable the bags when switched in 4WD?
    In other words, what is it used for... and why? :eek:
  9. Jan 23, 2013 at 6:41 PM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Disables the side curtain air bags, for off road situations. You wouldn't want to be on a crazy lean off roading, and bam, side curtain air bags go off, cause it thinks your in a roll over.
  10. Jan 23, 2013 at 6:41 PM
    OZ-T
    Peter North
    British Columbia
    It disables the curtain airbags that come on if they sense a roll over situation , the disable button is there so you can turn them off if you are doing offroading that involves high leans of the truck
  11. Jan 23, 2013 at 6:43 PM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Too slow :p
  12. Jan 23, 2013 at 6:45 PM
    OZ-T
    Peter North
    British Columbia
    I'm watching hockey
  13. Jan 23, 2013 at 6:50 PM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    I was watching too. :pout:
  14. Jan 23, 2013 at 6:51 PM
    That Dude Tim
    That Dude Tim Toyota Technician
    Elyria, OH
    11 TRD Sport 4x4 DCLB
    Falken Wildpeak AT3/W, BLK Mk6, ICON's, Firestone Ride Rites, SHLM, Rear view camera switch, 7-pin in bumper, Lighted 4x4 switch, ImMrYo bracket, mudflap delete
    OP if the truck isn't 4x4 then you might not have those switches. Truck trim packages and options vary. Also auto and stick have a different button too.
  15. Jan 23, 2013 at 6:52 PM
    OZ-T
    Peter North
    British Columbia
    I'm watching 2 games
  16. Jan 23, 2013 at 7:00 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    My 09 trd off road 6 speed has clutch start cancel instead of DAC
  17. Jan 23, 2013 at 9:03 PM
    File IFR
    Central MA
    Got it. Thanks guys. :)
    I thought side curtains were for a side impact... I didn't know they inflated during a tip/rollover.
