Buy a hitch or stick with bumper?
Discussion in 'Towing' started by sciencerabbit, Apr 29, 2013.
  1. Apr 29, 2013 at 5:17 PM
    sciencerabbit
    sciencerabbit [OP] Well-Known Member
    North Carolina
    2013 PreRunner
    I have a 2.7l double cab PreRunner.
    according to the manual I'm looking at a max 3500lb weight and 500lb tongue weight on the bumper.
    I am being given a jet-ski and someday would like to buy a small trailer to put a riding lawnmower or a scoop of mulch on.
    So the question is knowing I cant haul much anyway and Im never going to pull anything all that big in the near future Is it worth it to break my bank buying a hitch and t-connector now or just buy a ball for the bumper and t connector and possibly upgrade to a class 3 hitch later?
    or with my truck am I ever going to need a hitch?
  2. Apr 29, 2013 at 5:54 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I prefer receivers vs. the bumper because it's a lot lower and you can choose the ball mount to make the trailer tow level.
  3. Apr 29, 2013 at 6:02 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    ^^^ Agreed.
    OP,
    I've got a used aftermarket receiver hitch I'll let go for $80 + shipping if interested. It was a take-off from a customer truck when installing one of my High clearance bumpers.
    I believe it is 5000lb rated, and bolts together so its a little bit smaller than a factory hitch to ship.
  4. Apr 29, 2013 at 6:11 PM
    sciencerabbit
    North Carolina
    2013 PreRunner
    Tempting but shipping from Nevada to North Carolina cant be cheap and I can get a new one from Advance for 104 with the 30% discount they have going on.
  5. Apr 30, 2013 at 6:21 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    In the short term, if you need to use the tractor buy ramp transitions and shove it right on there. Mine is a 2.7 single cab.
  6. Apr 30, 2013 at 6:24 AM
    rickmeseke
    rickmeseke subaru of america
    Ricky
    Brunswick, GA
    a white truck
    i just bought a wiring kit and i tow with my bumper, pull a 4x8 trailer with either mine and my moms motorcycle(ninja and harley), or my riding lawn mower. also pull my jet ski, never had an issue.
    if the bumper is rated to pull 3500 lbs, and im pulling under 3500 lbs, might as well use it
  7. Apr 30, 2013 at 6:31 AM
    NMW 4x4
    NMW 4x4 Wheels With Moose.
    Walt
    T8 R11 WELS, Maine
    '14 DCLB SR5 4x4
    I've always used the bumper without issues. To be honest, I've exceeded the limit a few times towing my father's 18' Lund (weigh's ~4,000 lbs. with trailer). I've towed it up to 100 miles before without issue.
    In my opinion, a hitch isn't worth the loss in ground clearance when the bumper works just as well. But I spend a lot of time in the woods, ground clearance may not matter as much to you.
  8. Apr 30, 2013 at 7:50 AM
    sciencerabbit
    North Carolina
    2013 PreRunner
    And you think the PreRunner's Extra height is a non issue for occasional towing?
  9. Apr 30, 2013 at 7:57 AM
    Pugga
    Massachusetts
    If you're towing light and only for short distances, you could probably get away with just using the bumper. Keep in mind, most small trailers will be at a pretty significant angle when towed by the bumper (nose high). This can make loading the trailer tricky and also make the trailer track poorly (trailer can start 'wagging' down the road because of the high tongue). I like the receiver because I can put a shacke in there and use it as a recovery point and it allows me to be able to tow heavier if I ever need to.
  10. Apr 30, 2013 at 8:07 AM
    sciencerabbit
    North Carolina
    2013 PreRunner
    Alright, because at the moment all I am going to tow is a jet-ski all of half a mile from my house to the boat ramp, and I don't own a trailer yet, I'm going to try just the bumper. If I don't feel that it is safe for any reason, or my future trailer weighs more than say 1500lbs than I will upgrade!
    By the way Advance auto you can get 30% off right now with a max of $50 with the code TRT30
  11. Apr 30, 2013 at 8:19 AM
    tacomawv
    tacomawv tacomawv
    Richard
    WV
    sr5
    Wade sure-fit mats, afe dry filter
    A hitch will put the ball out from the truck letting you make sharper turns and you will have less of a chance of damaging your bumper with the trailer. Plus it will be better if you have to change ball size if you tow a different trailer.
  12. Apr 30, 2013 at 8:26 AM
    tacomawv
    tacomawv tacomawv
    Richard
    WV
    sr5
    And you can add things like this.
  13. Apr 30, 2013 at 1:30 PM
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
    I've always figured a hitch was better. It gets the trailer (or whatever you are towing) a bit farther away from the bumper, making it less likely for you to damage said bumper, and it also gives the trailer more/easier swing movement.
  14. Apr 30, 2013 at 6:54 PM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    I used the bumper hitch on my T100 for a couple of years. I moved to a mountainous area where the access was over a fairly rough, 20 mile road. A few trips over that road and the mounts for the bumper started to fail. I got a frame-mounted receiver hitch and had no more trouble. I wasn't exceeding the ratings of the truck, but the stress of the rough road was too much for the bumper. When I got my Tacoma the first thing I did was to put a class 3 hitch on it. As I recall it was about $130 new. Well worth it.
  15. May 10, 2013 at 3:03 PM
    taco206
    taco206 Well-Known Member
    Mill Creek, WA
    14 DCSB SR5 PreRunner 2.7L
    You've already spent some coin on the truck, whats a $200 hitch and $60 T-connector? I believe my hitch was $200, Valley brand I believe. I pull all 3 sizes of balls so thats where its nice. My advice, get a hitch.
  16. May 12, 2013 at 7:04 AM
    empty hull
    empty hull Active Member
    Tim
    Baton Rouge, La
    Prerunner V6 SR5 TRD Off Road
    Receiver is better. Tim
