Buy or Rebuild?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HUNTN247, Jan 16, 2023.
  1. Jan 16, 2023 at 8:27 PM
    HUNTN247
    HUNTN247 [OP] Member
    Greg
    2010 Toyota Tacoma Regular Cab
    My 2010 Tacoma 4X4 has 268000 miles on the 2.7. #3 cylinder is losing compression. Do I buy a new block or pull the original and rebuild it? Thanks for any help.
    po35042 likes this.
  2. Jan 16, 2023 at 8:30 PM
    Bishop84
    Bishop84 Well-Known Member
    You need to figure out what caused the low compression. Could be a valve not shutting, could be pistons etc.
    Sprig and po35042 like this.
  3. Jan 16, 2023 at 8:31 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Have you priced a low milage 2.7 at the bone yard? If price is good, this would save time and money. Not sure if the manifolds are different on a 2.7 like they are with the 4.0 with newer engines 13-22
  4. Jan 16, 2023 at 8:32 PM
    HUNTN247
    Greg
    We have a local LKQ. Sky high on the 2.7 they have. Around 5000
  5. Jan 16, 2023 at 8:37 PM
    Geeves77
    Mark
    Northeast
    2011 Tacoma DCSB
  6. Jan 16, 2023 at 8:37 PM
    po35042
    po35042 Well-Known Member
    Patrick
    Tuscaloosa, AL
    2021 SR 4x4 DCSB
    If it ends up needing a rebuild, I'd buy a short block... rebuilt a chevy v6 last year and was amazed how hard it is to find quality engine machine shops these days. Short block would have been waay cheaper.
  7. Jan 16, 2023 at 9:01 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    As already stated you need to first determine the cause of the compression loss. More often than not it’s a damaged valve seal or bad valve. Diagnose the problem and then proceed.
  8. Jan 17, 2023 at 7:36 PM
    HUNTN247
    Greg
    Gonna do a leak test on it this weekend. I will keep yall posted!!
  9. Jan 17, 2023 at 7:39 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    How many miles on the plugs and have you ever replaced the valve cover and spark plug tube gaskets?
  10. Jan 19, 2023 at 8:41 PM
    HUNTN247
    Greg
    Replaced coils and plugs 3 weeks ago. Going to do a leak test this weekend. Hope its just a valve!!
    Steves104x4 likes this.
  11. Jan 19, 2023 at 9:12 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    What’s your point? Neither of them see compression pressure. He’s not complaining about a misfire
