Buyer advice: problem to look for in gen 2s?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FlexingtonKY, Jul 20, 2024.
  1. Jul 20, 2024 at 11:10 AM
    FlexingtonKY
    FlexingtonKY [OP] Well-Known Member
    Sam
    The South
    2003 silver regular cab 4x4 Taco
    33” Dexteros, body lift, bed liner, and head unit
    Hey y’all, I’m looking to sell/trade my gen 1 and get a gen 2 within the year, but I don’t know what major problems to look for when shopping for a gen 2.
    I know with gen 1s, frame and mount rust are at the top of the list, but did that carry over to gen 2? What other widespread quirks/problems should I check for when shopping?
    thanks!
  2. Jul 20, 2024 at 11:19 AM
    BluberryBCtaco
    BluberryBCtaco Making the magic happen
    BC Canada
    2007 Tacoma Sport DCLB
    3in lift, Tow package, Any time 400w inverter, in cab outlet, vinyl floor, roof rack
    Head gasket.
    Rust on the floor pan
    Rusty rear bumper (not replaced if frame was replaced)
    Paint
    Pyts and FlexingtonKY[OP] like this.
  3. Jul 20, 2024 at 11:24 AM
    DoubleB
    DoubleB Well-Known Member
    Bakersfield CA
    22 TRD Pro / 06 PreRunner
    Timing chain cover oil leak. Look behind the power steering pump. Mine has been leaking/ seeping for the last 60k miles. It does not leak enough to drip on the ground and it costs a fortune to repair. I just clean it up every 10k miles or so.
    That has been the only non-wear item problem with my ‘06 in 188k.
    Oh yeah the paint. My truck has lived outside in the Central Ca heat it’s entire life and the paint really shows it.
    FlexingtonKY[OP] likes this.
  4. Jul 20, 2024 at 11:34 AM
    FlexingtonKY
    Sam
    The South
    Thanks, gents!
    newb question, but what’re the best ways to check condition of a head gasket?
    Also if it helps I’ll be looking exclusively at reg cabs, so v6’s won’t be in the mix. Thanks again!
    Black97v6MT likes this.
  5. Jul 20, 2024 at 11:46 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Severe head gasket leak could manifest as bubbles in coolant, misfire (compression loss in a cylinder), among other symptoms.
    Watch for steering rack leak visible at the tie rod bellows - most 2nd gens have it.
    The manifold air injection pump and switching valve aren't reliable, but there's nothing to do unless you see a check engine light. The system can be deleted in states without visual emission inspections, but the delete kit itself is $400+.
  6. Jul 21, 2024 at 4:04 PM
    TJTM
    TJTM Active Member
    2009 2.7 l, 4x4 access cab
    Have a look at the coolant bypass pipe. If it's plastic it needs to be replaced with the metal replacement pipe.
    The pipe runs underneath the intake manifold. Its easily replaceable but will take about 4 hours to do so.
    The pipe becomes brittle and breaks causing a loss of coolant.
    Black97v6MT and FlexingtonKY[OP] like this.
  7. Jul 21, 2024 at 4:23 PM
    FlexingtonKY
    Sam
    The South
    thanks y’all. This is exactly the kind of niche stuff I’m looking for. I’d have had no clue to look for this
    Black97v6MT and Steves104x4 like this.
  8. Jul 21, 2024 at 7:13 PM
    Rougarou680
    Rougarou680 Swamp Lurker
    Lousyana
    2006 Tacoma 4.0 Prerunner, 2013 & 2014 Tacoma 4WD 4.0L
    Leveling kit, hydro dipped rims & skid plate on 2013, 6” pro comp lift & color matched rims on 2006.
    The sun visors will sag in no time if used regularly.
  9. Jul 21, 2024 at 7:36 PM
    FlexingtonKY
    Sam
    The South
    don’t we all?
  10. Jul 21, 2024 at 8:13 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    Focus on looking for 2011-12's and in the Northwest and Southwest. Avoid Northeast and Midwest for rust issues and avoid the South and Southeast for potential flood damage. Check where the vehicle was originally sold. It is not uncommon for vehicles to be shipped across country especially flood damaged vehicles via the wholesale market for dealers. Avoid the Super White paint for flaking paint issues.
  11. Jul 21, 2024 at 8:44 PM
    FlexingtonKY
    Sam
    The South
    Thanks! What is it about 2011-12 models that makes them more desirable?
  12. Jul 21, 2024 at 9:11 PM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    For the 2.7 the coolant pipes and leaking steering racks as stated above. The newer trucks after 09-10 I believe come from the factory with the updated metal coolant pipe parts. Also the early 2nd gens had a few issues they eventually worked out like weak tailgates and issues with the motor mounts. The later 2nd gens also had more sound deadening on the firewall as well as nicer radios and more switch blanks in the dash.
    One positive for the older ones is you could get an sr5 spec regular cab up until about 2009
    Some have an issue with burning oil due to low tension oil control rings getting gummed up. So make sure to change the oil regularly and use a high quality synthetic.
    Valve cover leaks but they are an easy fix.
  13. Jul 21, 2024 at 9:20 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    I think they didn't have the air injection pump until 2011. ??? My 2010 doesn’t have it.
    FlexingtonKY[OP] and Black97v6MT like this.
  14. Jul 21, 2024 at 9:21 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    For V6 trucks
    07-11 and 13-15 only. Skip other years. (05/06 due to head gasket issues, and 12 due to poorly programmed air injection emission stuff, that leads to limp mode). Other than that, 09+ have VSC and side curtian airbags standard, and not much changed other than a few creature comforts over the years. (09+ TRD OR 4x4's got ATRAC, and 09+ in other trims - mainly trd SPORT - saw loss of mechanical LSD in favor for brake actuated LSD in the rear)
    Squirt and FlexingtonKY[OP] like this.
  15. Jul 21, 2024 at 9:32 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    V6 got it starting in 2012. 4-cyl had it earlier. (The 2TR is an older engine so it had more difficulty meeting emissions requirements.)
  16. Jul 21, 2024 at 9:42 PM
    FlexingtonKY
    Sam
    The South
    Thanks again y’all. This is really helpful
  17. Jul 22, 2024 at 6:21 AM
    toyodajeff
    jeff
    06 reg cab sr5
    My 2006 2.7 has the air injection pump. I took off the factory filter that causes issues and installed a small motorcycle air filter on it
  18. Jul 22, 2024 at 6:38 AM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    THere's more high mileage tacomas with a plastic bypass pipe running around then with replacement metal ones and most of the '06 tacomas do not have bad head gaskets. They switched gasket design in 11/2005. The op would do far better reading the 2nd gen common problem thread since that's not just people repeating what they've heard on here. Not saying that coolant pipes haven't needed to be replaced or that no '06s have blown a head gasket but to avoid an entire model year for something that was fixed pretty early in the MY is like nuking the lawn to get rid of some weeds. Build date is a simple check.
  19. Jul 22, 2024 at 7:05 AM
    Black97v6MT
    Black97v6MT 366k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    28 years of livin' Gen1 TacoLife...
    are you looking for auto or manual transmission in the single cab?
    4WD?
  20. Jul 22, 2024 at 8:13 AM
    FlexingtonKY
    Sam
    The South
    I’m looking for a 4x4 manual trans (which I imagine is what most folks say lol). It’s what my 1st Gen is and I’m hooked
    Black97v6MT[QUOTED] likes this.
