BUYER BEWARE: 3rd Gen Plug-N-Play Tailgate Bolt-N-Lock & Tailgate Bolt-N-Open
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KTJO 4x4, Feb 10, 2019.
Thread Status:
Not open for further replies.
  1. Mar 3, 2019 at 8:11 PM
    #581
    cshrum
    cshrum Well-Known Member
    CO Springs, CO
    17 blue TRD sport DCLB
    You’re awesome Katie! Thanks for your hard work and also wanting to make everything better, and adapting it as new ideas make the great thing even greater!
  2. Mar 4, 2019 at 3:57 AM
    #582
    Sgt.Tee
    Sgt.Tee Well-Known Member
    Pete
    NE Pa
    2019 MGM SR Tacoma 4&4
    Yes I willdrill the small holes. Having a magnet hold it in place is not a option for me. I am curious to see in the instructions how this actuator gets mounted, I read where guys are using a 2&4, piece of channel etc. I read also not to bend the wire on the actuator, so there are many different ideas floating around. I will follow the instructions once I receive the kit. Here in Pa. that will be weeks from nowaccount of the weather. Maybe someday I will move where it does not rain every other day. Wishful thinking
    KTJO 4x4[OP] likes this.
  3. Mar 4, 2019 at 4:02 AM
    #583
    itsnotatoy
    itsnotatoy Well-Known Member
    NW Valley AZ
    2023 Tacoma DCSB ICE CAP TRD Sport Premium & Tech Pkg
    I moved to AZ from NY. I know what rain and humidity is like. Couldn't take it anymore. Here in the Phoenix area we avg 300 days of sunshine per year. If you can bear a few months of heat the rest of the year is great!
    r1200gs4ok likes this.
  4. Mar 4, 2019 at 4:18 AM
    #584
    Sgt.Tee
    Pete
    NE Pa
    I moved to Pa from the Bronx, Being raised in the Bronx and moving here was a huge change. I made the move in the 70,s. The only thing I miss is my friends down there.
  5. Mar 4, 2019 at 4:58 AM
    #585
    Brandon230
    Brandon230 Active Member
    2018 Blazing Blue Pearl Tacoma Limited
    None yet...looking at options
    Can I get added to the list for a full kit please
    KTJO 4x4[OP] and BlackRoan like this.
  6. Mar 4, 2019 at 5:29 AM
    #586
    GoGoGadget
    GoGoGadget Well-Known Member
    2017 DCLB OR
    Sorry for the confusion. I have this magnet for another purpose, I have not actually used it for this mod. When the one guy expressed concern over drilling two holes in the tailgate I offered this as a possible alternative. My thought was take a piece of flat stock, steel or aluminum, or use a outlet blank from the electrical section and bolt that to the magnet. Then screw the actuator to that piece and place the magnet where it would normally be screwed per install instructions.
    I don't have the PNP kit yet. When I do I will install it with the magnet just to see if it works for anyone interested, then I will bolt it in drilling the two holes because I am not worried about drilling two holes in a spot that is unseen.
    Sgt.Tee[QUOTED] and itsnotatoy like this.
  7. Mar 4, 2019 at 7:43 AM
    #587
    Sgt.Tee
    Pete
    NE Pa
    Understood and thanks, I figured you are doing it that way. For some reason no matter how strong the magnet I would not trust it for this application, one good dip in the road and it will move. I have several good magnates I purchased for my fire arms and they move from time to time. This is a great idea though, but I am drilling. I guess you could use 3m double sided tape. That stuff is pretty strong, for me I am drilling and I would like to see how to attach that actuator.
  8. Mar 4, 2019 at 7:55 AM
    #588
    r1200gs4ok
    r1200gs4ok Well-Known Member
    O. K.
    Irvine, Ca
    2016 Tacoma TRD Sport DCLB w/ Tech, Nav, Tow Pkg, MGM
    don’t come to southern california....its been raining here for 24 of the past 30 days......but we need it
    Sgt.Tee[QUOTED] likes this.
  9. Mar 4, 2019 at 12:21 PM
    #589
    misterspruge
    misterspruge Member
    PA
    2018 Tacoma Sport
    Overpriced grill and FN fxpro wheels
    Sent a PEE EMM. Thank you
  10. Mar 4, 2019 at 12:45 PM
    #590
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    Well okay then . . .
    Ur in
  11. Mar 4, 2019 at 12:48 PM
    #591
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Is this the same harness that gets tied into for the passenger side door unlock handle mod? The one where u touch to lock / unlock?
  12. Mar 4, 2019 at 12:50 PM
    #592
    Oscar I
    Oscar I No longer a toyota driver
    A
    Good question I have no idea although I need to do that mod too
    KTJO 4x4[OP] and Skydvrr[QUOTED] like this.
  13. Mar 4, 2019 at 12:51 PM
    #593
    Skydvrr
    Nick
    YMH
    Black '17 OR
    It's be nice to have both those leads spliced in. But it's still better to positap the jumper harness than the OEM one.
  14. Mar 4, 2019 at 12:54 PM
    #594
    Oscar I
    You can always pull the necessary pins from the harness and solder in the leads for that of it's not the same and it's on the plug. Easier to do that outside the vehicle for sure.
  15. Mar 4, 2019 at 12:55 PM
    #595
    Skydvrr
    Nick
    YMH
    Black '17 OR
    True
  16. Mar 4, 2019 at 1:06 PM
    #596
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    Count me in for the harness only. I've already picked up an actuator unit. Paypal ready..
  17. Mar 4, 2019 at 1:49 PM
    #597
    n6vmo
    n6vmo Well-Known Member
    Sahuarita, AZ
    2018 DCLB OR AT Super "Priviledged"
    Bilstein 6112, ICON UCAs, 5160, AAL, 265/75/16 Falken Wildpeaks
    So, how is the anodized bracket, pictured below used?
    It could be bent/shaped to mount the actuator level with the lock mechanism.
  18. Mar 4, 2019 at 2:06 PM
    #598
    BlackRoan
    BlackRoan Well-Known Member
    2018 White TRD PRO
    Still working on it
    Can I get added for this harness
  19. Mar 4, 2019 at 2:36 PM
    #599
    Oscar I
    It's not used in our guide. If you figure something out tho I'd love to hear it
  20. Mar 4, 2019 at 2:51 PM
    #600
    CZ-Jack
    CZ-Jack Well-Known Member
    2019 DCSB OR Cement
    Is this thing loud as piss?
Thread Status:
