BUYER BEWARE: 3rd Gen Plug-N-Play Tailgate Bolt-N-Lock & Tailgate Bolt-N-Open
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KTJO 4x4, Feb 10, 2019.
Thread Status:
Not open for further replies.
  1. Mar 28, 2019 at 10:44 AM
    #981
    Rkiz4x4
    Rkiz4x4 Member
    Kisgen
    Pm sent just waiting on confirmation before submitting payment.
  2. Mar 28, 2019 at 3:47 PM
    #982
    CAG Gonzo
    CAG Gonzo Ascendant Spaghetti
    2018 OR DCLB BarRed
    Can someone clarify Step 4, "Screw actuator in place using supplied hardware."? I've got my two holes, and the hardware includes 4 silver screws, 2 brass lock washer plate things (that's what it looks like they do) and 3 stubby brass screws with a brass block with 3 holes and a trough. Looks like that block is for the actuator rod.
    What I'm thinking is the screws are mounted through the holes from the top, and the lock washer plates go in between the actuator body and metal portion of the tailgate. However I'm having a hard time getting the screws to screw and I'm worried I'll render the holes useless if I try to force it.
    MAS likes this.
  3. Mar 28, 2019 at 3:52 PM
    #983
    r1200gs4ok
    r1200gs4ok Well-Known Member
    O. K.
    Irvine, Ca
    2016 Tacoma TRD Sport DCLB w/ Tech, Nav, Tow Pkg, MGM
    some people use the 2 silver sheet metal screws to attract actuator to the tailgate.....i would re-think that....see my post 984......
  4. Mar 28, 2019 at 3:56 PM
    #984
    CAG Gonzo
    2018 OR DCLB BarRed
    Very detailed install. I'll be using that for routing, which I'm doing now until I figure how to mount the actuator. I don't have tubing or foam like you do. I'll just mount it direct and assess the noise and stability. I don't mind opening her back up again if I need to tack down some foam.
    r1200gs4ok[QUOTED] likes this.
  5. Mar 28, 2019 at 4:06 PM
    #985
    r1200gs4ok
    O. K.
    Irvine, Ca
    mounting the actuator is the most difficult item because you have to be sure how you are going to connect the rod to the arm on the handle.....it makes a big difference because of the way in which the rod moves and how you insert the rod in the eyelet......those things took me along time to decide with trial and error......all in all, i'm happy....very little noise....it sound better than any OEM i have listened to and looks like OEM .....to take apart and remount the actuator would be a pain in the butt......and the new holes you would have to drill maybe too close and intersect.....my recommendation si to spend the extra time and think out the actuator mounting place....good luck
  6. Mar 28, 2019 at 4:18 PM
    #986
    CAG Gonzo
    2018 OR DCLB BarRed
    That's sound advice. I have it in line with the hole I drilled in the black plastic arm, per the instructions. The tailgate is unlocked.
  7. Mar 28, 2019 at 4:29 PM
    #987
    r1200gs4ok
    O. K.
    Irvine, Ca
    do your measurements with the tailgate unlocked and the actuator fully retracted......
    i almost went off last night and did not connect the rod back to the orange locker.....fortunately i had not closed my tonneau cover....had i done that, i would not have been able to open the tail gate and had to break in......hahahah
    also take notice whether you want the top of the rod at N, E, S, or W position as it comes out of the eyelet.....makes a difference on where you drill holes for actuator and how you would have to bend the rod......trial and error and patience.....take your time.....i did and i am glad it did....there are many ways to mount the actuator and run the rod.......just figure out how and what you want, the picture it and manually open and close the actuator to see what things line up......remember, it is measure many times and cut/bend once......take your time
    MAS and vanrynd like this.
  8. Mar 28, 2019 at 5:02 PM
    #988
    CAG Gonzo
    2018 OR DCLB BarRed
    Thanks for the help. I got it mounted. I...may or may not have used a smaller drill bit initially. Can neither confirm nor deny. With properly sized holes the screws secured the actuator no problem. The system works! I see a very minor flex near the handle as the actuator actuates. I don't think that should be an issue overall, however.
    Unfortunately, the bullet connector on the blue wire of the wire run did come off and I wasn't able to crimp it back on securely so I'll run over to Lowe's and get a new one. The test only worked because of a shoddy electrical tape job that is in no way intended to be permanent.
    Solid product and very pleased I was able to do this on my own in about 3 hours! 10/10, would recommend and buy again.
    MAS and PapaRee like this.
  9. Mar 28, 2019 at 5:08 PM
    #989
    r1200gs4ok
    O. K.
    Irvine, Ca
    great news.........funny you mention the bullet connectors......all of mine came off.....not happy.....but went to Home Depot and got new ones and crimped them on and gave a tug.....now all good.....i am really happy i was able to do this.....lot easier than taking out my BMW motorcycle speedometer circuit board and soldering a jumper wire to make it give me correct speed and match up with the GPS.....
    only thing i did not do yet was to cut off ends of tie wraps.....:facepalm:
  10. Mar 28, 2019 at 5:10 PM
    #990
    Delmarksman
    Delmarksman Well-Known Member
    Smyrna, DE
    2016 TRD OR DCSB - Red, Premium & Tech Pkg
    OEM, For now...
    If not too late, Pictures please.
    Has anyone done a video of their install?
  11. Mar 28, 2019 at 5:15 PM
    #991
    r1200gs4ok
    O. K.
    Irvine, Ca
    look at post #984
    Delmarksman[QUOTED] likes this.
  12. Mar 28, 2019 at 5:33 PM
    #992
    r1200gs4ok
    O. K.
    Irvine, Ca
    mine was very close to being short also......i went as direct as possible.....i did not go into the first floor panel tie down, went to the second and had about 1.5" of strain relief.....i was about to have a heart attack
    KTJO 4x4[OP] likes this.
  13. Mar 28, 2019 at 5:45 PM
    #993
    KTJO 4x4
    KTJO 4x4 [OP] Well-Known Member
    Katie
    Oregon
    2017 TRD OFF-ROAD 4x4 DCSB BARCELONA RED
    Nitro 4.88 Gears OVTune 1.05 91Oct DirtyDeeds Exhaust
    Glad you made it with that 1.5” of strain relief :rofl: These butt connectors are really upsetting to be honest. I haven’t really heard anything from anyone recently and I’m taking that as a good thing as I’m thinking it was just that group of like 12, but still. I do know these last few batches there shouldn’t be any of them falling off. I pulled and tugged on each of them before shipping. I’m glad everyone is starting to get their kits in the mail.
    I will be getting to more of the new order updates tonight and tomorrow. ;)
  14. Mar 28, 2019 at 5:49 PM
    #994
    r1200gs4ok
    O. K.
    Irvine, Ca
    no big deal.....i know how to do things.....my set up with your kit is great.....as i have said, i took my time and got it right.....happier than a pig in slop....hahaha....no to wash truck......thanks Katie for all your hard work and patience with us......this site is great.....take care
    cshrum likes this.
  15. Mar 28, 2019 at 6:44 PM
    #995
    itsnotatoy
    itsnotatoy Well-Known Member
    NW Valley AZ
    2023 Tacoma DCSB ICE CAP TRD Sport Premium & Tech Pkg
    There's pictures throughout this thread. Its a lot to read but good info here.
  16. Mar 28, 2019 at 8:33 PM
    #996
    Jjhebert
    Jjhebert Member
    Jonathan
    Tacoma trd sport
    None yet
    Great kit. Easy to install, great and easy instructions!! Thanks
  17. Mar 28, 2019 at 9:11 PM
    #997
    KTJO 4x4
    Katie
    Oregon
    You are Welcome! :thumbsup:
  18. Mar 28, 2019 at 11:31 PM
    #998
    the_dau
    the_dau Well-Known Member
    Vancouver BC
    2017 Inferno TRD OR DCSB
    got mine in the mail today. border guards opened it! but everything's intact. thanks for all your hard work!
  19. Mar 29, 2019 at 12:00 AM
    #999
    KTJO 4x4
    Katie
    Oregon
    Glad everything is intact :) you are Welcome! Enjoy!!!
    the_dau likes this.
  20. Mar 29, 2019 at 4:53 AM
    #1000
    arguscanis
    arguscanis Well-Known Member
    rj
    cape cod
    17 Taco trd sport quicksand
    redline hood struts softopper meso pro shift mod stage 2 ebay scoop light mod fang hood vinyl remote start/ 4g anywhere start N2Designs KTJO 4x4 tailgate lock Faux Pro grill DIY Raptor lights Morimoto Amber fog lights Bilstein 5100 front and rear 887s front Dakar Medium Leaf Pack Poly Bushings Ultra Gauge Pro Skid plate SCS f5's Falken At3 wildpeaks Timbren bump stops x4 Meso led mirror turn signals Anytime back up camera SSO rock sliders (linex)
    pm sent, awaiting reply:drool:
Thread Status:
