Buyer Beware: KTJO 4X4 Driver's Side Grab Handles w/ A Pillars, HUD, and Bowl Lights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Dec 13, 2019.
DAH Delivery Challenge
  1. Ordered?
    27.2%
  2. Received?
    37.9%
  3. Have to bend upper clip to fit?
    15.9%
  4. Missing Upper Cover?
    6.0%
  5. Missing Lower Cover?
    3.4%
  6. Incorrect Hardware?
    13.4%
  7. Scratches / Damage?
    9.9%
  8. Other (oh gawd)?
    20.7%
  9. Magically Perfect!
    25.4%
  10. Stuck in Shipping Label Created Purgatory?
    3.9%
  11. OGs Still Waiting since Before the Ban?
    7.3%
  12. Return Attempted?
    1.7%
  13. Return Actually Happened?
    3.0%
Multiple votes are allowed.
Thread Status:
Not open for further replies.
  1. Jan 6, 2021 at 7:48 AM
    #2461
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Drilling out a spinning rivenut in the interior of a vehicle by the side airbag is the stuff nightmares are made of lol
    IcemanPNW, Buck Rogers, VB25 and 4 others like this.
  2. Jan 6, 2021 at 7:49 AM
    #2462
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    Yeah, the extra positional and angular adjustability of the clip nut (still tinnerman nut to me even if it has a full nut) seems like a very good idea on this application.
    Skydvrr[QUOTED] and tonered[OP] like this.
  3. Jan 6, 2021 at 7:50 AM
    #2463
    Tacospike
    Two Trucks
    Agreed!!
    I've drilled out thousands but never in that type of situation.
    Edit: more like hundreds, but still a lot
  4. Jan 6, 2021 at 7:50 AM
    #2464
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    100%
    :cheers:
  5. Jan 6, 2021 at 7:56 AM
    #2465
    BigWhiteTRD
    Ted
    You are both absolutely correct about keyed rivnuts. The truly difficult thing about removing is how do you hold the bolt or screw from spinning while drilling. Usually I try to pull the item or device away from the structure with enough force to cause the nut or bolt/screw head to jam on something.... Or use a dremel to cut a notch in the fastener head to hold while you drill.
    That said, after working for HOURS (in the past) to remove a single spinning riv-nut without destroying the aircraft structure, I am very hard pressed to use one except in situations where they can be held from the rear (somehow) in case of a failure. (and that is with a keyed rivnut).
    Also as Tony noted, their tension capability is rather poor, but I suppose its still probably ample...
  6. Jan 6, 2021 at 8:01 AM
    #2466
    tonered
    tony
    Lynnwood, WA
    A bit more SM backlash is always good here:
  7. Jan 6, 2021 at 8:04 AM
    #2467
    Skydvrr
    Nick
    YMH
    Black '17 OR
    How come they're bad in tension? Seems it would get stronger w more tension.
  8. Jan 6, 2021 at 8:08 AM
    #2468
    tonered
    tony
    Lynnwood, WA
    Most rivets and other deformed fasteners are not meant for tension applications. In places where deformed fasteners are used for tension joints, you will see the attaching fasteners loaded in shear.
    This was why I was suggesting the use of a backing washer or plate for the rivnut application. @Bertw192 came up with the best idea of threaded and keyed plate.
    But again, it is useless with the poor design of the handle.
    Skydvrr[QUOTED] and Tacospike like this.
  9. Jan 6, 2021 at 8:10 AM
    #2469
    Tacospike
    Two Trucks
    The punches keep on going. What a cluster $%*^
    Skydvrr and tonered[QUOTED][OP] like this.
  10. Jan 6, 2021 at 8:12 AM
    #2470
    tonered
    tony
    Lynnwood, WA
    Just crazy.
    Looking through the negative comments, only a couple are responded to. Of course, never an apology for the fuck ups.
    #bangood
  11. Jan 6, 2021 at 8:25 AM
    #2471
    tacobelletx
    tacobelletx Well-Known Member
    TX
    '18 Sport ACLB
    Technically, she did apologize for being only one person to an IG comment at one point...
  12. Jan 6, 2021 at 8:26 AM
    #2472
    tonered
    tony
    Lynnwood, WA
    :eek:
    Could you imagine a world with more than one KTJO4x4s? Maybe that is where Pelfrey came from? :bananadead:
  13. Jan 6, 2021 at 8:31 AM
    #2473
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Interesting.
  14. Jan 6, 2021 at 8:35 AM
    #2474
    BigWhiteTRD
    Ted
    Another way of looking at it, if the material in the 'rivet' has low enough yield strength to be deformed during installation, it isnt strong enough to be a really be a very good quality nut.
    (just some comparative data happen to have handy in front of me for tension strength)...
    A .25-28 Riv-Nut (NAS 1329) is good for 1820 lb tension when its made from aluminum, and 3500 lb tension when its made from carbon steel...
    A normal AN4 bolt (125 ksi standard) is good for 4170 lb tension (Mil-Hdbk-5).
    And a normal structural nut (such as AN365-4) is good for 6000 lb tension (MIL-N-25027)
    So not including durability, the (typical) rivnut is going to be weaker than a typical structural bolt, and much weaker than a typical nut.
    But durability is the bigger issue (for me).
    Sorry for the tangent...
    Now back to your regularly scheduled vendor shenanigans.
  15. Jan 6, 2021 at 8:38 AM
    #2475
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    Yes I can… look at the current majority of the younger generation with the no accountability, lack of moral compass and wants everything given not earned :anonymous: wait what are we talking about again
  16. Jan 6, 2021 at 8:55 AM
    #2476
    Skydvrr
    Nick
    YMH
    Black '17 OR
    The numbers never lie. Thanks for that!
    tonered[OP] likes this.
  17. Jan 6, 2021 at 8:58 AM
    #2477
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    Who's worse? USPS or KTJO?
  18. Jan 6, 2021 at 9:03 AM
    #2478
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    What is Premium Tracking? Do you pay extra for more details?
  19. Jan 6, 2021 at 9:05 AM
    #2479
    Skydvrr
    Nick
    YMH
    Black '17 OR
    "The box is feeling a bit down, maybe claustrophobic because it's at the bottom of the pile"
  20. Jan 6, 2021 at 9:06 AM
    #2480
    Tacospike
    Two Trucks
    Well well well
    StayinStock, Devious6 and tonered[OP] like this.
Thread Status:
