Buyer Beware: KTJO 4X4 Driver's Side Grab Handles w/ A Pillars, HUD, and Bowl Lights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Dec 13, 2019.
DAH Delivery Challenge
  1. Ordered?
    27.2%
  2. Received?
    37.9%
  3. Have to bend upper clip to fit?
    15.9%
  4. Missing Upper Cover?
    6.0%
  5. Missing Lower Cover?
    3.4%
  6. Incorrect Hardware?
    13.4%
  7. Scratches / Damage?
    9.9%
  8. Other (oh gawd)?
    20.7%
  9. Magically Perfect!
    25.4%
  10. Stuck in Shipping Label Created Purgatory?
    3.9%
  11. OGs Still Waiting since Before the Ban?
    7.3%
  12. Return Attempted?
    1.7%
  13. Return Actually Happened?
    3.0%
Multiple votes are allowed.
Thread Status:
Not open for further replies.
  1. Jan 18, 2021 at 7:10 PM
    #3581
    Rainoffire
    Rainoffire Well-Known Member
    2017 QS DCLB TRD Sport
    I like my for bowl lights too. A subtle but nice change for the interior.
  2. Jan 18, 2021 at 7:58 PM
    #3582
    Malvolio
    Malvolio free zip ties for Stun
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    There’s a scene from MST3K: The Movie (1993) where Crow decides to take a pick axe to the hull and “dig his way back to earth.” (They are lost in outer space.) The ship depressurizes, stopped only by Tom Servo, who ends up fitting neatly over the hole and, when a sucking sound ensues, says something like “this is a new feeling...and frankly I LIKE IT.” (Use your imagination.)
    Joel them asks Crow what he was thinking. And Crow replies “the thought occurred to me that I was doing something really stupid...........and I did it anyway.”
    Rock Lobster and tonered[OP] like this.
  3. Jan 18, 2021 at 8:08 PM
    #3583
    mrkabc
    mrkabc Mall Crawler with a Locker
    Art
    Corona, CA
    2017 MGM DCSB TRD OR
    Morimoto XB LED Head & Fog Lights, Cali Raised Stealth Light bar, OEM Roof Rack, Homelink Compass Mirror, Power Tailgate Lock, LED bed lights, MESO mirrors, gashole, switch panel & Stage 2 tails, PRO grille. Where's the mall?
    Glutton for punishment are you? :facepalm:
    Malvolio and tonered[OP] like this.
  4. Jan 19, 2021 at 12:56 AM
    #3584
    Malvolio
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    When your want for little LEDs in the flipper handle recess thing overcomes 3,500 posts of pain. It’s like supporting the South Sea Company because you like the whale meat.
    tonered[OP] likes this.
  5. Jan 19, 2021 at 4:13 AM
    #3585
    tacobelletx
    tacobelletx Well-Known Member
    TX
    '18 Sport ACLB
    Surprisingly, the most time consuming part of my install was trying to get the pillar to seat correctly next to the tweeter cover... oh and having to wet sand the covers to make them fit/look better. It was challenging to get the bolts to line up. I don't think the top ended up bending any (I pulled a bit to get it under the weather stripping, but don't think it was enough to bend the metal).
    I'll check eventually because I'll probably end up needing to take it off at some point to get my puddle light tharness situated better. After having the dealership take out my dash for warranty AC work a while back, the map/dome lights flicker some. Thought I fit the harness in better while installing the grab handle, but still have a bit of flickering.
    Overall, the part itself isn't too bad, but definitely not OEM quality. I can for sure say that if I hadn't ordered back in July (before the shit show started), I most definitely wouldn't have ordered.
    [​IMG] [​IMG]
    TVphotog97, Malvolio, DES2009 and 3 others like this.
  6. Jan 19, 2021 at 6:54 AM
    #3586
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    At least the easy install made up for the shitty fulfilment, damage, and exchange.
    Torquing the fasteners will not bend the clips. That is all done manually. Mainly with just the bolt threaded in a pulling on it in the direction needed.
    tacobelletx[QUOTED] and pochoboy like this.
  7. Jan 19, 2021 at 7:07 AM
    #3587
    pochoboy
    pochoboy Well-Known Member
    BountyOR_VF2 and Soul Surfer like this.
  8. Jan 19, 2021 at 7:27 AM
    #3588
    TacoSupremo19
    TacoSupremo19 Well-Known Member
    NJ
    2019 Black Tacoma TRD SPort DCSB
    Brushed Copper Blaze 10 Rims | 265 70 17 Toyo Open Country A/T III tires | Bilstein 5100 w/ Eibach Coils 2.5" lift | Blackhawk UCAs | ICON Rear 3 AAL |TRD Skid Plate | TRD CAI | OEM Rear Bed Lighting | OEM rear Tailgate lock | RC Bed Molle Racks | Custom Blacked out OEM LED Headlights | MESO V4 Mirror Turnsignals | MESO Interior trim blackout | TG DMM dash mount | TRD Shift Knob | OEM SR5 interior door handles | Upgraded Stereo including Alpine 700W Amp Alpine Type R Components & Hertz speakers 12" Sub | Custom Clazzio Seat covers | Mobtown Sliders | Front Camera
    I installed mine the other night. I used the Dorman M6 clip. My pillar came without the metal bushings installed so I left them loose on the end of the bolt which gave me more wiggle room. You can push them out easy if they are installed. I put the pillar into place (tweeter cover removed) and put the handle (with the bolt in it with the loose bushing) up to the mounting spot and found the clipnut and started it about 4 threads then did the same thing for the top bolt. I turned in both bolts some more making sure to leave enough room to push the bushings in place. All this time my handles are still not recessed in place. I then took a screwdriver and pushed the bushings in place. Tighten the bolt more to the point I knew the bushings weren't going to back out and then pushed the handle into the pillar. The bottom didn't line up and I had to push the handle down a little to get it to recess. Then popped the top in. Check to make sure the bushings were still in place and tightened the bolts. All the gaps look perfect to me. The weather-strip covers the edge of the pillar piece like the OEM piece was. The covers are ok. Lastly the color is slightly off
  9. Jan 19, 2021 at 7:39 AM
    #3589
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
  10. Jan 19, 2021 at 7:41 AM
    #3590
    Malvolio
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
  11. Jan 19, 2021 at 7:44 AM
    #3591
    Daria
    Daria Can I pet your dog? Moderator
    Dodging tumbleweeds
    People that use this site can’t either. I’ve seen tocoma waaaaay too many times.
  12. Jan 19, 2021 at 7:51 AM
    #3592
    Malvolio
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    Yeah, and I wasn’t really spelling shaming him. The video includes him trying to speculate whether the tiger-slashed “O” on KTJO’s business card is, indeed, an “O.” Gotta make content for the viewers, I guess.
    Tacospike likes this.
  13. Jan 19, 2021 at 8:03 AM
    #3593
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    So, while you're here, are you having fun monitoring the BS that is going on here?
    Malvolio and Tacospike like this.
  14. Jan 19, 2021 at 8:14 AM
    #3594
    pochoboy
    ho hum yt Grab Handle install video? lol, no problems with the install but that bottom bolt cover didn't seem to fit tightly on.
    I'm wondering the date and where its was manufactured?
    Malvolio likes this.
  15. Jan 19, 2021 at 8:26 AM
    #3595
    Daria
    Dodging tumbleweeds
    I’m just flabbergasted that people see this thread and continue to purchase crap from her.
  16. Jan 19, 2021 at 8:27 AM
    #3596
    Tacospike
    Two Trucks
    :amen:
  17. Jan 19, 2021 at 8:27 AM
    #3597
    tonered
    tony
    Lynnwood, WA
    Supposedly 2k more on the way.
    Might wanna lock it up? :smash:
  18. Jan 19, 2021 at 8:29 AM
    #3598
    johnnyroid
    johnnyroid Well-Known Member
    Vine Grove (Fort Knox) Kentucky
    2017 Black Tacoma Sport TRD
    I actually was going to do the bowl light too, and after reading this thread, and the problems with the light, I can't see any reason to deal with them at all.
    Toms 17, CttAznRanger and tonered[OP] like this.
  19. Jan 19, 2021 at 8:30 AM
    #3599
    Daria
    Dodging tumbleweeds
    I went ahead and added/linked this thread to a closed thread that is the first result on google for “ktjo 4x4” ;)
  20. Jan 19, 2021 at 8:34 AM
    #3600
    tonered
    tony
    Lynnwood, WA
    Thanks!
    This thread comes up first after direct ktjo4x4.com links. Seems that KTJO 4x4 knows how to manage Google search promotion:
    Apparently, shilling on Pinterest without a real account?
    IcemanPNW likes this.
Thread Status:
