Buyer Beware: KTJO 4X4 Driver's Side Grab Handles w/ A Pillars, HUD, and Bowl Lights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Dec 13, 2019.
DAH Delivery Challenge
  1. Ordered?
    27.2%
  2. Received?
    37.9%
  3. Have to bend upper clip to fit?
    15.9%
  4. Missing Upper Cover?
    6.0%
  5. Missing Lower Cover?
    3.4%
  6. Incorrect Hardware?
    13.4%
  7. Scratches / Damage?
    9.9%
  8. Other (oh gawd)?
    20.7%
  9. Magically Perfect!
    25.4%
  10. Stuck in Shipping Label Created Purgatory?
    3.9%
  11. OGs Still Waiting since Before the Ban?
    7.3%
  12. Return Attempted?
    1.7%
  13. Return Actually Happened?
    3.0%
Multiple votes are allowed.
Thread Status:
Not open for further replies.
  1. Jan 24, 2021 at 5:26 PM
    #3801
    Malvolio
    Malvolio free zip ties for Stun
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    Wasn’t the jugular. We waited 13 months. It’s archeology and relics at this point.
  2. Jan 24, 2021 at 5:26 PM
    #3802
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    It doesn't block the view for my seating position. Folks who sit further back my lose just a bit.
    My issue is not that you offered a positive experience, but that you said:
    That is clearly not the case. Speculation, cognitive dissonance, or a fabrication?
  3. Jan 24, 2021 at 5:28 PM
    #3803
    tonered
    tony
    Lynnwood, WA
    Mummy handles?
    wahoobie and Malvolio[QUOTED] like this.
  4. Jan 24, 2021 at 5:35 PM
    #3804
    pvhobo
    pvhobo Member
    tonered
    Yea communication was not stellar, turn around time was long, but super happy with install and end result.
    That's all I meant to convey to the TW group.
    hotrodder636 and whatstcp like this.
  5. Jan 24, 2021 at 5:59 PM
    #3805
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Manitoba
    3G, Tuned
    @pvhobo , if you want to tag someone, type the @ in front of the handle. As in @tonered :)
    Malvolio and tonered[OP] like this.
  6. Jan 24, 2021 at 6:01 PM
    #3806
    tonered
    tony
    Lynnwood, WA
    That is fine and there are some folks who feel the same way that you do. No one here is making representations beyond their own experience. The collective outcome is up to the reader.
    There were positives for me, but mostly negative including the fact that I don't trust it because of the amount of bending required on installation.
  7. Jan 24, 2021 at 6:04 PM
    #3807
    pvhobo
    pvhobo Member
    One more thing to keep in mind on these Grab Handles.
    Some of you have had some issues installing the bolts on install like I did.
    I ran a tap down the hole to clean up the threads before installing the bolts.
    Once installed you will forget this.
    When you go to have a windshield installed, they will have to remove this handle and bezel.
    Most shops will use an electric impact or air wrench to install your handle and will strip those bolt holes.
    Had it happen more than once.
    Who cares if they think you are a pain the ass by watching to make sure they hand start each bolt a couple threads, at least it will get done right.
  8. Jan 24, 2021 at 6:09 PM
    #3808
    pvhobo
    pvhobo Member
    Malvolio and wiljayhi like this.
  9. Jan 24, 2021 at 6:55 PM
    #3809
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    :thumbsup: I'll make it a point to remove the grab handle and A-pillar trim when I need to get the windshield replaced.
  10. Jan 24, 2021 at 7:03 PM
    #3810
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Good PSA there. :thumbsup:
    perkj and PapaRee like this.
  11. Jan 25, 2021 at 11:04 AM
    #3811
    Truggin
    Truggin What a long, strange trip it's been
    Don
    39.15737720308645, -77.92212986904099
    Black 2016 TRD Sport V6 4x4 Access Cab
    It's a work in progress. See my build thread.
    Well... Mine finally arrived. The box didn't hold up very well:
    But it looks like all of the parts made it:
    But one cover doesn't sit right:
    And should the threaded insert that goes in the round hole here, be able to fall out (like it did)?
    xxTacocaTxx likes this.
  12. Jan 25, 2021 at 11:06 AM
    #3812
    tonered
    tony
    Lynnwood, WA
    The bushing falling out is not a problem. It would be a minor plus if it stayed in place.
    Truggin[QUOTED] likes this.
  13. Jan 25, 2021 at 11:08 AM
    #3813
    ljerr2
    ljerr2 Well-Known Member
    Iowa
    2020 Tacoma TRD Pro
    Hope your install goes well...
    That insert is just a shoulder for the bolt, so it is not threaded. And no, it shouldn't fall out.........but mine did and probably 99% of everyone else's.
  14. Jan 25, 2021 at 11:27 AM
    #3814
    jimmerheck
    jimmerheck Well-Known Member
    Vancouver, WA
    2019 Tacoma Limited in white
    I still find it hard to believe that all of these handles were possibly built by the same molding machines to the same specs, but some of the members were able to start the upper bolt easily. I had to reef my handle like hell towards the windshield to get the upper bolt lined up straight, it was WAY out of alignment until I reefed on that handle. I hope some people didnt just force that upper bolt in at a cross threaded angle.
  15. Jan 25, 2021 at 11:41 AM
    #3815
    tonered
    tony
    Lynnwood, WA
    Same here. I have a few theories, but they just lead to more questions.
    -- Given the size and complexity of the parts, there are only one set of molds for this kit.
    -- The handle was tested on one Taco that was on the far end of the range of possible clip orientations. I cannot see Toyota accepting a 15deg total variance on metal parts, even for interior trim, but who really knows?
    -- The Stock pillar trim piece doesn't really care about the clip angle. All that it needs to align is a short 20mm (?) bolt through a thin piece of plastic. The angle in something so shallow is not critical and 7.5deg can be sucked up in the plastic. The much longer bolt needed for the handle reveals the issue.
    Big note there: KTJO 4x4 whipped in a 2,000 handle order without giving a shit about correcting the OEM / PnP fit of the kit. It would not be a fun adjustment to the molds, but it should have been considered to some extent.
    -- Some folks rate bending metal parts differently than others. Hammer to fit may be just fine to some and out of the range of sane possibilities to others.
    -- KTJO 4x4 doesn't give a flying fuck as long has the "OEM" mods print money.
  16. Jan 25, 2021 at 11:47 AM
    #3816
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
  17. Jan 25, 2021 at 11:52 AM
    #3817
    tonered
    tony
    Lynnwood, WA
    :wave:
    Me too!
    Just fixing one of the major issues could have been game changing for this kit.
    dilbert[QUOTED] likes this.
  18. Jan 25, 2021 at 11:52 AM
    #3818
    cabo wabo
    cabo wabo Well-Known Member
    billy
    virginia
    2019 dbc short bed trd sport
    Received mine on 1/3/2021 and the box looked like it had been in a tornado. Missing bottom bolt cover. Emailed both addresses on 1/3/2021 and have not received an email or missing part yet.
    tonered[OP] likes this.
  19. Jan 25, 2021 at 4:24 PM
    #3819
    STi and Taco
    STi and Taco Not a Super Hero
    Steven
    Georgia
    '16 Tacoma SR 4x4 Access Cab Black, 2012 Subaru STi Hatchback Black, 1995 Acura Legend L Gold (RIP), 2020 Corolla Hatchback
    Diode Dynamics LED Inerior Lighting https://www.diodedynamics.com/by-vehicle.html?no_cache=1&find=2016-toyota-tacoma-115242 Hella Supertone Horns Some Joe Schmuckitelli Keyless Entry Intermittent Wiper Mod - Thanks to @moe2o4 Cruise Control Mod - Thanks to @moe2o4, again Anytime Back-up and Front Mount Camera Mod - Courtesy of @Logistics91 (amazing customer service helping me get it just the way I wanted it set up) Drawtite Class IV trailer hitch with 7/4 pin connector and P3 Tekonsha Brake Controller RokBlokz Mud Flaps Access Cab Rear Seat Storage Mod - Thanks to @Cagedodger for the original idea. Just modified it to fit my needs. https://www.tacomaworld.com/threads/access-cab-storage-organization.453774/page-4#post-17877877 Method 701 Black Wheels 265-70r17 Nitto Ridge Grapplers Fumoto Drain Valve Weather Tech Floor Liners and Side Window Deflecors Tuxedo TruXport Bed Cover Access Cover Motion LED Light Strip. Mounted 2 in the bed. Air Dam Delete Demello Off-Road Overlander Aluminum Winch Bumper with Baja Hoop and Squadron Sport LED Spots Warn M8000 Winch Silex center console organizer and tray Full Bed and Under Hood LED Lighting A/C Condensation Drain Relocation Rostra Front Heated Seats aFe Power 51-82722 Magnum FORCE Stage-2 Si Pro DRY S Cold Air Intake System (Part #51-82722) Prolightz clear LED fog lights w/ lamin-x overlay Red line Hood struts Diode Dynamics Hi/Low beam HID conversion kit MesoJDM 4 switch cubby panel, 7 switch Center panel and Center console Coin Holder @mesojdm Carhart Gray Front Seat Covers Curtis Class IV receiver B&W Tri-ball hitch King 2.5 Front Coilover/Rear Shock 25001-119/25001-121 Coming Soon: Differential Breather Relocation Mod New tires, can't decide
    Good luck. Follow the link in the first post for a list of contact info. Send a message to everyone of them one after the other. Don't wait for a response from one before you go to the next one on the list. Just send the same message to every damn one of them. Then resend every fucking day until you get a response.
  20. Jan 25, 2021 at 4:28 PM
    #3820
    tonered
    tony
    Lynnwood, WA
    :pccoffee:
    :rant:
    :smash:
    Malvolio likes this.
Thread Status:
