Buyer Beware: KTJO 4X4 Driver's Side Grab Handles w/ A Pillars, HUD, and Bowl Lights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Dec 13, 2019.
DAH Delivery Challenge
  1. Ordered?
    27.2%
  2. Received?
    37.9%
  3. Have to bend upper clip to fit?
    15.9%
  4. Missing Upper Cover?
    6.0%
  5. Missing Lower Cover?
    3.4%
  6. Incorrect Hardware?
    13.4%
  7. Scratches / Damage?
    9.9%
  8. Other (oh gawd)?
    20.7%
  9. Magically Perfect!
    25.4%
  10. Stuck in Shipping Label Created Purgatory?
    3.9%
  11. OGs Still Waiting since Before the Ban?
    7.3%
  12. Return Attempted?
    1.7%
  13. Return Actually Happened?
    3.0%
Multiple votes are allowed.
Thread Status:
Not open for further replies.
  1. Jan 24, 2022 at 12:30 PM
    #5641
    JayCue
    JayCue Well-Known Member
    Jeremiah
    Central California
    2020 TRD OR CEMENT, DC SB
    any updates? do these new harnesses actually fix the issue?
  2. Jan 24, 2022 at 12:31 PM
    #5642
    Airborne22
    Airborne22 It's tough being a trophy husband
    Glen
    Suffolk, VA
    2018 Trd Off-Road SB Inferno Red
    See my build page!
    I asked her if I needed it with the 2018 and she said no, those were for newer models.
  3. Jan 24, 2022 at 12:37 PM
    #5643
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    Yes, it fixed it for my 2019, but I have a little bit of electronic feedback noise, so we're working through that now...
    Aqualoon likes this.
  4. Jan 24, 2022 at 3:15 PM
    #5644
    BOMBS
    BOMBS Well-Known Member
    2017 Black Tacoma TRD Off Road
    I had checked on that electronic noise from the HUD. Started/stopped the truck 2 times. Both times I had heard a low audible noise that sounds like a disc hard drive spinning or a cd/dvd disc spinning. It's a pretty low audible and not significant enough to be a nuisance in my opinion. I did not hear the same noise on both times turning off the truck though.
    If battery drainage is an issue or if it shorten up the lifespan of my AGM battery then that would be a concern. With that being said though, I do have a tune that alters the ECU which makes the alternator provides sufficient voltage for my AGM. I also have a battery maintainer as well, which I still use to maintain my AGM battery.
    If KTJO wants to send me a new one that doesn't have the audible noise, then cool. I'll take it, but at the moment the HUD works and the audible noise does not bother me. I have plenty of other mods and maintenance issues that requires my attention and money.
    Hopefully this helps and y'all make the best decision that suits your need.
    Aqualoon, RyanDCLB and VicNic3 like this.
  5. Jan 24, 2022 at 3:29 PM
    #5645
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    Since @BOMBS hears the noise too, and since you've indicated that the noise stops a minute or so after the truck is turned off, it must be "normal"... as the Toyota dealers would say.
    tonered[OP] likes this.
  6. Jan 24, 2022 at 3:44 PM
    #5646
    RyanDCLB
    4/19 DCLBOR
    I thought the noise stopped after turning off the truck, but now it seems to be going again. They've offered to replace it for free. If the new unit has issues, then I might live with it, or put it on a switched circuit. :notsure:
    I received a tracking number for the new unit 5 minutes after they offered to replace it:
    We haven't had this complaint yet so it is possible that its a defective unit... we can exchange it if you'd like? We will send you a return label with a new one and please send it back to us. Sorry for the inconvenience, this is the first issue we have had with these so far. We will be in touch with shipping information. :)
  7. Jan 24, 2022 at 3:51 PM
    #5647
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    I was thinking that maybe the HUD stayed 'on' and continued to make the faint noise for as long as the steering column 'info' display remains illuminated after turning off the ignition. But maybe yours is actually defective.
  8. Jan 24, 2022 at 5:39 PM
    #5648
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    If the noise is normal, you defo want a switched circuit. The very last thing you want is questionable gizmos melting down.
    I trusted the MC Tuning dual USB outlet to non-switched power for a few years. Nothing from KTJO 4x4 :puke: would I want running unsupervised.
    :poking:
  9. Jan 24, 2022 at 5:54 PM
    #5649
    2020SilverSky
    2020SilverSky Well-Known Member
    Seattle. WA
    2020 TRD Off Road 4WD 6MT
    Just throwing this out for consideration since I don't have one... but do you guys think the sound might be some sort of interference with the sound system given it's unusually close proximity to the tweeter?
    BOMBS and MIDTNTACO like this.
  10. Jan 24, 2022 at 6:02 PM
    #5650
    RyanDCLB
    4/19 DCLBOR
    It would have to be interference from the electrical system. I have mine plugged in, but uninstalled. It makes noise even when I hold it far away from the tweeter. These are also re-branded Chinese units found all over Alibaba, so I'm sure some other owners may have experienced this noise.
    tonered[OP] and Aqualoon like this.
  11. Jan 24, 2022 at 6:05 PM
    #5651
    Aqualoon
    Aqualoon More stickers!
    Minnesota
    2019 Off-Road DCSB Cavalry Blue
    Gives me an excuse to get an AGM battery and then annoy Shellshock about when he'll be back up in Minny for a tune.
    BOMBS[QUOTED] and tonered[OP] like this.
  12. Jan 24, 2022 at 6:10 PM
    #5652
    tonered
    tony
    Lynnwood, WA
    Tag that man! @Shellshock is that AGM dood.
    :militarypress:
    Aqualoon[QUOTED] likes this.
  13. Jan 24, 2022 at 6:12 PM
    #5653
    Aqualoon
    Minnesota
    I didn't want to bother the guy just yet! I mean, if he was doing another Minny run in the spring, I would kinda have to get an AGM battery eh?
    tonered[QUOTED][OP] likes this.
  14. Jan 24, 2022 at 6:14 PM
    #5654
    tonered
    tony
    Lynnwood, WA
    Nah. @Shellshock likes it.
    Those penguin ears (?) just perk right up.
    Shellshock and Aqualoon[QUOTED] like this.
  15. Jan 24, 2022 at 6:20 PM
    #5655
    GrizzledBastard
    GrizzledBastard OH NO! I've built a Faux Pro!
    Tim
    Central Coast, CA
    '21 TRD OR 4x4 DCLB Super White
    Not enough bandwidth on the internet to list.
    OMG!! The Massengill is so strong with this Postage Due!
    My Grab Ass Handle will be here tomorrow but it's coming via UPS so could be here anywhere from 10a.m. to 9p.m. UPS sux so bad in my area but at least one of the drivers gives Labrador Stu a biscuit.
  16. Jan 24, 2022 at 6:22 PM
    #5656
    MIDTNTACO
    MIDTNTACO Well-Known Member
    Middle Tennessee
    2020 Midnight Black TRD Sport 4x4 DCSB
    like a bad ground maybe..?
  17. Jan 24, 2022 at 6:23 PM
    #5657
    MIDTNTACO
    Middle Tennessee
    $1.16.. what the FUCK
  18. Jan 24, 2022 at 6:36 PM
    #5658
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
    This thread had talked me in to, and then out of, so many products. Keep up the good work!
  19. Jan 24, 2022 at 6:39 PM
    #5659
    Aqualoon
    Minnesota
    You might get something that works, you might not. Heck, you might not get anything for weeks/months/years then come home to a random KTJO package at your door that may or may not contain a pen and/or sticker.
    It's like gambling without the free drinks and lights and noises.
  20. Jan 24, 2022 at 6:46 PM
    #5660
    tonered
    tony
    Lynnwood, WA
    :rofl::rofl:
    That some serious Boss Ross inspiration. Gotta put a happy, little burnin' Taco right here.
    And without the hookers and coke.
    :duh::rofl:
Thread Status:
