Buyer Beware: KTJO 4X4 Driver's Side Grab Handles w/ A Pillars, HUD, and Bowl Lights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Dec 13, 2019.
DAH Delivery Challenge
  1. Ordered?
    27.2%
  2. Received?
    37.9%
  3. Have to bend upper clip to fit?
    15.9%
  4. Missing Upper Cover?
    6.0%
  5. Missing Lower Cover?
    3.4%
  6. Incorrect Hardware?
    13.4%
  7. Scratches / Damage?
    9.9%
  8. Other (oh gawd)?
    20.7%
  9. Magically Perfect!
    25.4%
  10. Stuck in Shipping Label Created Purgatory?
    3.9%
  11. OGs Still Waiting since Before the Ban?
    7.3%
  12. Return Attempted?
    1.7%
  13. Return Actually Happened?
    3.0%
Multiple votes are allowed.
Thread Status:
Not open for further replies.
  1. May 18, 2021 at 1:03 PM
    #4761
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    :fistbump:
    tonered[OP] likes this.
  2. May 19, 2021 at 10:08 AM
    #4762
    Mr. Excitement
    Mr. Excitement Well-Known Member
    J
    Custom floormats, fuzzy dice
    Are theses stickers plug and play?
  3. May 19, 2021 at 10:16 AM
    #4763
    Devious6
    Devious6 Not your Average College President Emeritus
    Mark
    Northeast Pennsyltuckyvania
    2020 Army Green TRD Pro
    Yes, they are. But, because of a Customs hold, you will only receive the backing paper for it first. The sticker itself will arrive as soon as possible once Customs releases the roll.
  4. May 19, 2021 at 10:18 AM
    #4764
    Mr. Excitement
    J
    So I finally got my actual handle last night. As usually the package looked like it was shipped by an angry gorilla. I’m not sure who’s fault that is. The handle itself has a few blemishes as you can see. It honestly looks like someone had previously tried to pry it off which is weird.
    The bottom bolt was a pain in the ass. The handle comes with two collar grommet things to guide the bolt. Unfortunately the handle isn’t the right size so the grommet can just fall out. In anyone is doing this install I would recommend adding a layer of painters tape so it stays securely held. I had mine in there and at one point The handle popped off. The grommet evaporated into the ether. I moved the truck, searched the garage, sent magnets down all the vents, it’s just plain gone. So I just said fuck it and installed I with some other grommet I had playing around.
    the hardware isn’t the same quality as the Toyota’s bolts. The Toyota bolts have a slight taper so they easily find the hole and thread. The top I had to thread in and it almost felt like I was cross threading it. The bottoms bolt just would not thread. I had the nut part held in place with painters tape as well so it wouldn’t fall off. After having it on and off at least 4 times, I finally got it. Anyways. In retrospect not sure it’s worth the $180 or 6 month wait, but at least the ordeal is over. If anyone needs some install tips hit me up and maybe I can help you out.
  5. May 19, 2021 at 10:28 AM
    #4765
    Beerpayzdabillz
    Beerpayzdabillz Pastryatarian
    Nor Cal
    2016 DCSB 4x4 sport
    I'm in.
  6. May 19, 2021 at 10:29 AM
    #4766
    STi and Taco
    STi and Taco Not a Super Hero
    Steven
    Georgia
    '16 Tacoma SR 4x4 Access Cab Black, 2012 Subaru STi Hatchback Black, 1995 Acura Legend L Gold (RIP), 2020 Corolla Hatchback
    Diode Dynamics LED Inerior Lighting https://www.diodedynamics.com/by-vehicle.html?no_cache=1&find=2016-toyota-tacoma-115242 Hella Supertone Horns Some Joe Schmuckitelli Keyless Entry Intermittent Wiper Mod - Thanks to @moe2o4 Cruise Control Mod - Thanks to @moe2o4, again Anytime Back-up and Front Mount Camera Mod - Courtesy of @Logistics91 (amazing customer service helping me get it just the way I wanted it set up) Drawtite Class IV trailer hitch with 7/4 pin connector and P3 Tekonsha Brake Controller RokBlokz Mud Flaps Access Cab Rear Seat Storage Mod - Thanks to @Cagedodger for the original idea. Just modified it to fit my needs. https://www.tacomaworld.com/threads/access-cab-storage-organization.453774/page-4#post-17877877 Method 701 Black Wheels 265-70r17 Nitto Ridge Grapplers Fumoto Drain Valve Weather Tech Floor Liners and Side Window Deflecors Tuxedo TruXport Bed Cover Access Cover Motion LED Light Strip. Mounted 2 in the bed. Air Dam Delete Demello Off-Road Overlander Aluminum Winch Bumper with Baja Hoop and Squadron Sport LED Spots Warn M8000 Winch Silex center console organizer and tray Full Bed and Under Hood LED Lighting A/C Condensation Drain Relocation Rostra Front Heated Seats aFe Power 51-82722 Magnum FORCE Stage-2 Si Pro DRY S Cold Air Intake System (Part #51-82722) Prolightz clear LED fog lights w/ lamin-x overlay Red line Hood struts Diode Dynamics Hi/Low beam HID conversion kit MesoJDM 4 switch cubby panel, 7 switch Center panel and Center console Coin Holder @mesojdm Carhart Gray Front Seat Covers Curtis Class IV receiver B&W Tri-ball hitch King 2.5 Front Coilover/Rear Shock 25001-119/25001-121 Coming Soon: Differential Breather Relocation Mod New tires, can't decide
    Congratulations, you got someone elses return
  7. May 19, 2021 at 10:29 AM
    #4767
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    I was going to order a sticker, but then I read somewhere that you may have to bend the glass just ever so slightly to complete the install. So as much as I would really like to have the sticker, I decided to pass.
  8. May 19, 2021 at 10:30 AM
    #4768
    Mr. Excitement
    J
    Wouldn’t doubt it. At least I can put this chapter of my life behind me. Haha
  9. May 19, 2021 at 10:30 AM
    #4769
    STi and Taco
    Steven
    Georgia
    You can try plugging them into a socket, but you might not like the results
  10. May 19, 2021 at 10:32 AM
    #4770
    STi and Taco
    Steven
    Georgia
    I would put a small mark on the inside and return it. Then we can see who gets it next.
    Pay it forward. Lol
  11. May 19, 2021 at 10:33 AM
    #4771
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    I had received the wrong size clipnut (M6) with my original shipment that took forever to arrive. After informing KTJO of the fact, she sent me an entire new hardware pack. So I have extra collar spacers if you want one for your handle.
  12. May 19, 2021 at 11:10 AM
    #4772
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    I believe the molders just tossed the parts in a box for shipping to the folks what wrap and ship them to KTJO 4x4. That is my guess at the source of the crappy edge finish on the handles. Zero QC or any attempt of feedback in the system.
    It sounds like you need to tweak the upper clip.
    Yeah, the bottom bushing hole is too large on all of them even though it as splines to capture the bushing. Again, zero QC at ever stage of the project.
    tcjacado and Beerpayzdabillz like this.
  13. May 19, 2021 at 11:11 AM
    #4773
    tonered
    tony
    Lynnwood, WA
    Epic!
    :itllbuffout:
    DES2009[QUOTED] likes this.
  14. May 19, 2021 at 11:16 AM
    #4774
    Daria
    Daria Can I pet your dog? Moderator
    Dodging tumbleweeds
    Sticker installation actually requires an entire drawer of Jeremys. Jeremys not included in purchase cost.
  15. May 19, 2021 at 11:17 AM
    #4775
    tonered
    tony
    Lynnwood, WA
    He coached me well on fixing electrical problems.
    And, Dammit! Now, all my poundy things have new names.
    :smash:
    Am I as bad as KTJO 4x4 for stealing @MESO 's shit?
    Devious6 likes this.
  16. May 19, 2021 at 11:33 AM
    #4776
    Devious6
    Mark
    I'm an old Army guy, so they are all just versions of a BFH.
  17. May 19, 2021 at 11:34 AM
    #4777
    tonered
    tony
    Lynnwood, WA
    BFH is a good, but no one knows what I'm talking about when I ask for one.
    Devious6[QUOTED] and Tacodog like this.
  18. May 19, 2021 at 11:38 AM
    #4778
    Mr. Excitement
    J
    Hey, guys. Hey. Ready to talk plate processing and residue transport plate funneling? Why don’t we start with joust jambs? Hey, why not? Plates and jousts? Can we couple them? Hell, yeah, we can. Want to know how? Get this. Proprietary to McMillan. Only us. Ready? We fit Donnely nut spacing grip grids and splay-flexed brace columns against beam-fastened derrick husk nuts and girdle plate Jerries, while plate flex tandems press task apparati of 10 vertipin-plated pan traps at every maiden clamp plate packet. Knuckle couplers plate alternating sprams from the T-Nut to the S. K. N to the chim line.
    Pyrotech likes this.
  19. May 19, 2021 at 11:42 AM
    #4779
    waltuo
    waltuo Well-Known Member
    Toyotas
    Update : my local distributor has not received their 50 orders yet
  20. May 19, 2021 at 11:44 AM
    #4780
    tonered
    tony
    Lynnwood, WA
    Whoa. Actual customers ahead of dealers. Interesting.
    waltuo[QUOTED] likes this.
Thread Status:
