BUYER BEWARE: New 3rd Gen Tacoma Tailgate Opener
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KTJO 4x4, Jun 18, 2019.
Thread Status:
Not open for further replies.
  1. Jun 18, 2019 at 2:02 AM
    KTJO 4x4
    KTJO 4x4 [OP] Well-Known Member
    Katie
    Oregon
    2017 TRD OFF-ROAD 4x4 DCSB BARCELONA RED
    Nitro 4.88 Gears OVTune 1.05 91Oct DirtyDeeds Exhaust
    MODERATOR NOTE: KTJO4X4 has been permanently banned and will not be able to answer your questions or sell her items on TW. Do your research regarding long lead times and lack of customer service.
    Hi Everyone! :wave: Welcome to the Tailgate Opener information and ordering thread. This thread is an extension of the Tailgate Lock & Tailgate Opener thread. I figured since that thread has the list of the Tailgate Lock at the beginning, it would kind of be hard to have another list with it for the Tailgate Opener. Therefore, this thread will have just the order list. I will continue to use the other thread as the main thread with this one as just a thumbnail to that one when needed. I have found a new love for Plug-N-Play Harnesses. They just make your life so much easier when it comes to cleaning up your wiring. It not only makes for a professional installation, it is extremely easy to connect and disconnect whenever necessary.
    TAILGATE OPENER BY KTJO 4x4
    https://youtu.be/Fufsio7Ah2U
    https://youtu.be/ynvzF5nknqM
    PURPOSE:
    The purpose of this Kit is to add a powered opener that can be electronically lowered from your Key Fob, the Tacoma Interior or on the Tacoma Tailgate itself. This is accomplished by adding a second actuator inside the tailgate and using the provided harness to plug into the factory wiring through the passenger door.
    PRODUCT DETAIL:
    There is no need to Splice/Tap into your Trucks OEM Wire Harness. This New Harness is made with all brand new material including OEM Connectors, Terminals, and Wiring to go with your Trucks Wire Harness located on the 3rd Gen Tacoma on the Passenger Side in the Kick Panel Area. The purpose of this harness is to allow you to Open your Tailgate with your Key Fob, from the Tacoma Interior, or on the Tailgate itself. You are still able to use your handle to open your tailgate, but this alleviates the need for your handle and makes it more convenient for your use.
    REQUIREMENTS:
    Due to our second Bolt-N-Open Bracket & Rod, you are not required to drill any holes to mount the Actuator in the Tailgate. This New BNL Bracket & Rod anchors on directly to the Passenger Side OEM Bolts.
    Due to our Plug-N-Play Wiring Harness, you no longer are required to tap into your Lock and Unlock factory Wires. This Kit & Wiring is 100% Plug-N-Play.
    Due to @DSIM Tailgate Opener Module V2, you will be able to press your Key Fob 3 times for the unlock signal to the tailgate and it will open like magic!
    It will also have the optional push button harness, that will allow you to open via a push button switch!
    In order for these features, you are required to purchase his module and harnesses from his site. You can find more information on his thread located HERE
    Getting tired of having to manually drop your tailgate with the handle? Look no further...this module plugs into OEM wiring and with 3 pushes of the unlock signal, the tailgate will open like magic! With the Optional Push Button "B-Harness", it will allow you to open via a Push Button Switch! Because who needs handles anyway?
    This module is a part of this Plug-N-Play Kit and it is offered by another member of this TacomaWorld forum @DSIM. You need this Kit and this Module offered in the link below. The Kit below provides all the Plug-N-Play Wiring for the Actuators and Mounting Brackets for the Actuators that will live inside the Tailgate. There is NO DRILLING
    REQUIRED.
    Please take a look at this Module before you order. You can view this Module HERE
    DSIM TailGate Opener Module
    = Brains of the 3-Click Mod
    KTJO 4x4 TacomaWorld Kit
    = Hardware and OEM Plug-N-Play Wiring.
    This Module is built on a Custom PCB / Arduino Nano platform. The enclosure is 3D printed and there are two connectors/wire harnesses that serve two purposes:
    A-Harness (3x Unlock Functionality):
    Included with the Module connects into your OEM wiring and provides Power, Ground,
    Unlock, and Actuator signals. It hooks directly into the OEM T-Harness for full Plug-N-Play installation.
    B-Harness <Optional> (Push Button Functionality and Interlocks):
    The optional B-Harness will be available in a few weeks and sold separately. With the added B-Harness there are four wires (Push Button In, Push Button Out, Park Signal, and IGN Signal.) With this harness installed it allows for a Push Button to be used that is fully interlocked to prevent unwanted openings of the Tailgate while driving. The interlocks are as follows and when installed are applicable to both the 3x Unlock and Push Button openings:
    • If Ignition is ON and Park is ON, then allow to open.
    • If Ignition is ON and Park is OFF, then DO NOT OPEN.
    • If ignition is OFF, then allow to open.
    LEGAL TERMS, LIMITED WARRANTY, TERMS AND CONDITIONS:
    This thread and kit contains the information necessary for installing and operating your Power Tailgate Opener Complete Full Package with the Plug-N-Play Wiring Harness & Bolt-N-Lock Bracket & Rod & Bolt-N-Open Bracket & Rod. If any questions arise, contact your installation dealer, KTJO 4x4, or DSIM depending on which product.
    This thread and kit is designed for the installer or individual with an existing understanding of automotive electrical systems, along with the ability to test and connect wires for proper operation. To ease installation, we suggest that you READ THIS GUIDE before beginning your installation.
    *CHECK OUT KTJO 4x4 TAILGATE LOCK/UNLOCK W/ KTJO 4x4 & DSIM OPENING MOD INSTALL VIDEO*
    https://youtu.be/6wW2yeSorAI
    *CHECK OUT MY INSTALL GUIDE HERE*
    This thread and kit is provided as a GENERAL GUIDELINE and the information contained herein may differ from your vehicle.
    DISCLAIMER:
    KTJO 4x4 and its vendors shall not be liable for any accident resulting from the use of this product. This system is designed to be professionally installed into a vehicle in which all systems and associated components are in perfect working condition.
    PACKAGES AVAILABLE TO PURCHASE:
    Tailgate Opener Complete Full Package*
    (PNP, Integrated Harness, 2x Actuator, BNL, BNO) - No Drilling
    PRICE: $150 (SHIPPING FEE $13.20)
    Bolt-N-Open Add-On Package
    (PNP, 4-Wire Integrated Harness, Actuator, BNO)
    PRICE: $115 (FREE SHIPPING LOWER 48)
    OEM Bolt-N-Open Add-On Package
    (PNP, 2-Wire Integrated Harness, Actuator, BNO)
    *Tailgate Opener includes both Tailgate Opener and Tailgate Lock Complete Full Packages.
    *Please note: If you want to use your Key Fob for 3-Unlock clicks, you must purchase MODULE from @DSIM
    INDIVIDUAL OPTIONS:
    Tailgate Lock Actuator Single*
    PRICE:
    $6 + SHIPPING
    Tailgate Lock Actuator 2-Pack*
    PRICE:
    $10 + SHIPPING
    *If you would like to order the White tip Opener Actuator, please specify when you place your order. Otherwise, Black tip Lock Actuator will be sent.
    Tailgate Rod, Bolt & Nut
    PRICE: $10 + SHIPPING
    PRICE: $30 (FREE SHIPPING LOWER 48)
    PRICE: $40 (FREE SHIPPING LOWER 48)
    Plug-N-Play Harness Opener
    PRICE: $55 (FREE SHIPPING LOWER 48)
    Integrated Tailgate Harness Opener
    PRICE: $20 (FREE SHIPPING LOWER 48)
    CH4x4 Tailgate Push Button Switch (MOMENTARY)*
    PRICE:
    $24.98 (FREE SHIPPING LOWER 48)
    *Please specify if you want the White or the Blue Momentary LED Push Button
    SHIPPING FEES:
    Priority Mail Medium Flat Rate Shipping USA
    PRICE: $13.20
    Shipping Outside of Lower 48
    PRICE: CALCULATE ON THE WEBSITE
    Priority Mail Shipping CANADA, JAPAN, CHINA
    PRICE: CALCULATE ON WEBSITE
    *PLEASE DO NOT FORGET TO ADD YOUR SHIPPING FEES TO YOUR ORDER*
    I thought it would be nice for those that may be wondering what tools may be needed for this mod or for those that might enjoy following pictures to show some from my install...
    REQUIRED/RECOMMENDED TOOLS:
    • T30 Torx Bit
    • T15 Torx Bit
    • Razor Blade for Black Grommet
    • Flex Seal Style Product for Black Grommet (Optional)
    • Wire Cutters/Crimpers
    • Cable Ties
    I hope you find this thread helpful and useful. I truly feel that everyone needs to be able to lock their tailgate with the push of a button, but also have the capability to open your Tailgate Automatically without the Handle! It’s crazy that it doesn’t come like that. I enjoy being able to help others out with this mod and I will continue to make these as long as there are individuals requesting them. Thank You for your purchase and support with the Plug-N-Play Tailgate Opener. It was a pleasure doing business with you. Enjoy your New Mod! - KTJO 4x4
  2. Jun 18, 2019 at 2:03 AM
    KTJO 4x4
    Katie
    Oregon
    PAYPAL PAYMENT INFORMATION:
    PayPal Email: kjkelley24@hotmail.com
    PayPal Link: PayPal.Me/KTJO4x4 - ORDER NOW!
    Step 1: Sign In
    Step 2: Send & Request Payment
    Step 3: Enter Email Address for Payment
    Step 4: Select your Preferred Payment Option
    Option 1: If you select Sending to a Friend, please make sure to list your Forum Username in the Notes Section and then PM me your Full Name and Shipping Information.
    Option 2: If you select Paying for an Item or Service, please make sure to cover the additional charges that are listed below:
    DC0CE4A7-C210-4E49-AA0F-00AC5456D0CB.jpg AB13FBCA-B18E-4986-B92D-762EE8C4A00E.jpg
    Step 5: Enter your Total Amount and Complete your Payment!
    PLEASE NOTE:
    Your order is only secure once you have completed your payment! Please send me a PM for confirmation that I have received your payment. I need your Full Name and Shipping Information. Once I have received payment, I will add your Forum Username to the Current Order List.
    Thank You for your Purchase! :spending:
    CH4x4 Custom Toyota Small Momentary Tailgate Push Button Switch
    Now available on EBay!
    https://www.ebay.com/itm/383109291264
    FEATURES:
    • The product is manufactured to fit in the OEM space available in your car or truck, simple to install
    • MOMENTARY Push Switch
    • Laser Etched Legend
    • Single upper L.E.D Light
    • Single lower L.E.D Light
    • Upper Light is ON when the Switch is pressed IN
    • Lower Light can be Wired to separate Dash Light Circuit
    • Rated at 3 Amp 12V
    • Wiring diagram supplied with the Switch
    KIT CONTAINS:
    • 1 MOMENTARY Toyota Small Push Switch
    • 1 Connector with Cable for easy installation
    CUSTOMIZATION OPTIONS:
    • If you’d rather a different Word Etched below rather than TAILGATE, contact the seller because that’s an option. Wait time may vary.
    • If you’d rather a different color than BLUE, contact the seller because that’s an option. Wait time may vary
    Inferno__Taco likes this.
  3. Jun 18, 2019 at 2:03 AM
    KTJO 4x4
    Katie
    Oregon
    3RD GEN TOYOTA TACOMA (2016+)
    PLUG-N-PLAY HARNESSES
    IK1
    IC1
    PNP HARNESS - OPENER
  4. Jun 18, 2019 at 2:03 AM
    KTJO 4x4
    Katie
    Oregon
    CURRENT ORDER LIST:
    1. @RyanDCLB - COMPLETE FULL PACKAGE - PAID
  5. Jun 18, 2019 at 2:03 AM
    KTJO 4x4
    Katie
    Oregon
  6. Jun 18, 2019 at 2:21 AM
    KTJO 4x4
    Katie
    Oregon
    TAILGATE OPENER WIRING DIAGRAMS
    Full Kit Integrated with DSIM’s A-Harness:
    Full Kit Integrated with DSIM’s B-Harness:
    DSIM’s B-Harness Routing:
    TAILGATE OPENER INSTALLATION STEP-BY-STEP GUIDE:
    Step 1: With T-Harness UNPLUGGED connect DSIM’s A-Harness to KTJO's T-Harness and Integrated Harness (for the actuator) following the diagram above.
    Step 2: Hook up TailGate Opener module while still UNPLUGGED from the truck. The white connector can only be connected fully one way. If you were to hook it up upside down while still plugged in it is possible to damage the board inside. (The cable will be shipped connected in the correct orientation for reference). It is crucial to make sure DSIM’s A-Harness is not upside down. Please follow the pictures below for reference.
    Step 3: As far as the Module is concerned you are done. The rest is KTJO’s Complete Full Kit for installation of the T-Harness, Integrated Harness, Bracket & Rod, and Actuator. You can find those install instructions with the link listed above in Post #1.
    Step 4: Check that your Radio Settings match the below picture. If they do not match, the module will likely default to the 4x Unlock instead of 3x.
    Step 5: TEST
    Installation of this TAILGATE OPENER COMPLETE FULL PACKAGE is now complete. It is very straightforward. However, if any issues arise during installation of the Tailgate Opener Module, please refer to the Trouble-Shooting information below. If you try the steps below and still have issues please contact DSIM at dsim.solutions@gmail.com OR shoot me a PM. If you have any issues during installation of the Tailgate Opener T-Harness, Integrated Harness, Bracket & Rod, or Actuator, please contact me at KTJO4X4@outlook.com OR shoot me a PM.
    Trouble-Shooting:
    Step 1: Pop open the enclosure. Check and make sure there is a red led on indicating that the arduino board is on.
    LED is ON.
    GOOD. Continue To Step 2.
    LED NOT ON
    BAD. Continue To Step 2 to try a reset.
    Step 2: Unplug A-Harness. Led should turnoff.
    LED should be off in ALL Scenarios.
    Step 3: Plug it back in to reset the module. Led should be on.
    Red LED is ON
    GOOD. Continue To Step 4.
    LED NOT ON
    Power Issue. Check red and black wires on the A-Harness, and where the connections are to the T-Harness. Follow the Diagram in Post #2.
    Step 4: Press unlock 4 times. There should be another led on the arduino that should blink with each unlock press (TX LED). After the TX blinks 3 times you should audibly hear the relay on the board "Click".
    TX LED only Blinked 3 Times on 4 unlock presses.
    Radio Settings. Check to make sure your radio setting match post #2. Else you will need to hit unlock 4 times to activate the tailgate opening event.
    TX LED Blinked 4 Times on 4 unlock presses.
    GOOD. Your Radio Settings are configured for 3xTailgate Open
    The TX LED did not blink at all
    GOOD. Your Radio Settings are configured for 3x Tailgate Open
    The TX LED blinked, but the Relay DID NOT CLICK
    BAD. Restart at Step 1 and try again. If this does not work after another reset then its possible the arduino output pin was shorted during installation. You will need a replacement arduino (Contact dsim.solutions@gmail.com or PM DSIM here on TW)
    The TX LED blinked, the Relay Clicked, but the actuator did not move.
    At this point the module is doing what it should be doing. Check actuator wires to make sure they are properly connected. Power is being sent from the Module but its not making it to the actuator or the actuator is not grounded.
    The TX LED blinked, the Relay Clicked, Actuator Moved, but TailGate did not drop
    *Adjustment instructions are under construction, pics and better verbage to come but heres the basics. Minor adjustments may need to be made to the latch on the bed side. The latch on the bed side is setup on a slotted hole, try loosening and adjusting the latch and retightening. You can also try removing the rubber stops. If you remove the rubber stops and that works then try shaving 1/8" off of the rubber stops.
    Inferno__Taco and ponts like this.
  7. Jun 18, 2019 at 2:38 AM
    ShadyCoh
    ShadyCoh Well-Known Member
    Burnet, Tx
    Payment sent for full package
    KTJO 4x4[OP] likes this.
  8. Jun 18, 2019 at 2:59 AM
    bonifacio
    bonifacio Well-Known Member
    Central PA
    2019 Cement Gray Tacoma OR 4x4
    So if I have your Pop N Lock what do I need with the ship in conversion? Just a lot of Pop Lock Open Bolt going on.
    Bolt-N-Lock Bracket & Rod Opener
    PRICE: $40
    PRICE: $20
    PRICE: $12.80
    +$15 conversion?
    Take my money!
  9. Jun 18, 2019 at 3:25 AM
    KTJO 4x4
    Katie
    Oregon
    @ShadyCoh - Received your payment :thumbsup: I will take a look at it, but since your already purchased the Tailgate Lock Complete Full Package, you actually only need some of the items. The one item that is up to you that you will need to decide on is the Integrated Harness. For $20 you can get the New one or you can route two new additional wires yourself. That’s totally up to you and your skills. Just let me know on that one. Other than that, I’ll PM you separately and then send you a refund of the difference. Appreciate your purchase. You will love the fact you waited. Remember, you have one more piece from @DSIM to pick up when he completes it. I think he mentioned he’s a week to two weeks out :bananadance:
    @bonifacio - So if I have your Pop N Lock what do I need with the ship in conversion? Just a lot of Pop Lock Open Bolt going on.
    PRICE: $40 YES
    PRICE: $20 YES, UNLESS YOU’D RATHER RUN YOUR OWN WIRING. FOR $20 I DEFINITELY THINK ITS WORTH GETTING THOUGH.
    PRICE: $12.80 YES
    +$15 conversion? & YES UNLESS YOU’D LIKE ME TO SEND THEM TO YOU TO DO
    DONT FORGET THE ACTUATOR :)
    Take my money! :spending:
    ponts likes this.
  10. Jun 18, 2019 at 3:43 AM
    bonifacio
    Central PA
    Payment sent for existing BNL Opener!
    PRICE: $40
    PRICE: $20
    PRICE: $12.80
    Conversion of PnP Lock Harness to PnP Lock/Opener Harness
    PRICE: $15
    $87.80 total to upgrade from previous BNL PnP Lock Harness to Full Package.
  11. Jun 18, 2019 at 5:27 AM
    Rob Daman
    Rob Daman The Taco Formerly Known as Hard Shell Taco
    Rob
    So Cal
    17 OR 6MT
    a lot
    #fancy :thumbsup:
    Jessrin and KTJO 4x4[OP] like this.
  12. Jun 18, 2019 at 5:42 AM
    dlovell90
    dlovell90 New build 5/1/19
    Derrick
    Waukee, IA
    2016 Tacoma TRD Off Road
    Billie 5100s OME 888s Fallen Wildpeaks Mamba m25s Lots of cosmetics MESO everything
    Following until I can read More into this
  13. Jun 18, 2019 at 6:00 AM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    I'm confused on exactly what those of us who have previously purchased your complete full package for the tailgate lock need to purchase in order to add the tailgate opener feature.
    I know you're busy with fulfilling orders for your other products, but if it's possible to provide more detail outlining what each individual option does it'd be greatly appreciated :thumbsup:
    Xx_Evilvirus_xX and KTJO 4x4[OP] like this.
  14. Jun 18, 2019 at 6:14 AM
    Rainoffire
    Rainoffire Well-Known Member
    2017 QS DCLB TRD Sport
    Very interested.
    I have a Pop-N-Lock (Non-KTJO version) and purchased your harness so I wouldn't have to tap into the wires.
    What would be needed to get the tailgate opener to work?
    Guessing just the full kit?
  15. Jun 18, 2019 at 6:23 AM
    KTJO 4x4
    Katie
    Oregon
    I most definitely can but to keep it short. The easiest way to look at is, everything that I have on here is needed to operate the Tailgate Opener. If you do not have my Tailgate Lock, then you need my Complete Full Package. If you have my Tailgate Lock, well take everything that comes in that Kit and subtract what comes with it: BNL - Lock, Actuator, Integrated Harness (But this one doesn’t matter because the Opener uses a different one), and PNP Harness Lock.
    The Opener has the New BNL - Opener, the second Actuator, Integrated Harness w/ 4 Wires, and then it just uses the PNP Harness Lock and adjusts it to make it the PNP Harness Opener. Since you already have those other items, you save money because you do not have to purchase them.
    I will add some more detail today when I can. That’s a great point. Thank You!
    PcBuilder14[QUOTED] likes this.
  16. Jun 18, 2019 at 6:24 AM
    SLICKYINC
    SLICKYINC Well-Known Member
    West Tennessee
    2017 QUICKSAND TRDOR LB
    If we don't have Pop-N-Lock. Will this kit include that plus the Tailgate opener?
    OnlyTaco and KTJO 4x4[OP] like this.
  17. Jun 18, 2019 at 6:26 AM
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    Reserved. I’m interested.
    Have the original locking tailgate from you. Good mod.
  18. Jun 18, 2019 at 6:32 AM
    dead.fm13
    dead.fm13 Well-Known Member
    Chesapeake, VA
    2017 Tacoma TRD Sport
    5100/888's front, JBA UCA's, 5160's/Dakar's rear, Ray 10 MDB 17", 285/70/17 Ridge Grapplers, Hondo Garage Radio Knobs, MESOJDM Ultimate Turn Signals, MESOJDM Ultimate Combo Maps/Dome, MESO Total Tail Stage II, MESO Puddles
    Also interested in the additional items to make this work being that I already have a full Tail Gate locking kit from you.
  19. Jun 18, 2019 at 6:32 AM
    Rainoffire
    @KTJO 4x4 liked my post, so the full kit it is.
    Money sent.
  20. Jun 18, 2019 at 6:48 AM
    ra29dreams
    ra29dreams Well-Known Member
    Jacksonville, FL
    2017 Tacoma TRD Off-Road
    I'm sorry if this is covered. I've read and am still not sure.
    I don't have any of your previous products, been waiting to pull the trigger on this. If I purchase the complete kit above (FULL PACKAGE FOR $150) does that give me the opener AND locking feature? What do I need to be able to LOCK and OPEN the tailgate as shown? Thanks for these AWESOME products!!!!
Thread Status:
