Buying 2019 OR tomorrow - Factory Tonneau or Aftermarket?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Soundchasr, Sep 2, 2019.
  1. Sep 2, 2019 at 8:02 PM
    #41
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Bakflip MX4 here. Love the flush look and matches nicely with box sides as mentioned. Easy to install and remove if you need full box access.
    Soundchasr[OP] likes this.
  2. Sep 2, 2019 at 8:06 PM
    #42
    St0rm-Tr00per
    St0rm-Tr00per Well-Known Member
    SoCal
    2018 TRD OR 4X4 DCLB - Super White
    “Semi-Pro”/“PrOff-Road”
    Thanks!
  3. Sep 2, 2019 at 8:17 PM
    #43
    Hellapeno
    Hellapeno Well-Known Member
    Austin
    2016 TRDOR
    Choice Goodies
    Aftermarket for sure
    EDIT: if the truck doesn’t have one, great. don’t buy OEM, especially from the dealer.
    If the truck has a tonneau, tell them to find you one without it, or get them to remove it and reduce the MSRP accordingly. What I did whit multiple things on my truck. You don’t have to buy any options Ever..., floor mats, side steps, tonneau, or any other toyota or dealer add on.
    Tonneau covers are handy, but I wouldn’t pay the 699? That the dealer is charging when you can source a gently used backflip or equivalent for much less.
  4. Sep 2, 2019 at 8:35 PM
    #44
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    I have the OEM on my '18 TRD Sport and am pleased with it. A little water gets in during hard rain, but I have water-tight boxes underneath so no problem.
    TimC, iamjase and Soundchasr[OP] like this.
  5. Sep 2, 2019 at 8:36 PM
    #45
    TacoMamba35
    TacoMamba35 Well-Known Member
    PNW
    2021 Tacoma TRD OR DCSB 3.5
    I have the SB tonneau. Some people criticize it, but I think it's great. Solid quality, and does exactly what it is supposed to do. But...(see below)
    ^^ Definitely try for this. And...(more below)
    If the previous strategy isn't gonna work, then aftermarket will be best.
  6. Sep 2, 2019 at 10:40 PM
    #46
    deusxanime
    deusxanime Well-Known Member
    MN
    2020 Cement OR DCSB V6 6MT 4x4 Prem+AdvTech+LED
    Yeah I have the OEM tonneau and those pins are annoying. Catch things on them and about 1mm away from scratching my wheels if I throw the tires in the back upright. Hoping to upgrade to a 2020 and will not be getting it this time. Going aftermarket tonneau or might even go with topper instead.
    $650 from the factory, so not far off.
  7. Sep 2, 2019 at 11:09 PM
    #47
    Boosted_Carrera
    Boosted_Carrera Well-Known Member
    Hawaii
    2018 TRD SPORT, 1996 911 Turbo
    If you're a bit OCD , you won't like the OEM cover. It doesn't stay flushed. The ones I have seen on trucks looked a bit warped . One reason I've opted out of it. Before truck purchase, one of most important is a tonneau but, a good one to know once locked it's safe. It took about 2 months of searching , going shops and settling on the LEER HF350M. I have not seen any Tacoma with this particular cover yet than mine. Importatnt piece of this particular cover is it doesn't have a strap going across the release clip. A simple wire fished in between the tailgate and cover will unlock it. Pretty stupid design.
    The LEER is a HD latch you need to press with 2 fingers to release, but easy. All 3 panels have it's own latch. When you close it, each lock has a loud *POP* ..*POP*.. Very easy to remove whole panel if need to. The mounting clamps are real easy as well. All you need is a 12mm socket. **NO CUTTING ANYWHERE ** . I've gone through pouring rain and wash the truck once a week. If any, a few drops in the bed another important factor. This cover sits about 1/4 *ABOVE* the bed and has rubber seal that keeps water out. Most ones I looked at sits below the bed rail which contributes to water leak. I love this frickin cover. This cover is designed how I would've done it. Installer told me use 303 Protectant once a month on bed panels and rubber seals to keep it pliable.
  8. Sep 3, 2019 at 8:38 AM
    #48
    xerogs1
    xerogs1 Well-Known Member
    New Mexico
    2019 TRD OR DCSB AT Silver Sky Metallic
    Bartact Seat Covers, Cali Raised LED molle bed system, radio knobs and Subaru Tweeters, OCD interior parts, OEM Exhaust tip, dash cam, hood protector, various theft deterrent items. Still a WIP
    I don't mind the OEM tonneau cover but it came pre-installed on the truck when I purchased it. If it didn't already have it I would have purchased an after market option. The OEM is sturdy and I haven't noticed any leaks but you have to make sure you press down on it on the panel edges for it to latch well, there is an audible click. It seems easy enough to remove although it is somewhat awkward for one person but not a huge deal. 303 Aerospace Protectant has kept it looking brand new even sitting out in the Southwest sun for extended periods. Just make sure to haggle with the dealer on the price if it is pre-installed.
    Soundchasr[OP] and ICU1 like this.
  9. Sep 3, 2019 at 9:00 AM
    #49
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    I'll throw in a vote for an aftermarket, but it all depends on what you wants to spend. The Toyota cover isn't very expensive and is functional for most folks' needs. I have the Truck Covers USA rolling tonneau. They will set you back almost as much as a cap, but what you get is fully lockable, water resistant, retractable cover that's solid as they come. I have mine with yakima rails pre-welded and I have a set of bars mounted to the top. I can easily access everything in the bed and lock it out of sight all while keeping the space above the bed to tie down bikes, boats, paddles, etc., with easy access vs. having to load as much on my roof.
    May be more than you're looking to spend, but I've had mine on for 3 years and its as solid as the day I installed it.
    https://www.truckcoversusa.com/american-rack-system/
  10. Sep 3, 2019 at 9:31 AM
    #50
    deusxanime
    MN
    How much did it set you back? I'm thinking about something similar vs. getting a topper. I was looking at the retractable RetraxPro XR with the Yakima rails as well, which is going for just over $1700 on Amazon as of now. The toppers I'm looking at (Leer or ARE) are probably closer to $3000 fully kitted out. I prefer the look of a tonneau, but debating if I need the extra storage space and height or not that comes with a topper. With a couple kids, I can't put much in the cab on trips and the bed with tonneau can get full and be restrictive.
  11. Sep 3, 2019 at 9:33 AM
    #51
    bshammer0
    Brandon
    Nashville, TN
    Yeah, it's a hard decision for sure. Mine set me back right at $2k including the yakima hardware/rails/bars and it is a tough balance at times. I still prefer a tonneau overall, but when we take trips with my daughter it can get a bit tetris-like in the bed, but at the end of the day I gain easy access to things mounted on my bed so it works out. I can't imagine a better retractable cover though. Perfect design imho
    deusxanime[QUOTED] likes this.
  12. Sep 3, 2019 at 9:43 AM
    #52
    deusxanime
    MN
    If that included the bars as well in the price, then that seems like a good comparable price. Good to have an alternative to the Retrax though, didn't know there was another with the same features.
  13. Sep 3, 2019 at 9:54 AM
    #53
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    I have the factory cover, but loved the truxedo lo pro lq better.
  14. Sep 3, 2019 at 10:02 AM
    #54
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    I have a Truxedo Truxport and i like it alot. I wanted the rails ontop of the bed instead of making the bed more narrow. If i haul anything heavy and it shifts against the rail it wont damage it nearly as much as the low pro style.
  15. Sep 5, 2019 at 2:28 PM
    #55
    Soundchasr
    Soundchasr [OP] Well-Known Member
    2020 Tacoma Sport MGM DC LB
    I was thinking the Bak MX4 but the Bak rep recommended the F1 and Fibermaxx because she says the MX4 will dent easier and wouldn't be as good in the cold weather (Pittsburgh, PA). Anyone have experience with MX4 denting or problems in the cold?
  16. Sep 5, 2019 at 2:32 PM
    #56
    Kwisak
    Kwisak Well-Known Member
    Jon
    Arizona
    2024 Tundra Limited off-road 2018 Inferno Tacoma Off Road MT
    Pro grill Joying radio with wireless car play Hood decal Bed decal Pro skid Pro wheels 285/70/17 Sliders Blackout emblems Pro exhaust Pro intake Painted engine cover Ditch lights Tint Tacoma letters glove box Off-road wether tech inserts Lock box console Blackvue Orange trim Orange inserts Katzskin Weather tech Bed mat Hilift Tire locks Extra switch Rotopax Fox 2.5 fronts with 700lbs Kings Fox 2.0 rears with resi Icon rxt springs Icon Delta UCAs Meso side markers Meso gashole On order —— Avid bed rack SSO bumper Morimoto headlights and fogs Meso map lights and done light
    Aftermarket, don’t have to cut rails
  17. Sep 5, 2019 at 2:50 PM
    #57
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    I have the MX4, had it for a year and a half. Had a half a foot of snow on it last winter. Below freezing for a while. My 5 year old daughter loves climbing up on it. I regularly put stuff up on it. I do have a scratch on it but no dents and no issues in the cold. I am happy with my decision.
  18. Sep 7, 2019 at 6:45 AM
    #58
    Eddie1958
    Eddie1958 Well-Known Member
    ED
    I have the Bakflip MX4 and live in Pennsylvania. Went two winters so far. The problem in the winter would be ice buildup. I would not open it unless I removed the ice or snow. I did manage a very small scratch on the top by some wrenches I had sitting on it. Only complaints I have are this some of the rivers that hold the openers have some rust on them some did not. The fastener that you use when the cover is open and laying on the bed fell off. I just got a little bigger screw and some thread locker on them. You will also want to put some thread locker on you prop poles. As they vibrate off and fall in the bed.
    Keep 303 dressing on it and I figure it will life the last of the truck. Dents may come but its not like it is on your body panels and would stick out. I would buy again in fact if I were to get a newer model I would order it with out oem cover. Then you will not have to look at the holes some one cuts in your bed rail caps.
  19. Sep 7, 2019 at 6:51 AM
    #59
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Probably too late, but don't be shy to ask for free items thrown in after you negotiate the price. Don't be afraid to walk away!!!
    I got the following:
    Winter tires/rims
    OEM soft top Tri-Fold Tonneau cover
    rubber Tub Mats
    Pro Grill
    A good price on your trade in
    *** Don't be afraid to walk away ( I said it again). Try another dealership....
  20. Sep 7, 2019 at 7:13 AM
    #60
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    OP pics of the truck???
