Buying a 17 ft travel trailer for my truck. any advice
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JUJtacoma2010, Mar 19, 2012.
  1. Mar 19, 2012 at 2:49 PM
    JUJtacoma2010
    JUJtacoma2010 [OP] Well-Known Member
    Fresno
    Tacoma 2010 Dbl Cab. OFF Road Package
    I am buying a small travel trailer. This is my first one. This is the only forum I trust and so please by brother and sisters, give me some advice on that to look for when I buy this trailer. What paper work should I get from the owner. do I need a sway bar?
    Appreciated all you guys help.
  2. Mar 19, 2012 at 5:15 PM
    stangkeip10
    stangkeip10 Well-Known Member
    Cincinnati
    '10 Magnet Gray 4x4 Access Cab SR5
    BHLM, Black OR TRD wheels, BFG Mud terrains, yellow wire mod, 5100s @ 2.5, toytec tsb aal
    do you have any info on the camper? weight specifically? you're going to want a weight distribution hitch as well so keep that in mind.
  3. Mar 19, 2012 at 5:40 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    I tow a 18' camper it has duel axles with out a WD hitch but if some one gave me one I would use it. It does help with the "bucking bronco" effect on a rough road. They make aftermarket rear sway bar kits but I really don't think you need one. Mine loaded is around 3000#. The paper works is different from state to state so give your DMV a call or a trailer dealer. A bill of sale and a title would be a start usually the trailer is covered by your truck insurance coverage but that is some thing you'll have to check.
  4. Mar 21, 2012 at 2:00 AM
    tractng
    tractng Well-Known Member
    Please update this post as I am doing the same research. I am looking for a small one too :). I can see myself taking the wife & son to a beach and park there a night or two a month.
  5. Mar 21, 2012 at 5:25 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
  6. Mar 21, 2012 at 8:47 AM
    tractng
  7. Mar 21, 2012 at 9:02 AM
    gt40
    gt40 Well-Known Member
    Georgia
    11 SR5 4X4 SB TOW PKG.
    A little advice if you buy a used trailer. Check out with the DMV to make sure that it does not have any money owed on it. If the owner does owe money on it make sure his note is paid off. If you pay him and he does not pay off the note they will come after the trailer which is you.
    This is one that I am planning on buying. Very easy to set up and should be good for 4 people. A little tight, but is much easier than a pop up.
    Check out the video and click on full screen.
    http://www.pecocamping.com/2012-forest-river-flagstaff-classic-12-rb-new-popup-ga-i227438
  8. Mar 23, 2012 at 8:11 AM
    JUJtacoma2010
    Fresno
    I like that. looks nice, not too big and easy to setup. thanks for the advice on checking on with the dmv. I didnt know I had to do that. I always thought that if they had the pink slip for the trailer that I should be good to go.
  9. Mar 23, 2012 at 1:50 PM
    badger
    badger Well-Known Member
    07 SR5
    Mine is a 16 ft Scamp that weighs about 2500# loaded. I've towed it all over the western states on all kinds of roads. No WD hitch, and no problems. I like it because it is light weight, aerodynamic, and tows so easily. Leacks are almost a non-issue. It uses a single torsion axle. I highly prefer the torsion axle over a leaf spring. There are lots of good trailers though, so it just depends on what you want, and your intended use.
