Buying a 1990 with 400k miles?
Discussion in 'Hilux' started by Coconuts, Apr 13, 2020.
  1. Apr 13, 2020 at 6:19 PM
    Coconuts
    Coconuts [OP] New Member
    Hi Folks,
    I'm considering buying a 1990 Toyota Pickup with around 400k miles on it (the engine was rebuilt 200k miles ago). The most recent owner seems to have taken good care of the truck and has replaced a lot of components (listed below). I would love to know your thoughts on what I should look our for and what major issues or required maintenance I could likely expect over the next 50k miles.
    I'd be doing around 10k miles per year (mainly for baja/desert camping trips).
    Thanks a lot for your help!
    Here are the details from the seller:
    1990 Toyota Pickup SR5 V6 5-Speed Manual Transmission
    4WD
    Original engine had 200k on it
    Rebuilt Engine has 200k (it is a 3VZE out of a 1992 4Runner)
    All new leaf springs
    Marlin crawler short shift kit
    New OEM clutch bracket installed
    Only rust is on windshield area from a previous botched replacement.
    No leaks. Doesn't Burn Oil. 16-18 average MPG
    Within the last 30k miles:
    • Timing Belt/Tensioner/Main Pulley Bearing
    • Alternator Belt
    • Power Steering Belt
    • Water Pump
    • Radiator
    • Thermostat
    • Coolant Flush
    • Clutch Master Cylinder
    • Clutch Slave
    • Center Link
    • Tie Rods
    • Lower Ball Joints
    • 32 X 11.5 X 15 BFG All Terrains with Cross Drilled and Slotted Rotors with Toyota Brake pads in Front with plenty of life
    • Valve Cover Gaskets
    • Valve Adjustment Done with only two shims used so the valve seals are still in great shape
    • Aftermarket Aisin Manual Locking Hubs that spin freely
    • Front Diff from a Newer T100
    • Front Sway Bar from a Newer T100
    • Bilstein Shocks All Around
    • Marlin Crawl Built Transfer Case
    • Aftermarket Intake
    • Aftermarket Power steering Pulley and Reservoir
    • Flowmaster Exhaust That Dumps after Cab
    • Clutch
    • Spark Plugs Wires and Dist. Cap
    • Transmission Fluid changed with Redline GL4 MT90
    • Rear Diff Front Diff and Transfer case all used Motul 80W90 Gear Oil
  2. Apr 13, 2020 at 6:24 PM
    Pickeledpigsfeet
    Pickeledpigsfeet Well-Known Member
    Foothills, CA
    It has one of the worst motors toyota ever designed in it, 3.slow. I have owned 4, and they had issues with headgaskets, heads, exhaust manifold leaks, Oil pan leaks, stupid vaccum ADD, leaky injectors, broken injector plugs, front and rear main seals and everyone leaked at the PS pump.
    Only thing going for it is that it is a manual.
    It looks like a lot of the failure prone stuff has been replaced, but I would only buy it if it was cheap and I was going to throw a 3.4 in it.
    Coconuts[OP] likes this.
  3. Apr 15, 2020 at 3:54 PM
    Coconuts
    Thanks for your advice. You think I'm likely to have a lot of problems with 3VZE even though it has been rebuilt (e.g., the head gasket has been replaced)? The seller is asking $4,500. Sounds reasonable to you?
  4. Apr 15, 2020 at 3:59 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Thats a hard pass for me. The 3.slow was a horrible engine as stated above.
    Save that money. For not much more you can find something way newer with a reliable engine.
    Regardless of how much was rebuilt on the truck.
  5. Apr 15, 2020 at 4:08 PM
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    4500? He gotta be joking
  6. Apr 15, 2020 at 4:13 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    The rubber parts are 20 years old. Door seals etc. Were the hoses replaced, including the run to heater core in the cab? Does the AC work?
