Buying a 1st gen Tacoma with squealing belt
Discussion in 'New Members' started by Que, Jun 30, 2016.
  1. Jun 30, 2016 at 7:20 PM
    Que
    Que [OP] Member
    Scott
    Searching
    Hey y'all, long time reader here, but never owned a Tacoma.
    I found a first gen Tacoma I'm looking to buy. But, its in another city. I'm being told that there's a squealing sound (belt?) when first starting the truck. It goes away after a bit. Also, it only happens when starting truck with the a/c on.
    Can anyone diagnose from afar? Alternator Belt? Any other possibilities?
    Any help would be greatly appreciated. Thanks.
  2. Jun 30, 2016 at 7:22 PM
    Burnett
    Burnett Well-Known Member
    Nolan
    North Georgia
    98' Xtra cab v6 4x4 evergreen pearl
    Bilsteins 5100's & 5125's, OME Dakar leafs Custom toolbox Custom bedstep/towhook/reverse light combo Custom Bedrack
    Accessory belt needs tightened. Probably time to replace it.
  3. Jun 30, 2016 at 7:23 PM
    Que
    Que [OP] Member
    Scott
    Searching
    Thanks
  4. Jun 30, 2016 at 7:26 PM
    Bishop84
    Bishop84 Well-Known Member
    There's 3 accessory belts (a/c p/s and alt)with a cam timing belt. I usually suggest changing them all in one shot. The AC belt may be the culprit but any loose/worn belt can cause noise under varying load.
    Use a flash light and look for cracks and weathering on the belts. They may be ok and just need readjustment. The timing belt is difficult to inspect and usually relies on the previous owner supplying service history.
  5. Jun 30, 2016 at 8:21 PM
    Que
    Que [OP] Member
    Scott
    Searching
    Thanks Bishop. Think I'm going to try to get them to replace all 3 for the hell of it.
    DustStorm4x4 likes this.
