Buying a 2005 Tacoma with Front End 2012 Conversion
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaNerd, Oct 22, 2015.
  1. Oct 22, 2015 at 2:03 PM
    TacomaNerd
    TacomaNerd [OP] Member
    Las Vegas, NV
    Tacoma 3RZ-FE 2.7 L
    Hi guys,
    I don't know much about Tacoma, but there is a guy locally looking to sell his 2005 Tacoma Prerunner. He's change the front end to a 2012 which i like, and also did a CST 4" lift spindles. Any issues or concerns I should worry about or look into?
    He's asking $15K with 90K miles.
    Thanks.
  2. Oct 22, 2015 at 2:04 PM
    1MK
    1MK Desert Explorer
    Southern California
    Make sure the reason it's been converted isn't because it's a salvage title.
    Other then that, just make sure the work done looks clean and professional.
    Gwarden, G.T. and 12TRDTacoma like this.
  3. Oct 22, 2015 at 2:05 PM
    Large
    Large Red
    Look for leaks, look at the ball joints, make sure the truck runs good and there is minimal rust on the frame
  4. Oct 22, 2015 at 2:06 PM
    1MK
    1MK Desert Explorer
    Southern California
    Would also HIGHLY suggest taking it to a shop for a complete inspection prior to purchasing. Most sellers are more then happy to allow you to bring it to your mechanic to ensure everything checks out ok.
  5. Oct 22, 2015 at 2:10 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Heres a couple spots to check:
    roll under the truck, see if you can slip your hand in between the steering rack and the engine...of its tight at all, there is frame damage.
    Check all the body panels in the engine bay and up in the wheel well, if there are any ripples or anything looks slightly warped, there was an impact.
    Check the gap between the bed and the cab on both sides, simple as putting your fingers in on one side and seeing if its the same on the other.
    Check under the front bumper, up inside, make sure all bolts and nuts and fasteners are there, if you really want to go crazy, pull some of the fasteners off so you can see up under the fender liners and such, they can hide alot.
  6. Oct 22, 2015 at 5:27 PM
    TacomaNerd
    Las Vegas, NV
    Tacoma 3RZ-FE 2.7 L
    Thanks guys!
    I will keep all those in mind when I check out the truck.
    I did run an AutoCheck and it says "1 Accident record(s) reported through accident data sources".
    Anyway I can get the details on that accident?
  7. Oct 22, 2015 at 6:51 PM
    kubatcha
    kubatcha Well-Known Member
    Get a CarFax.
  8. Oct 22, 2015 at 7:04 PM
    FATaco
    FATaco Meh
    Friends call me Ginger
    Fairbanks
    07' TRD DCSB
    Dakars w/AAL, OME/886's, All Pro Front Bumper, Rear bumper, IFS skid, and UCA's. Superwinch Tigershark. Magnaflow muffler... vrooom
    Lol...Carfax. Autocheck is far superior.
  9. Oct 22, 2015 at 7:48 PM
    VolcomTacoma
    Jeff
    NorCal
    Get both. And do a THOROUGH inspection on that thing. AND THEN take it to a mechanic to do another inspection. I'd almost walk at the accident notification, but I know insurance companies will put an "accident" flag on your truck in a fender bender
  10. Oct 22, 2015 at 7:56 PM
    VolcomTacoma
    Jeff
    NorCal
    Yea, 2WD's are worthless...
  11. Oct 22, 2015 at 7:56 PM
    DylansBase
    DylansBase Well-Known Member
    Dylan
    Murfreesboro TN
    2007 DCSB Taco TRD Off-road
    Bilstein 5100 w/OME 886 All pro expo leafs w/icon 2.0 Relentless Fab plate bumper BFG KO2
    Ask if he had it done at a shop. My brother in law did that clip conversion and no matter what we did it wouldn't line up right. But if it looks good go for it. X2 on the salvage title. People think that it's different so it will be more desirable and sell easier even if it has a salvage title
  12. Oct 22, 2015 at 7:59 PM
    DylansBase
    Dylan
    Murfreesboro TN
    2005 with 90k? Not to be negative Nancy but 15k seems kinda cheap for the mileage unless it holds salvage title. Well atleast where I'm located. There's 2nd gens with 120k still going for 18k-20k. Granted they're 4x4 though.
  13. Oct 22, 2015 at 8:01 PM
    DylansBase
    Dylan
    Murfreesboro TN
    4x4. Zoom in and you can see the front CV axle shaft
  14. Oct 22, 2015 at 8:05 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    jlastic, ChamYota, 1MK and 1 other person like this.
  15. Oct 22, 2015 at 8:06 PM
    DylansBase
    Dylan
    Murfreesboro TN
    Damnit! Welp time for glasses:anonymous:
    nelson18matt likes this.
  16. Oct 22, 2015 at 8:12 PM
    VolcomTacoma
    Jeff
    NorCal
    Congrats, Jordan has an awesome truck, learn to TW.
    And it's definitely a 2WD
    Bam.
  17. Oct 22, 2015 at 8:51 PM
    Blue_DMZ_Tacoma
    Blue_DMZ_Tacoma Well-Known Member
    Chaz
    Irvine, CA
    Blue DMZ Tacoma
    2006 Speedway Blue Tacoma AC TRD Prerunner Total Chaos LT Fox Coilovers Fox Bypasses King 500 DMZ Bedcage DMZ Deavers Fox 3.0 Triple Bypasses Total Chaos Spindles Glassworks Fenders DMZ Custom Bumper With 4 Vision X HID's 16" MT Classic Blue Locks 315/75/16 BFG All Terrains DMZ FAB 4.88 Gears TC Heimed Uppers
    Hahahahaha what's the point of buying a 4x4 and never use it? 95% of people who buy 4x4s
    ChamYota, 1MK and nelson18matt like this.
  18. Oct 23, 2015 at 8:25 AM
    TacoTaco15
    TacoTaco15 Well-Known Member
    Jake
    VA
    2015 MGM DCSB PreRunner 2.7
    If I were a betting man, I'd say it's salvage. If it's not currently salvage, check and see if the title was transferred in from another state at any point - sometimes guys will do that to trick one state's DMV into giving them a normal title.
    X2 on taking it to a mechanic - any reputable mechanic will look it over for you - they may charge a few dollars possibly, but small beans to a $15k purchase. If the seller even hesitates a little, I'd walk away.
  19. Oct 23, 2015 at 11:20 PM
    TacomaNerd
    Las Vegas, NV
    Tacoma 3RZ-FE 2.7 L
    Thanks for all the feedback guys, I decide not to purchase the Tacoma.
    Here's the ad if you're wondering: http://orangecounty.craigslist.org/cto/5279356614.html
    and here is the auto check: http://davis-moore.com/autocheck/vin:5TEJU62N15Z078749
    The part that concerns me the most is the accident in 2009, then all of the sudden it went off the grid until 2015. Most vehicles will have some sort of REGISTRATION EVENT/RENEWAL every year, so because this truck didn't I assume it was damaged and sitting in someone's garage as a fixer upper. Also, the 1st owner is from Cali, and the 2nd owner is also lives in Cali, but got a AZ title? The guy said he has a house there and save money on registration / insurance?
    I dunno, but too fishy for me, so I passed.
    G.T. likes this.
  20. Oct 23, 2015 at 11:24 PM
    TacoTaco15
    Jake
    VA
    Good decision, brother. Again, from my post earlier, I'd be willing to bet money that he switched the title over to Arizona to 'scrub' the salvage title. I call BS there.
    Again, wise decision. You'll find your great truck, no worries.
