Buying a new trailer. understanding weight distribution hitches and if I need one?
Discussion in 'Towing' started by vtwinjunkie, Feb 15, 2022.
  1. Feb 17, 2022 at 7:10 AM
    wtjl240
    wtjl240 Well-Known Member
    Jeff
    Spring Hill, TN
    It's best if it's matched towards what you need but you can use a higher rated one. I bought the Fastway E2 rated for 1,000 lbs tounge weight and I have a porpoising trailer over large dips/bumps on the interstate. However, I bought this one because we're looking at larger trailers for the future. It'll be fine, just bumpy before it smoothes out.
    Our current camper is a 2020 Starcraft 212FB with a tounge weight of 425 lbs but we're looking at heavier campers in the 600-800 lbs tounge weight range and the Fastway E2 I bought says it's best suited for 600-1,000 lbs tounge weights
  2. Feb 21, 2022 at 1:54 PM
    AZ Pete
    AZ Pete Well-Known Member
    Arizona
    deleted by AZ Pete
  3. Feb 21, 2022 at 2:02 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    You don't need a WDH for that trailer. A friction sway control bar would be a necessity though.
    Reese Friction Sway Control (towuniverse.com)
    Your tongue weight will be closer to 500 lbs though. I don't know where they got 231 lbs from
    vtwinjunkie[OP] likes this.
  4. Feb 22, 2022 at 6:31 PM
    Aquatic Tacoma
    Aquatic Tacoma Well-Known Member
    Odessa, Fl.
    2019 Tacoma TRD Sport 4x4 Dbcb , 2004 Tacoma S-Runner
    Both are Stock - built correct from the start.
    The weight distribution bars for example on my E2 provide the “distribution” by flexing after setup. Other type hitches uses chains or cables. If the bars are designed to distribute say 800-1200 tongue weight they will be built thicker than 300-600 lbs bars. So instead of flexing and distributing, they be stiff and could bend or break truck or trailer.
    Also get familiar with the trailer towing section in the truck owners manual. You get a lot of crappy info on this forum from folks who have never even looked there.
    I have no connection other than receiving great customer service over the years. But contact the expert folks at ETrailer.com with any question.
