Buying a used Toyota... HELP!
Discussion in 'New Members' started by TXGirl11, Jan 10, 2020.
  1. Jan 10, 2020 at 1:16 PM
    TXGirl11
    TXGirl11 [OP] New Member
    April
    Tacoma V6 4WD - 178k miles
    None.
    I'm looking at a 2013 Taco double cab with 178k miles, 4x4, everything in it but leather seats... Do you think thats a good investment? I know Toyota trucks last forever, but is 178K too many miles?? I'm hopefully only going to spend $14-16k on it... I don't know, I need some advice any and all is welcome, but no trolls please =)
  2. Jan 10, 2020 at 1:20 PM
    TXGirl11
    April
    None.
  3. Jan 10, 2020 at 1:25 PM
    fiftyxp
    fiftyxp Well-Known Member
    2017 trd offroad 4x4
    have you seen it yourself?
    It spent some time in ohio.
  4. Jan 10, 2020 at 1:27 PM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    Check that frame out really good and post some pics on here
  5. Jan 10, 2020 at 1:30 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Not a terrible price if its 14K. As always have the frame checked for rust.
  6. Jan 10, 2020 at 1:33 PM
    Muddycoinwash
    Muddycoinwash Well-Known Member
    2015 TRD OR access, 2000 4x4 reg
    Welcome to TW! As far as miles, I just bought a 2000 w/155k, I expect to put at least another 150k on it. I would have a mechanic look at it, and run a carfax to check the history. Best of luck!
  7. Jan 10, 2020 at 1:35 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Sounds good to me. Check for frame rust. Look for Timing belt replacement sticker under hood. If not it was due at 100,000 mi.
  8. Jan 10, 2020 at 1:52 PM
    BINK05TRD
    BINK05TRD Well-Known Member
    Massachusetts
    TRD OR AC SILVERSKY 15
    Welcome to the forum April :cheers:
    Can you send us a link on it ?
    Peeps here will let you know if it’s worth it.
    Taco critter and Evlkarl like this.
  9. Jan 10, 2020 at 1:55 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW...As long as it’s be maintained well it should still have a lot of miles left.
    Taco critter and Black DOG Lila like this.
  10. Jan 10, 2020 at 2:10 PM
    BINK05TRD
    Massachusetts
    CarFax looks good. Basic oil changes it seems.
    As stated above check the frame.
    There’s another member on the forum that just purchased one from a Toyota dealership and the frame is toast.
    Taco critter likes this.
  11. Jan 10, 2020 at 2:17 PM
    TXGirl11
    April
    None.
  12. Jan 10, 2020 at 2:19 PM
    TXGirl11
    April
    None.
    It’s one owner certified on carfax... I haven’t checked it yet. I need to do that... I got the vehicle off true car and I’m sure if there was frame damage it would have been reported...
  13. Jan 10, 2020 at 2:20 PM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    V6s have a timing chain, no replacement necessary at 100k
  14. Jan 10, 2020 at 2:21 PM
    TXGirl11
    April
    None.
    This is her...
  15. Jan 10, 2020 at 2:36 PM
    El Duderino
    Jeremy
    HI->PNW
    The inside looks nice but no pics of frame and under carriage makes me want to pass until I see them
  16. Jan 10, 2020 at 2:43 PM
    jtaco11
    jtaco11 Well-Known Member
    Looks clean 1 owner has all the basic oil change records which is good. Id have a mechanic look at it also just at 178k miles some major services should be around the corner if it was never done like water pump, serpentine belt, etc. Can factor that in with sale price. Good luck!
  17. Jan 10, 2020 at 2:51 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Frame rust, wheel bearings, brakes and cables, driveshaft u joints and center bearing, timing belt, tires, alternator belt and tune up. If the frame is good figure 3k to “fix” it (if you have to) and good luck I hope it works out for you!
  18. Jan 10, 2020 at 2:53 PM
    BalutTaco
    BalutTaco Moja_Przygoda
    2019 Cement Limo Trail Edition -> 2022 Magnetic Grey OR
    Bird nest engine bay.
    I want to say you can find a way better deal! But I'm cheap!
    Taco critter and TXGirl11[OP] like this.
  19. Jan 10, 2020 at 2:58 PM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
    Welcome to TacomaWorld!
  20. Jan 10, 2020 at 3:00 PM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    you can def find a better deal 178k is a lot of miles and so is 14k for it
