Buying a used trd exhaust. Any advice?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by slowlane, Jun 2, 2015.
  1. Jun 2, 2015 at 9:33 AM
    slowlane
    slowlane [OP] Well-Known Member
    AZ
    16 double cab MGM
    So im working out a deal that ill be buying a genuine trd exhaust with trd etching on the tip. He pulled the exhaust off, not to long after buying the tacoma. Ive never bought a used exhaust from someone, does anyone have any advice before i buy this off of him? I know that itll fit, we both the same truck, double cab short bed. Should i look for any specific branding to confirm its genuine? Any help is appreciated. Thanks!
  2. Jun 2, 2015 at 9:36 AM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    They are SS so most likely not rusted.
    Should be good to go. TRD muffler is smaller dia. so just compare to yours.
    Easy to swap also, enjoy.
  3. Jun 2, 2015 at 9:46 AM
    DanceswithWolves
    DanceswithWolves palabra a tu madre
    Jerry
    Roosevelt UT
    13 DCSB OR
    new gaskets.
  4. Jun 2, 2015 at 11:27 AM
    slowlane
    AZ
    16 double cab MGM
    Thanks for the help guys!
    I have about 13k on my truck. Could i swap out the gaskets from my exhaust? Or is it better to get new gaskets?
  5. Jun 2, 2015 at 11:28 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    New gaskets whenever you unbolt the couplers IMO. Cheap insurance against exhaust leaks.
  6. Jun 2, 2015 at 11:31 AM
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
    Yes to play it safe get new gaskets!
  7. Jun 2, 2015 at 11:36 AM
    DanceswithWolves
    Jerry
    Roosevelt UT
    13 DCSB OR
    Always new gaskets at joints where unbolted. They crush and if reused, usually leak. Do it right or do it over!
  8. Jun 4, 2015 at 7:16 PM
    RKCRUZA
    RKCRUZA Well-Known Member
    Bob
    Placerville, Ca
    2015 TRD Pro in the Garage!
    Had a picture with the TRD muffler showing the part number but can't find it now. The two exhausts should look pretty much identical with the exception being the TRD muffler is about 1/2 the diameter of the stock muffler. Depending on the year Taco it came off of and is going on to the brackets may be different 2013 to present uses the same hangers, pre 2013 may be different. I swapped out a 2015 for a 2015 so no issues. Soap or such on the rubber hangers makes it easier to get the hangers off. Also, if doing the swap on the ground, jack up the back end of the truck as high as you can without picking up any tires and then pull the exhaust out towards the front of the vehicle (I used a floor jack under a drop hitch as I have the tow package). Also, when removing / installing, alternate tightening / untightening the spring bolts rather than doing one side all the way at once. About a 20 minute job if all goes well...hardest part was getting the rubber hangers off as it was a new vehicle. I re-used the "doughnut" gasket but only had 1200 miles on the truck...it is always good to replace it.
