<Buying Advice> 2003 Toyota Tacoma TRD Xtra Cab Pre-Runner <HELP>
Discussion in '1st Gen. Tacomas (1995-2004)' started by RAD, Apr 20, 2011.
  1. Apr 20, 2011 at 11:36 PM
    RAD
    RAD [OP] Well-Known Member Vendor
    Rad
    LAX & LOGAN
    My buddy decided to buy a 2nd Gen. He decided to not buy a brand new CBR600 and Go Used.
  2. Apr 21, 2011 at 7:24 AM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    100k mile service? does that mean the timing belt has not been done?
  3. Apr 21, 2011 at 7:45 AM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    X2
    and about the leaf springs they were probably going to be done by now anyways. The 1st gen stock leaf springs suck. The truck sounds good from the description. How does the frame look?
  4. Apr 21, 2011 at 11:19 AM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    Yup you guys got it...
    Timing belt
    Frame check
    If it was lifted mall-crawler style, check to see if things like incorrect driveshaft + pinion angles are causing any wear or damage.
  5. Apr 21, 2011 at 1:09 PM
    RAD
    Rad
    LAX & LOGAN
    Thanks
