Buying first truck which should i get?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by xbluexile, Dec 20, 2019.
reliability?
  1. 4.0 w/ 6spd
    18 vote(s)
    81.8%
  2. 2.7 w/ 5spd
    4 vote(s)
    18.2%
  1. Dec 20, 2019 at 12:20 PM
    xbluexile
    xbluexile [OP] New Member
    Hello im looking at two Tacoma's to purchase as my first vehicle/truck.
    My first pick was a 2009 access cab with the 4 cyl 2.7 liter 5 speed, 264k with two owners, the truck runs good and seems solid other than when i start to push the clutch in, like a 1/4 way it starts to squeal just slightly and not to loud...
    The second option i was looking at was another 2009 but this one is a TRD with the 4.0 and a speed equipped, 183k one owner...
    Im mainly wanting the trd cause itll hold its value better and longer, but i dont know how reliable the 6 speed is compared to the 5 speed, or the 4.0 compared to the 2.7...
    I work as a steel framer and will put close to 120 miles a day, wont be towing much and just be using it for usual outdoor activities, maybe occasional road trips from Montana to Seattle, i come from a ford family and no nothing about toyotas so any info and advice is appreciated!! Thanks again!
  2. Dec 20, 2019 at 12:21 PM
    xbluexile
    Just a fore word also i havent been able to drive the v6 yet as its 100 miles away im just considering before i make the trek
  3. Dec 20, 2019 at 12:32 PM
    '14RC
    '14RC WA State
    Seattle
    2014 4x4 Regular Cab 5MT
    2" Lift & 32" tires w/ Camping Setup (see details) Suspension: Dobinson 2" Coils (PN: C59-316) 4x Bilstein 5100's (base setting) SPC Upper Control Arms Deaver J66 Leaf Springs Ride-Rite Airbags Archive Garage Hammer Hangers Poly Leaf Spring Bushing Camping: SnugTop Canopy ARB awning Built a Camping Shelf in the Bed Yakima Mega Warrior Roof Basket Interior: Bucket Seat Conversion Acoustically Insulated Interior Added Cruise Control Rear Storage Organizers Traction: Yellow Wire Mod Alloy's with 265/75/16 Towing: Aftermarket Class III Tow Hitch Trailer Wiring Brake Controller (wired, not installed) Misc: ECGS Bearing NH Oil Undercoating
    Hi xbluexile,
    Welcome to the forum! I'm on my 5th Toyota pickup truck (all have been 4cyl) + my family has a couple of 4runners (4.0 V6 and 4.7 V8). IMO (without knowing price) the TRD is the clear option here. Lower miles, and that 6 cyl is really a nice engine. The clutch squeal sounds suspect, that might be a throwout bearing issue if you didn't notice the clutch slipping, otherwise. I'm not sure where you are located, but check for rust on the frame (particularly the S-Curve where the frame begins to bend upwards to meet the bed), check the fenders for any rot, look around for leaks, and just listen for any suspect noise/vibration in the engine/drivetrain when you test drive. That's about the best you can do without taking it to a mechanic. You don't really need to be concerned about 2.7 vs 4.0 for longevity, both engines are high quality.
    Good luck!
  4. Dec 20, 2019 at 1:17 PM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    2.7.. PASS
  5. Dec 20, 2019 at 2:01 PM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    I'm partial to the late 2nd Gen's....for me....
    would have to be (and is) the 4.0L w/manual...even with quirky ratios
    Now short bed or long bed is another question ?
    Double cab only for me.....just need & like the extra space
  6. Dec 20, 2019 at 2:04 PM
    rphillips
    rphillips Well-Known Member
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    Only reason to have a 2.7 is if, like me, you are addicted to reg. cabs. I love my reg. cab Taco, but hate the weak little 2.7. But you can't get a reg cab with a 4.0.
  7. Dec 20, 2019 at 2:23 PM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    With those two choices I'd probably opt for the lower mile 1-owner TRD. What are price differences?
    That said, do not listen to the people shitting on the 2.7. It's an equal or better engine in every way except power. The only reason you'd hate it is if you like to haul ass or tow heavy loads. It's a beast off-road.
  8. Dec 20, 2019 at 3:10 PM
    Rick's 2012
    Rick's 2012 Well-Known Member
    Rick
    Costa Rica
    2012 Double Cab 4x4 Grey with leather
    Stock
    Lower mileage V6 :thumbsup:
    jetfishn likes this.
