Buying high mileage? Things to look out for?
Discussion in '1st Gen. Tacomas (1995-2004)' started by scs167, Jun 24, 2023.
  1. Jun 26, 2023 at 11:11 AM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    These only get to the 400K or 500K mark by what was done to it during the first 100K...
    Ideally high milage is OK on a mostly high way mile truck.....daily commuter......
    Changing that coolant and oil is a big deal.....
    Best way is to buy three of them....over the years.....
    .....by the time you go for your forth one.....you'll be an expert.
    Hell I'm wanting to restore a 4-runner now......
    .....which are all japan assembled ...and run forever...
    Black97v6MT likes this.
  2. Jun 28, 2023 at 5:55 AM
    scs167
    scs167 [OP] Member
    Thanks all! I'm now considering a 2002 4Runner, which I understand is basically the same as a Tacoma in terms of reliability/maintenance (correct me if I'm wrong). It has 214k miles and listed for $14.9k, with a few mods that I like. The maintenance history is pretty immaculate, it's local, and owned in rust-free states (TX/CO), so I am pretty stoked on this one. Will probably go check it out today!
  3. Jan 26, 2025 at 3:17 PM
    Tamayonnaise
    Tamayonnaise Member
    Aidan
    I know this is an old post, but what issues do the trucks outside of 98-02 have?
    Moonrman and Pbfender15 like this.
  4. Jan 26, 2025 at 6:20 PM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    Not sure of any issues the '95.5-97 trucks had, but the '03-04 trucks have an early version of throttle by wire that requires a full throttle body replacement ($500) if and when the accelerator pedal position sensor goes out.
    I have a spare brand new OEM throttle body for my '03 sitting on the shelf as a result of this.
  5. Jan 26, 2025 at 6:21 PM
    ztwatson
    ztwatson Well-Known Member
    Milwaukee, WI
    2004 Tacoma TRD Xtra Cab
    I believe all 03-04 have ABS brakes which some people don’t like. The rear drums in 03-04 also have a different braking system where they automatically stay adjusted compared to having to use the parking brake. The throttle body is different on my 04 compared to the 02 I had. But honestly I’m not sure what else is really all that different when comparing 02 to 04.
  6. Jan 26, 2025 at 6:22 PM
    ztwatson
    Milwaukee, WI
    Can we swap in the earlier style throttle body?
  7. Jan 26, 2025 at 6:49 PM
    Red_03Taco
    Jerad
    My understanding is we cannot. Our ECU needs to recognize/detect the accelerator pedal position sensor (APPS). So presumably you could swap ECUs and an older throttle body.
    ztwatson[QUOTED] likes this.
  8. Jan 26, 2025 at 7:10 PM
    O'Silver_Taco
    MD
    03/04 novelty list....unique to these
    motor in the throttle body, cable sensor instead of cable actuated....
    trannies are electronic with no kick down cable...
    charcoal canister is in the worst place for north salt states.....rear...
    they seemed to go crazy on the cats.....one would of been enough....
    I actually think the abs is the best thing......trucks are so dangerous they need everything they can get to save your ass...
    I'm not a fan of coil over plug ignitions......reliability is hit or miss....
    Similar on the pre 98's.....because of the point distributor.....little less reliability...
    the mechanical parts wear, eventually has to be replaced.....
    and the maf sensor......if unlucky enough to get the ancient one.....the $1000 discontinued one....without which truck will not run....
    And for the worst thing.......it seems the later taco frames are wasting away faster than the pre 01's.........the replacement frames fall in this same production date......hint hint...
    ztwatson and Black97v6MT like this.
  9. Jan 27, 2025 at 7:59 AM
    Red_03Taco
    Jerad
    Weren't '98-02 trucks also coil over plug? My '03 has coils on cylinders 2, 4 & 6, with plug wires connecting each coil to another cylinder (1, 3 or 5). The '98-02 trucks I've seen have all been setup in this same way.
    Are you just referring to 2rz/3rz trucks?
  10. Jan 27, 2025 at 6:01 PM
    O'Silver_Taco
    MD
    5vz's are sorta coil over.....half and half
    reason the earlier 2rz/3rz's are simpler.....last a lot longer.....98/2000
    think the Tundra and 5vz coil oem coil design is above standard...
    those I've seen very few problems.....like 200K and zero problems
    I'm not sure the 2rz/3rz coil over plug design is as robust.......especially aftermarket/clone...01's to 04's
    Red_03Taco likes this.
