Buying lifted Tacoma... questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Maniac28, Jan 2, 2011.
  1. Jan 2, 2011 at 3:39 PM
    Maniac28
    Maniac28 [OP] New Member
    Ian
    Hemet, CA
    Looking!
    Hi all,
    So I would like to buy a Tacoma, been looking for a 4x4 TRD Off road, and I found one not far from me. It is an access cab with the manual transmission, 63k miles. Also, it has the following mods:
    6" Pro Comp lift kit with coilovers (I believe this is the lift, but could be wrong)
    KMC XD 18X9 wheels
    Mickey Thompson Baja 325/60-18 tires
    My concern is... I really don't want such a big lift, and such large and expensive (and noisy) tires on my truck. I'd rather have a stock truck with the 265 tires, stock wheels, and a small lift, or no lift.
    My question is... how hard is all this to remove, and also, will I be able to sell the stuff easily? How hard will it be to go back to stock? I'm an OK wrench, but have no experience with lifted trucks. I don't know much about the value of used wheels, tires, and lifts.
    Thanks for any advice. BTW, they are asking $15k for the truck.
  2. Jan 2, 2011 at 3:42 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    IIRC 6" drop-bracket lifts with these trucks require cutting the front crossmember of the frame...irreversible...
  3. Jan 2, 2011 at 3:42 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    I believe that in order to install that lift on a 4x4, the stock front crossmember must be cut. There is no going back to stock, unless you find a donor crossmember to weld back in.
  4. Jan 2, 2011 at 3:54 PM
    Maniac28
    Ian
    Hemet, CA
    Looking!
    That is great info (but bad news for me). thanks.
    I think it's a 6" lift... but I could be wrong, it might only be 4". I guess I could go over there and try to find out. It's at a dealer so they don't really know.
  5. Jan 2, 2011 at 4:10 PM
    chopper
    chopper ky taco
    chop
    stanton,kentucky
    05 taco reg cab 4x4
    dura tracs, debadged, weathertech floormats, removed mudflaps,black paint wheels,k&n air intake.
    just buy one thats stock and u dont have to worry about it.
  6. Jan 2, 2011 at 4:45 PM
    BlueTaco07
    BlueTaco07 Super Mod!
    Cody
    Panama city, Florida
    Looking
    I will trade you my stock 2007 toyota tacoma 6 5.5 lug rims for the kmc xds?
  7. Jan 2, 2011 at 6:42 PM
    KPT
    09 Prerunner
    If it's a procomp it's either a 3" or 6".
  8. Jan 2, 2011 at 7:03 PM
    surfrat
    surfrat Well-Known Member
    LI, NY
    icon coilover, total chaos UCA, allpr expo, icon 2.0 rear,wet okole
    if the previous owner saved the part that he cut out it can be re welded back in...just not sure its worth the headache
  9. Jan 2, 2011 at 7:16 PM
    th3bigk0
    th3bigk0 GETTN IT
    Dylan
    Lamecaster
    13 TRD Double Cab
    Fox 2.5 RR C/O's,Camburg UCA,Camburg Spindles,KING 2.5,OME Dakar Leafs,285 KM2,XD HOSS 16'',BHLM,HID's,CB,Hornblasters Shocker 540 train horn,KICKER 12 ported....
    i would NEVER run a drop bracket lift,they do require cutting and are just shitty,keep looking
  10. Jan 2, 2011 at 7:17 PM
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    You would also be inheriting all the problems like wear and tear on bearings and drive lines that are caused by lifts. I would walk away since you don't want the lift
  11. Jan 2, 2011 at 9:51 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Yeah, it's as they all said. It's worth considering only if you want the lifted configuration.
    It's nuts to buy a lifted truck with the intention of trying to reverse it back to stock, especially when there are already so many stock trucks out there on the market.
    Bullwinkle J. Moose thinks you're impatient and have money burning a hole in your pocket. Impatience is always the enemy of the prospective car or truck buyer. Patience is your friend.
  12. Jan 2, 2011 at 9:56 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
  13. Jan 3, 2011 at 8:05 AM
    Maniac28
    Ian
    Hemet, CA
    Looking!
    Thanks guys, I really appreciate your advice. This is hugely helpful to me, someone who is new to this whole truck world.
    I definitely won't be buying this truck for all the above reasons. I don't need one right now, I already have a 4x4 that's still running, and I can continue to look for a nice, unmolested Tacoma.
