Buying My First Tacoma! Advice Needed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by matteozeppi, Jul 3, 2025.
  1. Jul 3, 2025 at 4:36 AM
    matteozeppi
    matteozeppi [OP] New Member
    Hey everyone,
    I’m currently in the market for my first Tacoma and was leaning toward a 3rd gen. I’m specifically looking for a manual, as I really miss the feel of driving stick. I’ve been daily driving Ford F-150s with the 5.0 for the last 13 years and absolutely love them, but I’ve heard great things about the Tacoma in terms of reliability and off-road capability.
    That said, I’ve also read that the 2005–2015 models are considered more reliable due to the simpler 1GR-FE engine. Some say the 3rd gens are just as good though, so I’m a bit torn. I’m trying to avoid the 4-cylinder models and really just want something solid and dependable for the long haul.
    I’ve heard mentions of oil leaks and other minor issues with the 3rd gens — is there anything major I should be aware of? Would really appreciate any insight or advice from experienced owners on which generation to go for.
    Thanks in advance!
  2. Jul 3, 2025 at 8:04 AM
    TACOTRDPRO1
    TACOTRDPRO1 TOM S
    ROCHESTER NY
    2020 TRD PRO // 2010 VETTE ZR1
    I can tell you I have A 2020 TRD PRO manual.. zero issues. You are correct in your thinking GET a 3 pedal truck. Much less problems. Watch out for rust if your in a rust belt area like me. I dont drive it in the winter. Good luck !!
    Horseshoez likes this.
  3. Jul 3, 2025 at 8:12 AM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    Biggest thing to look out for on these trucks are rotted frames. Other than that ensure there's maintenance records. There's a lot of complaints with the 3rd gen auto trans so wanting a 3rd pedal will alleviate that issue. Folks still reccomend a tune with a manual trans on the 3rd gens. I currently own an 07 (second gen) with no complaints.
  4. Jul 3, 2025 at 8:16 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Every vehicle from every builder is going to have its "issues". Some are pure folklore, and some are very real. But overall the 3rd Gen Taco is a solid mid-size truck. If it were me, I would look for a 2020 or newer truck. Expect to look extra for a manual that trips your trigger.
    PS: you are going to miss the towing capabilities that your F-150 had if you happen to tow stuff.
    Burns, BillF1564 and Chew like this.
  5. Jul 3, 2025 at 8:23 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    No problems with my 2016 with 62K miles. I am the original owner, so if you buy used make sure it is well maintained. Check out this thread since you have an F150. Welcome to TW regardless of what you get.
    https://www.tacomaworld.com/threads/f150-owner-considering-making-the-switch.705304/
  6. Jul 3, 2025 at 9:52 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    a manual is going to be hard to find, but hold out for what you want.
    I suggest test driving one, even if it's an automatic. Especially since you are used to a V8, you should understand the 3.5 doesn't product much torque down low and needs to be spun up. There is a new post nearly every single day from folks wanting to "improve shifting" or something of the sort, fact is, there is nothing wrong other than expectations and lack of test driving before purchasing. Also if you plan to tow, there are numerous complaints on the manual transmission trucks having a tall reverse gear, making backing up hills and/or with a trailer, a clutch slipping endeavor or having to use 4low.
    All said- I love my 3rd gen and plan to keep it a long time. But, when it gets retired, it will be replaced with a truck with more low end torque.
    BillF1564 likes this.
  7. Jul 3, 2025 at 10:43 AM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Some of those old F-150's and even the Rangers are beasts. And per others you will miss the towing capability and torque.
    But - the 2021-2022-2023 models are 'good'.
    Perfect?... no.
    Do your homework, get someone to take a deep dive look-see and you should be ok.
    I wouldn't buy the 2024+ 4th Gens for another few years to see how they shake out.
    Horseshoez and BillF1564 like this.
  8. Jul 4, 2025 at 3:21 AM
    Nirango kid
    Nirango kid Well-Known Member
    Gilles
    Ontario
    2021 Tacoma TRD Sport Premium in Barcelona Red
    I have the 2021 year and have no issues with it. I don't tow, go off road. I mainly use it as a everyday old man truck. Keep it at 50 mph on most paved roads and regular maintenance is the key to a long life of the vehicle and oh yeah forgot get oiled or rust proofed if you live in the snow, salt belt like I do.
  9. Jul 4, 2025 at 4:28 AM
    TomYotaNH
    TomYotaNH Well-Known Member
    Tom
    Seacoast NH
    '16 Barcelona Red DoubleCab Limited
    Almost Stock - BedRug, Power Tailgate Lock, ….
    Welcome to TW.
    2016 owner here, 82k and no abnormal issues. Do oil changes and regular maintenance. When buying, note what you’ll be doing , towing, or whatever and buy appropriately decked out, like towing package, etc. if you like creature comforts, look at “Limited”, if you’re just looking for a workhorse SR5 will get’r done. One big thing is resale value when it’s time to move on, they do hold their value.
  10. Jul 4, 2025 at 4:37 AM
    fiftysix
    fiftysix Mell-Known Wember
    Midwest
    23 TRD OR, 03 Rust Bucket
    Tacos rule :taco:
    Tocamo likes this.
  11. Jul 4, 2025 at 5:55 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    If speed is your #1 need, you may be disappointed. But if reliability and off-road capability is your #1 need, you've picked the right truck.
    The TRD Off-Road model is the best bang for the buck, as it is much cheaper than the TRD Pro, and the TRD Sport is more of a street runner.
    The SR & SR5 (V6), are no slouches either, they are just missing the rear locker & Crawl Control (something the TRD Sport also does not offer).
    shakerhood and Road_Warrior like this.
  12. Jul 4, 2025 at 6:03 AM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    My 2021 SR5 has been incredible. I came from a ram 1500 that was a complete piece of garbage. I purchased that truck new and took extremely good care of it but it was falling apart by 60K miles.
    The Tacoma is the opposite, nothing fancy and it just starts and goes every time as long as you take care of it.
    I drive my truck all over North America and I use it like a truck. If I had to go back in time to when I sold my Ram because it couldn’t be trusted, I would buy still the exact same taco.
    Tocamo and GLGAR like this.
  13. Jul 4, 2025 at 6:04 AM
    Squirt
    Squirt Samsung Aficionado!
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back. J&L catch can. AMP Powersteps
    Being a previous Taco owner and current F150 owner I would definitely recommend driving multiple before buying. For me F150 is much roomier, seats are more comfortable, ride a little better, I ended up getting better fuel economy with the 3.5L EcoBoost than my 2009 with the 4.0 and a rocket ship compared to the Tacomas.
    Chew, BillF1564 and Road_Warrior like this.
  14. Jul 4, 2025 at 7:53 AM
    BillF1564
    BillF1564 Well-Known Member
    2021 Tacoma SR
    The f150 hauls more, tows much better, has a lot more room, and will get better mileage than a Tacoma.
    The Tacoma is a decent mid sized truck. Keep the Ford. I like my Tacoma for what it is.
    Chew likes this.
  15. Jul 4, 2025 at 9:30 AM
    Big Cole
    Big Cole Well-Known Member
    You will be disappointed moving from an F-150 to a Tacoma. I went from a Ram 2500 with the 6.7 Cummins to my 21 Tacoma. Tacoma fuel economy is worse, less comfort, and considerably worse drivability. Only reason I switched vehicles was that I stopped towing my Jeeps so I could no longer justify an expensive depreciating asset sitting in my driveway rotting in the sun.
    Squirt and Chew like this.
  16. Jul 5, 2025 at 3:43 AM
    Breeze Man
    Breeze Man Member
    2023 Tacoma TRD Sport DC LB
    I have a 23 TRD Sport 6' bed. I had a 13 Sierra 5.3 before the Tacoma. The Sierra had alot more power, room and bed space. I just did not need a full size V8 powered truck since I do not tow or haul heavy loads. For me, the transmission in the Tacoma is the only quirk the truck has. Apparently a tune helps with this issue.
  17. Jul 5, 2025 at 5:40 AM
    4x4spiegel
    4x4spiegel Well-Known Member
    Welcome to TW ! Whatever you purchase let us know how it goes as time passes .
  18. Jul 5, 2025 at 6:41 AM
    18trdsport
    18trdsport Well-Known Member
    Bay Area, CA
    2018 TRD Sport ACLB MT
    If you are worried about 3rd gen reliability, buy one from a dealer with an extended warranty. Toyota pumped out 200k-250k 3rd Gens per year between 2016-2023. You will hear a few horror stories, but the vast majority of 3rd gens are reliable. I have a 2018, but my mileage (20k) is too low so can't give much advice on it's reliability just yet. It has had to recalls serviced (fuel pump, PCS sensor), and once for warranty (squeaky clutch).
  19. Jul 5, 2025 at 8:27 AM
    majpooper
    majpooper Well-Known Member
    Dennis
    North Carolina
    2022 Black TRD OR
    OTT Tune Front 2" lift OME 888 coil Bilstein 5100 DuroBump extended front bump stops Archive Garage extended rear bump stops Rear 1.85" lift Icon RXT leaf pack Bilstein 5100 SPC UCA DX4 16x8 +10 wheels 285/75R16 KO2 viper cut CMC sway bar delete exhaust reroute exhaust cut just past the rear axle U-bolt flip LFD engine skid plate RCI transmission and x-fer case skid plates Spindle gussets
    I have a 2022 Off Road that I literally beat to death off road - it does not get babied. Just had it at the shop for the 60K maintenance and no major issues.
    I do change the oil every 5K miles and sometimes - when I feel like it - rotate the tires and clean the mud and dirt off it. Oh and it has an OTT tune so I think it runs really nice on the pavement so all the complaints about under powered blah blah blah - yeah, I have no idea what that is all about.
  20. Jul 5, 2025 at 10:49 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    To get the Manual you will be only able to find in a few trim levels and configurations. Double Cab Short Bed Off Road, Sport, and Pro, and Access Cab Sport. Since you mentioned no 4 bangers, l left out the 2016 - 2017 Access Cab SR.
    Chew and Horseshoez like this.
