Buying New Truck, questions about existing lift
Discussion in 'Suspension' started by Skimoab, Apr 27, 2011.
  1. Apr 27, 2011 at 2:40 PM
    Skimoab
    Skimoab [OP] Active Member
    Dave
    Draper, UT
    06 Silver CC LB Sport
    Plasti-dipped Badging, Leveling Kit, New Wheels and Tires, 4WD Switch Illumination, Aftermarket Stereo
    Hi Everyone,
    First of all, I'm new to the forum so Hello! I've been a regular over at Mazda6Club.com but just sold the 6 to buy a Taco and I'm excited to join in on this community.
    I've found the truck that I'd like to buy but I'd just like some input on the lift. I do know that it's a Pro Comp 6" lift, but I don't know what is stock and what has been replaced/upgraded. It does look like the Drive Shaft, Half Shafts, and maybe even the rear differential have been replaced? I've taken several shots and would like to know anything you guys can tell me.
    Thanks!
    Dave
    Front Setup:
    Rear Setup:
    View to the rear of driver-side leaf spring, is this extension stock or added?
    Additional photo of lifter:
    Original Diff?
    Front Drive Shaft:
    Dana Roll Pin:
    Rear Drive Shaft into Dif:
    Mid Drive Shaft Linkage:
    Truck as it currently sits:
  2. Apr 27, 2011 at 2:42 PM
    tacoma44x44
    tacoma44x44 Well-Known Member
    Jamie
    Calgary, AB
    07 Dc trd
    Pro comp stage 1 right there.
    All the rest of the truck looks OEM to me.
  3. Apr 27, 2011 at 2:46 PM
    DocCisco
    DocCisco Well-Known Member
    David
    Utah County, UT
    LB TRD Sport 4x4
    Welcome Dave! I'm over in PG.
    Awesome group of people here. Good looking truck.
  4. Apr 27, 2011 at 2:58 PM
    Skimoab
    Dave
    Draper, UT
    Thanks guys. So the Dana Driveline parts are stock? How would the Pro Comp 1 affect the life of the transmission or the mpg? Should I be worried at all at 60,000 miles? Should I consider re-gearing if it's on 31-32" tires?
    Thanks for your help.
  5. Apr 27, 2011 at 3:04 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    You should be fine with those gears but you might want to go to stage 2 and upgrade those shocks.
  6. Apr 27, 2011 at 11:29 PM
    Skimoab
    Dave
    Draper, UT
    Suggestions on where to buy the Stage II upgrade?
