buying used coilover
Discussion in 'Suspension' started by 08pretaco, Sep 7, 2009.
  1. Sep 7, 2009 at 10:09 AM
    08pretaco
    08pretaco [OP] Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    so im thinking of buying some used eibach coilovers for my tacoma. its the old toytec ones that were silver. so my question is what will i need to buy in order to make them work. cause im just getting the coil and the collar i guess is what its called, the thing on the bottom that you crank up with the spanner wrench. can i use the same top plate i got on my stock setup? then do i need any "gaskets" idk what they are but when you look at the picture on toytec of their coilover, there are these silver gasket type looking things.
    also do you think its a good deal for a couple hundred?
  2. Sep 7, 2009 at 10:16 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    If you already are running the 5100 shocks, then all you will need is a spanner wrench.
  3. Sep 7, 2009 at 9:56 PM
    08pretaco
    az
    dont have the 5100 yet but will order from sonny and i figured id need a spring compressor haha
    are these a good set of coils and is a couple hundred a good price you think?
  4. Sep 7, 2009 at 9:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You may be able to swing a deal with Downsouth, or Toytec on a new set for the same price.
