Buying Used
Discussion in 'Suspension' started by The Scientist, Sep 24, 2022.
  1. Sep 24, 2022 at 10:07 AM
    The Scientist
    The Scientist [OP] Active Member
    San Diego, California
    2019 TRD Off-Road DCLB
    ARE Shell, K&N Air Filter, Tint, LED Headlights, Custom build-out, Meso Taillights, Bilstein 6112, Bilstein 5160, Icon RXT Stage 3 Leaf Pack, CBI Prinsu Rack W/ Lightbar, TRD Pro Grille, Falken Wildpeaks on KMC Wheels,
    Can someone enlighten me on things to look out for when purchasing used mechanical gear? I am on a very tight budget but MUST upgrade my suspension (I'm sagging very badly) so am pretty locked into finding cheaper suspension as it has been used for 10k miles or something along those lines. However, I feel like this is rather sketchy because people are usually taking off good suspension for a reason, and I'm worried it will bite me in the butt. Like yeah, maybe I save a grand, but it shits the bed in a year and now I have to pay 3k more or something along those lines. Does anyone have some input? Should I even bother shopping second-hand suspension?
  2. Sep 24, 2022 at 10:11 AM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    The suspension components on your truck are vital to your safety. Why would you want to go cheap? Used products can save you a lot of money, but you don't know if they're defective, were abused or neglected, etc...
    It'll hurt your wallet, but you'll have peace of mind knowing that you have new parts that are under a warranty. Used parts very rarely have a warranty. Now, buying new isn't a 100% guarantee, but that's what a warranty is for.
  3. Sep 24, 2022 at 10:17 AM
    The Scientist
    Yeah, the issue is that I don't want to get mediocre parts new and then have to upgrade again in a couple of years' time. id rather instead get nicer parts used but I don't know if that is much better.
  4. Sep 24, 2022 at 10:24 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    People are upgrading suspension(s) all the time. Know what you are buying. Know who you are buying from, do you believe the back story. Need some UCA’s, free to good home. New ball joint and bushings you are good to go. About 40K miles on them.
    I got a good deal on previously owned OME springs $300 with a few thousand miles on them. Gave my OEM springs away to get them out of the garage.
    gsubioguy, MalinoisDad and Key-Rei like this.
  5. Sep 24, 2022 at 10:27 AM
    Merling
    Merling Well-Known Member
    James
    NH
    2021 Black Tacoma TRD OR
    RCI IFS Skid Eibach Stage 2 Explore Overland Sliders
    Personally I would get new unless I knew the person with the takeoffs
    edit: something penny wise but dollar poor
    The Scientist[OP] and Nessal like this.
  6. Oct 3, 2022 at 10:42 PM
    goforbroke123
    goforbroke123 Well-Known Member
    Montgomery County, PA
    2012 Tacoma TxPro DBcab 6speed
    Dude, don’t put used clapped out ass parts on your 2019 truck, even if they are King or xyz. They’re probably for sale because they need to be rebuilt, that’s the common theme I see on TW at least.
    You might want to factor in the rebuild cost and down time of your truck when these used high end parts shit the bed, along with labor cost if you aren’t doing the wrenching yourself. After you figure that out you might not be saving any money and just causing more headaches.
    I’d keep saving my money if I were you.
    A stock 2019 with saggy suspension already?
    Is that a cap on the back?
    Merling likes this.
  7. Oct 3, 2022 at 11:22 PM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    I run used lower mileage than my truck and less abused Lca's, used leafs, 10 year old Fox coilovers, used Uca's before I switched my setup up a bit, it all depends on if you know what you are getting into or not and if you are down to do maintenance on the used parts if needed.
    Merling likes this.
  8. Oct 4, 2022 at 3:30 AM
    Merling
    James
    NH
    If they’re looking for someone to tell them cardinal signs of collapse on components, maybe not the best idea for them to get used stuff. I know I wouldn’t know, so I bought new.
    Just wait for a sale, if you can. Safety first
    goforbroke123 likes this.
  9. Oct 4, 2022 at 6:05 AM
    The Scientist
    i hear yuh, turns out I’m making quite a bit more than I originally thought, and yeah not really into the idea of getting used. I’d rather sleep easy at night. Yeah I’ve got a cap on it but I’ve also built out the back so all the wood added tons of lbs
  10. Oct 4, 2022 at 7:08 AM
    Merling
    James
    NH
    I can personally tell you, good luck with whoever installs. I went to the “premiere” shop in my area and they put the blocks on backwards and argued with me about it even with saying the manufacturer is telling me it’s wrong.
    In the end they fixed it but when you pay top dollar, you expect the service to be there. And done right the first time. Anyways, hope it goes well for you is all I mean
  11. Oct 4, 2022 at 7:13 AM
    The Scientist
    well shit. I thought the “pros” was the best way to get the job done. I don’t have nearly the time nor space to do it myself. Fingers crossed the leafs, front and back sus get put on correctly! I’m having a company called The Taco Garage do it, got a referral from a buddy.
    AccuTune Offroad likes this.
  12. Oct 4, 2022 at 7:21 AM
    AccuTune Offroad
    AccuTune Offroad Well-Known Member Vendor
    El Cajon, CA
    So did you decide what you're going to do for suspension?
  13. Oct 4, 2022 at 7:31 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    There are guys on here all the time that buy a brand new truck, bring it home, and rip all the OEM suspension off to replace with Kings, FOXs, etc.
    If you are only trying to rectify sag, buy a set of those take offs. Job done. The claim that used suspension isn't safe doesn't hold any water to me. If its got 50k desert racing miles then its probably shot anyway. Buying something with a few k miles wont be any issue
  14. Oct 4, 2022 at 7:36 AM
    taco_rhyno
    taco_rhyno Well-Known Member
    06 DC 4x4 Sport
    Given your ‘very tight budget’ and extra weight in the back how about just having a shop put in a custom or heavy duty leaf pack in the rear with some new normal use shocks?
    Leave the front as is and meet your budget need.
    The Scientist[OP] likes this.
  15. Oct 4, 2022 at 7:56 AM
    AccuTune Offroad
    El Cajon, CA
    100% agree, however buying used aftermarket shocks, you are putting all your trust in the seller. Used shocks can be similar to a used engine. Looks good on the outside, but falling apart on the inside. Its a gamble.
    SR-71A[QUOTED] likes this.
  16. Oct 4, 2022 at 8:01 AM
    The Scientist
    yeah I’m going to run an icon 3 RXT leaf pack, 5160’s rear and 6112’s on the front
  17. Oct 4, 2022 at 8:02 AM
    The Scientist
    That’s pretty much the plan :)
    taco_rhyno[QUOTED] likes this.
