Buzz Driving me crazy ... HELP PLEASE
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GOTSAND?18, Nov 22, 2018.
  1. Nov 22, 2018 at 7:05 AM
    GOTSAND?18
    GOTSAND?18 [OP] Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    K so this is driving me crazy .I have a 2018 Tacoma 4x4 auto transmission .The issue I have been having for awhile is a have a slight buzzing in the steering wheel only at 12 o'clock at 2k rpm . I Have taken it in to the dealership twice already for the same thing . The first time tech felt it. He did the update that was suppose to fix the issue . We did a test drive and there was some improvement but buzzing was still there. I waited a bit thinking maybe I'm just sensitive to the buzz .1 month later still there I took it to the dealership again this time the tech said he didn't feel anything .This buzz is starting to drive me crazy .Anyone else had this issue with there 18 Tacoma or am I nuts and sensitive to the buzz . Thinking of going to another dealer to look at it to see what they say . If they say the same .I think ill open a case with Toyota . What's your thoughts guys ???
  2. Nov 22, 2018 at 8:09 AM
    EdgeCrusher
    EdgeCrusher Well-Known Member
    Chicagoland
    '16 OR DCSB Fully Loaded
    Thoughts? No one here can help you with this issue. Return to dealer and call corporate.
    tcjacado likes this.
  3. Nov 22, 2018 at 8:20 AM
    GOTSAND?18
    stock
  4. Nov 22, 2018 at 8:50 AM
    Norsemanvike
    Norsemanvike Well-Known Member
    Escondido, CA
    '18 Sport 4x4, DblCb, ShBd, BBP
    You say it's a "buzz," which is audible. Then you say "feel it", which is physical. So, are you actually hearing it with your ears or feeling it with your hands?
  5. Nov 22, 2018 at 8:51 AM
    GOTSAND?18
    stock
    I feel it in my hands . Its only on top of the steering wheel and at 2k rpm .
  6. Nov 22, 2018 at 8:54 AM
    Norsemanvike
    Escondido, CA
    What exactly was the update? Is there an associated TSB? What was the verbiage in the tech's notes when they tried to fix it the first time?
  7. Nov 22, 2018 at 8:56 AM
    GOTSAND?18
    stock
    it was a tsb for the transmission shifting .have no clue why they would think that was the issue . his notes stated that everything seemed normal after update .there way of double checking the truck was going out on the line and seeing if the other trucks are doing the same . I call his bull shit I think the tech had no clue .
  8. Nov 22, 2018 at 8:58 AM
    tdnick
    tdnick Go Vols!
    Alabamer
    2018 Cummins 4x4
    Can you feel it with ECT on?
  9. Nov 22, 2018 at 9:00 AM
    Clearwater Bill
    Billy
    Largo Florida
    Your hands feel it at the proper driving position of 10 and 2?
    Or only at 12 (top) as you state?
    Only at 2k?
  10. Nov 22, 2018 at 9:00 AM
    GOTSAND?18
    stock
    makes no difference ect on off same thing 2k rpm slight buzz in steering wheel . weird it only does it at 2k rpm.
  11. Nov 22, 2018 at 9:01 AM
    GOTSAND?18
    stock
  12. Nov 22, 2018 at 9:02 AM
    Norsemanvike
    Escondido, CA
    Agreed, TSB 62-18 doesn't address that issue. Since you say it's a physical vibration on the top of the steering wheel and the TSB he applied only fixes the computer's transmission code. One doesn't have anything to do with the other and you got a bad tech or techs. I'd take it back a 3rd time, go on a test drive with the tech or the service advisor with them driving. Let them know when you feel the vibration when you're touching the steering wheel from your side.
    If that doesn't do it, call corporate and open the issue with them.
  13. Nov 22, 2018 at 9:25 AM
    rob4092xx
    rob4092xx Well-Known Member
    Phoenix, AZ
    Too much weed!
    The hammer likes this.
  14. Nov 22, 2018 at 9:29 AM
    Uncle Elroy
    Uncle Elroy You feel me knockin'?
    Truck with 4 wheels, sometimes.
    Obviously a harmonic issue. They check the tightness of your steering wheel?
  15. Nov 22, 2018 at 9:54 AM
    GOTSAND?18
    stock
    far as I know nope .
  16. Nov 22, 2018 at 10:12 AM
    rlc177
    rlc177 Well-Known Member
    GOTSAND?18[OP] likes this.
  17. Nov 22, 2018 at 10:22 AM
    TEXAS BS
    TEXAS BS Formerly known as MMXVII
    JB
    Texas
    2017 ACLB TRD OR 4X4
    Does it go away in 4WD Hi? If it does then search on needle bearing problem.
  18. Nov 22, 2018 at 10:34 AM
    Uncle Elroy
    Potential for sure right here
  19. Nov 22, 2018 at 11:05 AM
    friendlywithbears
    friendlywithbears a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
  20. Nov 30, 2018 at 2:08 PM
    GOTSAND?18
    stock
    So update to my stupid buzz .Took the truck to another dealer sat there for 3 hours . They came back said the tech didn't feel a buzz. I was like what the hell .I looked like a crazy person lol . So next step is to open a case with Toyota . For the mean time I stuck a steering wheel cover that helps 10% with this annoyance . I'm hoping it will go away with more millage I put on it . I'm starting to think Toyota tells its tech to tell us that there is no issue since they have no clue what it is.
