Buzz/Growl when stopping and turning sharp
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bosshog1, Jan 3, 2017.
  1. Jan 3, 2017 at 2:31 PM
    bosshog1
    bosshog1 [OP] Well-Known Member
    micah
    West monroe, la
    '05 DCSB TRD Off-Road
    OME lift w/ 886's and Dakar AAL, Cooper Discoverer ST Maxx 285/75/16, Cruisin Off-road front bumper, custom Toyota grille
    I know that this type of thing has been covered in other threads, but I do not feel like any of them accurately describe my issue. When coming to a stop or turning sharp (or both, like pulling into a parking spot), I hear what I would describe as a growl or buzzing sound from the front end. I recently replaced the front driver side wheel bearing. I dont think the passenger side is bad yet because I dont hear this sound any other time. Any ideas?
    I have a 2005 TRD Offroad with OME 886 front coil springs and Dakar AAL in the rear.
    Thanks in advance.
  2. Jan 3, 2017 at 2:33 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Anti lock brake module?
    Broken spring?
  3. Jan 3, 2017 at 2:48 PM
    DEMikey
    DEMikey Mr. Badwrench
    mikey
    delaware
    2013 red taco
    100XR, OTW Surf Rod Rack, Toytec 3" lift, +1 on tires
    tire size? this describes exactly my front mudflap noise. only happens in and out of driveway.
  4. Jan 4, 2017 at 4:46 AM
    bosshog1
    micah
    West monroe, la
    Springs are fairly new, added within the last year. I'll have to look into the antilock brake module. Thanks.
    Tire size is 285/75/16, but I took my mud flaps off long ago.
  5. Jan 4, 2017 at 4:55 AM
    TacoMitch93
    TacoMitch93 Tasty Taco
    Mitch
    Nova Scotia, Canada eh
    09 Tacoma SR5
    You're 100 percent sure your tires aren't touching anything?
    I run 285 75 16's on factory rims with 1.25 inch spacer and OME 885 coils, I rub on the front portion of the fender and my cab mount.
  6. Jan 4, 2017 at 4:59 AM
    bosshog1
    micah
    West monroe, la
    No I am not positive. I have done some trimming to fit the tires, but it s possible that they still hit when I turn. I will definitely have to look into it. Thanks you, I hope this is it and not something mechanical.
  7. Jan 4, 2017 at 5:51 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Check your bearings again to be sure.
  8. Jan 4, 2017 at 9:41 AM
    DEMikey
    mikey
    delaware
    2013 red taco
    wheel bearings generally dont make noise like that unless the wheel is about to fall off at which point it would be so noticable on the highway it wouldnt be funny.
    even the little flaps on the front??
    TacoMitch93 likes this.
  9. Jan 5, 2017 at 7:02 AM
    bosshog1
    micah
    West monroe, la
    Yah even the front flaps are off. I guess I could be rubbing somewhere else, but I don't know why I would just now be noticing after all these years.
  10. Jan 5, 2017 at 3:57 PM
    DEMikey
    mikey
    delaware
    2013 red taco
    for what its worth, when my cooler rack is on my truck, with all my gear in it, ice, water drinks, rods, etc, i rub getting in and out of my driveway. somewhere in the wheel well. 265.75.16's on stock wheels with spacers.
  11. Jan 5, 2017 at 6:34 PM
    bosshog1
    micah
    West monroe, la
    I do have a steel front bumper that may be bringing my tires in contact with something when I'm turning and/or slowing down. But when I got the bumper I also swapped out my OME 885's for 886's to support the extra weight. Any ideas on how to check for a run that only happens when I'm moving? I haven't seen any evidence of it on my tires.
  12. Jan 6, 2017 at 3:25 AM
    TacoMitch93
    Mitch
    09 Tacoma SR5
    Do you have any worn paint anywhere? It's pretty obvious where my tires are rubbing, but my truck is white so that makes it a little easier. I mainly rub in hard corners and when backing up while turning.
  13. Jan 6, 2017 at 3:26 AM
    TacoMitch93
    Mitch
    09 Tacoma SR5
    I also had to cut a tiny bit off my fender flare to stop it from rubbing every time I turned the wheel.
