Buzz in front in
Discussion in '2nd Gen. Tacomas (2005-2015)' started by UTVolyaker, Dec 10, 2015.
  1. Dec 10, 2015 at 1:07 PM
    UTVolyaker
    UTVolyaker [OP] Well-Known Member
    Central Virginia
    Now that is has gotten a little cooler here in Virginia, I have noticed a buzz/rattle (sort of like a bumble bee in a coke can sound) when I accelerate. It basically happens between 1000 - 1500 rpm's and sounds like it is coming from right under the motor - I have a 2007 tacoma -- any suggestions or need for worry? Thanks!
  2. Dec 10, 2015 at 3:28 PM
    Conumdrum
    Conumdrum Well-Known Member
    Las Vegas
    2014 Tacoma
    2WD Sport Nav SC V-6 Mall crawler Home Depot truck
    Climb under there and have someone rev the engine? 1000-1500 is really low RPM's. Loose something or other?
    Vid/audio would be great.
  3. Dec 10, 2015 at 4:22 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    Does it only buzz when you lightly push on the throttle, then stop when you let off?
  4. Dec 10, 2015 at 6:52 PM
    UTVolyaker
    Central Virginia
    Yes -
  5. Dec 10, 2015 at 10:10 PM
    sparkystaco
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    Alrighty then, my first and best guess since my truck did and is doing it again is it's the air box on the pass. inner fender, it happens where the air horn goes into the fender.
    Easy to check, just remove the two bolts holding it to the inner fender & unscrew the clamp on the air tube, when you pull it off, you'll see the air horn that goes into the fender and a piece of cheap foam tape around it that collapses and lets the horn vibrate against the fender.
    While it's off take the truck for a ride to see if the noise is gone.
  6. Dec 11, 2015 at 10:51 AM
    4myTaco
    4myTaco SmaSh it Up
    Lucas
    Plainfield, IL
    06 DCLB Sport
    OME 3" lift up Front, LR UCA's, All-Pro Expo leafs in back, 17" XD Addicts with 285/70/17s, OEM Roof Rack, Westin Light Bar, Relentless Tailgate plate, Weathertech's, Blue Sea Fuse Box, Iggy's Switch Holder, Pioneer avh-3300bt Radio, LED Interior/License Plate Lights
    I had a similar issue, it was the heat shield above the exhaust. The shied had broken around the outside of the nut so it wasn't holding anything any more so it was rattling around.
