Buzzing noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Low Tide, Jul 29, 2022.
  1. Jul 29, 2022 at 10:55 PM
    Low Tide
    Low Tide [OP] Active Member
    2015 4WD SR5 DCLB
    265 / 75 R16s, Method 305 NV (16”), anti-tailgate theft, tonneau cover, tailgate lock.
    Can anyone tell me why my truck will sometimes make a buzzing noise at night. It sounds like it’s coming from the gas tank area under the truck.
    Is this normal?
  2. Jul 30, 2022 at 6:35 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Yes it's normal, it's the leak detection pump running for the EVAP leak check.
    b_r_o likes this.
  3. Jul 30, 2022 at 6:54 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Tacoma gnomes. If you had left them alone they would have cobbled a new suspension for you while you slept.
    But no. You went and noticed them.
    ... Or you could believe the correct answer above me. :alien:
    Dm93 and wi_taco like this.
  4. Jul 30, 2022 at 10:16 AM
    Low Tide
    2015 4WD SR5 DCLB
    Thanks for the explanation Dm93, I figured it was probably something normal but I didn’t want to assume and have my battery run down because I neglected something!
    Rock Lobster …
    they must know that I heard them working cause a new suspension has not been magically installed
    Rock Lobster and Dm93 like this.
  5. Jul 30, 2022 at 10:44 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Yea the test runs at around 3-8 hrs after the truck is turned off and lasts around 5-10 min, there's may factors to enable the test to run but that's the timeframe. Basically a little vacuum pump pulls a vacuum on the fuel tank to check for leaks, that's what your hearing.
    Rock Lobster likes this.
