Buzzing sound from the front with engine off
Discussion in 'Technical Chat' started by Chickenmunga, May 1, 2013.
  1. May 1, 2013 at 11:23 PM
    Chickenmunga
    Chickenmunga [OP] Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    This one has me puzzled.
    Tonight I had to bleed the brakes and check out my front parking lamps (they were dead)
    I went ahead and used on the brakes. I don't think I did a great job, because I was getting lots of air. I made sure that the reservoir never went down below halfway.
    Went for a short test drive and came back, parked in garage.
    I turned off the truck, then turned it back to the ON position
    I got out of the truck and noticed an electric hum from the front end. It's a pretty low sound, probably not much louder than the fan in my computer.
    If I press the brakes, a louder humming comes from the rear, and the front continues humming.
    If I let off the brakes, the front keeps humming.
    If I turn the truck off, the humming immediately goes away.
    During my test drive, I made sure the ABS worked
    I have an ABS kill switch (makes the truck think the diff lock is on), and toggling that doesn't effect it
    All lights are off.
    I don't have VSC
    What gives? It sounds like it's somewhere underneath the engine, but too hard to pinpoint.
  2. May 3, 2013 at 1:43 PM
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Brake booster, normally makes a slight noise, you may have air in it which is making it louder.
  3. May 3, 2013 at 2:05 PM
    Chickenmunga
    Keizer, Oregon
    I was expecting it to stop after a short bit, but I tested and it was still going after 2 minutes. I'm guessing I just had tons of air in the line. decided to have a shop bleed it because I was done with farting around with it.
  4. May 3, 2013 at 7:23 PM
    BamaToy1997
    Bill
    Navarre, FL
    Trying to figure this one out. The booster works on vacuum, so yeah, there will be air in the booster on one side as the pedal is being pressed. Are you trying to say that he has a vacuum leak on the supply side?
  5. May 3, 2013 at 10:28 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    ABS pump?
  6. May 4, 2013 at 1:26 AM
    Chickenmunga
    Keizer, Oregon
    shop found no leaks. they took the air out and found a bad wheel bearing (unrelated). I didn't ask about the humming yet because I wanted to eliminate some of the easy stuff first. I haven't had a chance to check the noise again to see if its still there.
