Buzzy Vibration at certain RPM's..read before buying!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Doobiewah, Oct 25, 2015.
  1. Aug 27, 2016 at 10:25 AM
    #2081
    whopper
    whopper 2016 MGM 4x4 double cab
    wayne
    north carolina
    2016 tacoma double cab 4x4 MGM
    On going
    No idea why it fixed it or if it's permanent but I got an awesome deal it's not droning but at WOT and as a bonus for now the vibration has gone away
  2. Aug 27, 2016 at 10:27 AM
    #2082
    whopper
    wayne
    north carolina
    On going
    Yes they should fix it
    And this exhaust only drone at WOT and I like the deep rumble
  3. Aug 27, 2016 at 10:28 AM
    #2083
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Deep rumble.... lol... so you dropped a V8 in your truck?
  4. Aug 27, 2016 at 10:29 AM
    #2084
    whopper
    wayne
    north carolina
    On going
    Smitty99 your funny you'll bitch about everything I like you
    Yes it's a v6 and this flow master has a rumble not a crackle
    smitty99 likes this.
  5. Aug 27, 2016 at 10:32 AM
    #2085
    smitty99
    Scottsdale
    Adds new exhaust and thinks his Tacoma sounds like
    https://youtu.be/YgSa6Rz4Orc
    :rofl:love u too !!!
    Riding Dirty likes this.
  6. Aug 27, 2016 at 10:33 AM
    #2086
    heyphillip
    heyphillip Well-Known Member
    DARRYL
    Did you notice any change in your gas milage
  7. Aug 27, 2016 at 10:33 AM
    #2087
    whopper
    wayne
    north carolina
    On going
    No my 1969 Camaro sounds like that
  8. Aug 27, 2016 at 10:33 AM
    #2088
    smitty99
    Scottsdale
    Now that's secksay
  9. Aug 27, 2016 at 10:34 AM
    #2089
    whopper
    wayne
    north carolina
    On going
    Maybe slight but not much
  10. Aug 27, 2016 at 10:37 AM
    #2090
    heyphillip
    DARRYL
  11. Aug 27, 2016 at 10:38 AM
    #2091
    heyphillip
    DARRYL
  12. Aug 27, 2016 at 12:31 PM
    #2092
    whopper
    wayne
    north carolina
    On going
    Yes but I didn't pay any where close to that! guy had it wife didn't like it.
  13. Aug 27, 2016 at 1:23 PM
    #2093
    49Tacoma
    49Tacoma Well-Known Member
    2016 Tacoma Limited 4x4
    Hey @whopper could you all give us a detailed writeup on what your symptoms were prior to installing the Flowmaster? For instance, vibration on a scale of 1-10 in the pedal and steering wheel. We'd definitely appreciate it! Alot of us are contemplating on purchasing.
  14. Aug 27, 2016 at 2:58 PM
    #2094
    TinSue
    TinSue Well-Known Member
    I have noticed the same thing on occasion, but mine seems to stop after only a couple of miles.
  15. Aug 27, 2016 at 5:35 PM
    #2095
    heyphillip
    DARRYL
    My Truck isn't constent it's intermitting its a annoying problem for sure.I've seen youtube videos on Generation 2's.having the same vibration problems as our generation 3's.So this is a ongoing problem that Toyota still hasn't figured out.
  16. Aug 28, 2016 at 7:19 AM
    #2096
    MGB
    MGB Well-Known Member
    2017 manual TRD Sport
    As a disclaimer, this is my first post, and I have not even driven a Tacoma yet; mine will not be delivered until late October (TRD Sport, manual transmission, Access cab, Quicksand), but I solved a similar vibration problem on another vehicle and the solution might be of interest. Over 10 years ago I put a Ford Racing 302 crate engine into a 1968 MGB GT. The installation went fine but there was a vibration between 1800 and 2400 RPM (worst between 2000 and 2300 RPM). The vibration was felt in the floor, steering and gas pedal, and was worse in the higher gears. Looking on Mustang forums I found that the 302 engines are known for having a harmonic vibration at those speeds but it is not generally felt unless stiffer than stock engine mounts are used. The engine, transmission, and exhaust in the MG were all rubber mounted, but there was no room for the Ford engine mounts so I used stiffer Jaguar XKE mounts. In thinking about the problem I felt that the exhaust system, being rigidly attached to the engine, might be amplifying the vibrations. To check this, I installed flex joints just behind the headers to mechanically isolate the exhaust pipes from the engine, and this eliminated the vibration. Therefore, I think a flex joint in the Tacoma exhaust system, maybe just behind the cat, might be worth trying, especially as the vibration has been reported to respond to changes in the cat back exhaust configuration.
  17. Aug 28, 2016 at 1:56 PM
    #2097
    OkTacoTRD
    OkTacoTRD Well-Known Member
    Jerry
    2016 Black Tacoma TRD Off Road
    So, do you guys feel confident that Toyota will eventually have a fix for this vibration issue? It's a constant source of irritation to me, and I'm on the fence about keeping the truck because of it. My dealer, who drove it, agreed it's an issue, and filed a case with Toyota for me. He said it might take anywhere between next week and a year for them to have a fix for it though. He did say he thought they would come out with a fix though. If I was positive they would remedy it, I'd just stick it out. But, I want to do a lot more to my truck, and I just can't make myself do it based on this irritating vibration! I waffle back and forth about every day as to cut my losses and move on, or wait on Toyota.
    49Tacoma likes this.
  18. Aug 28, 2016 at 1:59 PM
    #2098
    smitty99
    Scottsdale
    I doubt it because it was also an issue on the last generation
  19. Aug 28, 2016 at 7:17 PM
    #2099
    unclemat
    unclemat Well-Known Member
    2012 TX Baja
    I suggested installing flex sections eons ago in this thread, but so far nobody has bit.
    Good to hear such a fix worked for a similar problem on another vehicle.
  20. Aug 29, 2016 at 12:50 PM
    #2100
    Hudson Taco
    Hudson Taco Member
    2023 Tacoma ACLB
