Buzzy Vibration at certain RPM's..read before buying!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Doobiewah, Oct 25, 2015.
  1. Oct 16, 2016 at 2:20 PM
    #2201
    Taco361
    Taco361 Well-Known Member
    Victor
    Corpus Christi, Tx
    2022 TRD Sport 4x2
    Stock "for now"
    The rumble strip vibration can be corrected with a leaf spring kit from Toyota bro. The buzzing vibration in the steering wheel is a whole different issue.
  2. Oct 20, 2016 at 11:43 PM
    #2202
    JackSmith
    JackSmith Well-Known Member
    Tony
    SJC, CA
    '16 TRD OR DCSB 4x4 Manual
  3. Nov 1, 2016 at 11:06 AM
    #2203
    monsterkx2fiddy
    monsterkx2fiddy Well-Known Member
    Birthplace of Davy Crockett
    Got a few theories on vibration issues.
    Has anyone gone to an aftermarket transmission mount? Or maybe go pro it.
    Ive seen vibrations from some after market transmission mounts same size etc but the rubber made all the difference.
    Intermediate steering shaft is loose? Something else there is loose (go pro) and needs a muffler clamp to tighten up the slack?
  4. Nov 5, 2016 at 6:06 AM
    #2204
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Well I just had the dealer service Mgr tell me that its the injectors causing the steering vibes I could do noting but laugh at him and he asked me what was wrong with that finding. I said it sounds like you just pulled that out of your ass because you don't know what it is...!
    Koitz and gearcruncher like this.
  5. Nov 5, 2016 at 6:53 AM
    #2205
    IPNPULZ
    going to be fun!
    So I guess there is no TSB out yet?
    Koitz likes this.
  6. Nov 6, 2016 at 1:14 AM
    #2206
    Old Tundra Guy
    Old Tundra Guy Well-Known Member
    SW Ohio
    I would think Toyota knows exactly what the problem is.My guess is probably the fact that it uses non hydraulic engine mounts like those on the Lexus and would be too expensive to replace at this point. This could probably be confirmed if this engine uses them in the new Highlander which reviews say is butter smooth running.Man I wish this could be fixed as is ABSOLUTELY drives me crazy!
    jetfishn, IPNPULZ and OkTacoTRD like this.
  7. Nov 6, 2016 at 1:15 AM
    #2207
    Old Tundra Guy
    SW Ohio
    See I am up at 4 AM thinking about it, lol...
    PROseur likes this.
  8. Nov 6, 2016 at 3:23 AM
    #2208
    IPNPULZ
    going to be fun!
    @ minutes after leaving the dealer last night the vibes were still their, but they say they could not verify.
  9. Nov 6, 2016 at 3:31 AM
    #2209
    IPNPULZ
    going to be fun!
    I am thinking that Toyota is just saying fuck it....
    Taco361 likes this.
  10. Nov 6, 2016 at 5:22 AM
    #2210
    redneck47441
    redneck47441 Member
    Travis
    Black
    I'm not any kind of mechanic but in my experience in light duty common rail diesel's such as 6.7 cummins and tdi I different fuels would cause a mild vibration more so a mild buzzing vibration as the topic suggest. I can say 100% this was it just what I concluded over my several years of diesel. I haven't experienced the buzzing vibration in the Tacoma as I've only test driven one. I couldn't ever tell a difference in fuels with my HUEI injected powerstroke.
  11. Nov 6, 2016 at 5:34 PM
    #2211
    IPNPULZ
    going to be fun!
    Did this engine come over from Lexus?
  12. Nov 7, 2016 at 4:28 AM
    #2212
    Old Tundra Guy
    SW Ohio
    As far as I know ,yes.Basically same engine.
  13. Nov 7, 2016 at 4:39 AM
    #2213
    IPNPULZ
    going to be fun!
    Thanks, Now I am wondering since they don't have the same motor mounts as the Lexus could this be a factor? and If I am seeing it right this motor has the exhaust manifold built into the heads or am i wrong on that? The vibration is driving me nuts as well..
  14. Nov 7, 2016 at 10:06 AM
    #2214
    Old Tundra Guy
    SW Ohio
    Just picked mine up from 15,000 mile service. Service manager was pretty upfront about it,said they and Toyota were aware of the issue and they verified the problem in mine.Per the SM it is a sympathetic vibration from the exhaust,no fix from Toyota at this time.I plan on pushing the issue until there is a fix or till I sell the truck,whichever comes 1st.
    JPTx and RPain like this.
  15. Nov 7, 2016 at 11:50 AM
    #2215
    IPNPULZ
    going to be fun!
    I wonder if the mounts will cross between the two?
  16. Nov 7, 2016 at 11:58 AM
    #2216
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    Engine mounts are different, exhaust isolators are just your standard rubber ones found on many vehicles
  17. Nov 16, 2016 at 12:14 AM
    #2217
    monsterkx2fiddy
    So has this been determined to be due to the needle bearings?
    And I wonder, for people experiencing a resonating exhaust. I wonder if a hemholtz cavity somewhere on the headers/exhaust could reduce that noise.
  18. Nov 16, 2016 at 12:21 PM
    #2218
    COskimtb
    COskimtb Well-Known Member
    2016 Tacoma OR 4X4 DCSB 6MT MGM
    This vibration is not related to the needle bearings.
  19. Nov 16, 2016 at 12:44 PM
    #2219
    IPNPULZ
    going to be fun!
    It is either Transmission,shaft angles or motor mounts is my guess...
    I have had my truck in twice for this issue and the Master tech at my dealer has said its related to valve body or exhaust....
  20. Nov 26, 2016 at 2:01 PM
    #2220
    mlatner
    mlatner Well-Known Member
    Michael
    Omaha, NE
    2017 Tacoma OR DCSB
    Stock
    My 2017 just started doing this around 800 miles and now it's really noticeable at 1200 miles. I'm not going to read through 100 pages of thread, but it seems to me to be an issue with the brake pedal or something attached. I can tap the brake pedal while driving and can hear the buzz change a little.
    Koitz likes this.
