Buzzy Vibration at certain RPM's..read before buying!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Doobiewah, Oct 25, 2015.
  1. May 27, 2017 at 9:01 PM
    #2381
    Zrx1100
    Zrx1100 Member
    Georgia
    07 silver taco
    I know this may sound out of the blue but I had a buddy with the same problem very similar to yours less than 800 miles and vibration with the buzzing ended up changing the universal joints and completely fixed even tho it was a new truck
    Riding Dirty likes this.
  2. May 27, 2017 at 9:04 PM
    #2382
    Patrick1046
    Patrick1046 Well-Known Member
    05 AC Long Bed - 16 DC Short Bed - 16 4Runner
    Understood--honestly--I hope this get's engineered out---as I really like the Toyota product.....
    Diablo169[QUOTED] likes this.
  3. Jun 2, 2017 at 2:38 PM
    #2383
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    The driveline vibrations on mine have been more pronounced lately. I notice them especially when merging under light acceleration to get onto the highway at aroun 1900 to 2100 RPMs. Super fucking annoying.
    Once it drops below 1800 or so, I do not notice them at all. It's a rhythmic "waaaaaa waaaaa waaaa" almost reminiscent of the Needle bearing issue but obviously under different circumstances (plus I had the ECGS bushing installed)
    cwolgy88 likes this.
  4. Jun 2, 2017 at 4:06 PM
    #2384
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    FWIW (and yes, I know I am not supposed to be posting in the 3rd gen forum as I do not own one) I drove a 2016 with 9600 miles on it today and while digesting the experience did some back-of-a-napkin calculations--and found that when running in the Atkinson emulation mode the effective displacement of the 2GR-FKS engine is reduced to 1.17641 L--let's be generous and call it 1.2 L.
    I believe this accounts for the "buzziness" reported by many and experienced myself in now 3 test drives of 2016 (2) and 2017 (1) 3.5 L slushbox Tacomas, here are the numbers and calculations.
    engine dimensions:
    • bore: 94 mm
    • stroke: 83 mm
    • rod length "guesstimated" as 140 mm
    calculated values:
    • cylinder area (cm²) = 9.4^2 *pi /4 = 69.3978 cm²
    • displacement per cm of stroke = 69.3978 cm³
    • displacement per stroke = 69.3978 * 8.3 = 576.0016 cm³
    (validation of the above: displacement for 6 cylinders = 576.0016 * 6 = 3456.0095 cm³ = 3.456 L)
    Note the following does not consider reduced flow during periods of partial intake valve opening and closing, or the effect of vacuum and inertia of the air charge mass
    (that's the back-of-a-napkin part).
    In "Atkinson" mode the intake valve
    opens @ 33°ATDC -- after 0.8532 cm of downward piston travel [intake] -- (7.4468 cm of downward travel [intake] remains)
    closes @ 105° ABDC -- after 4.6377 cm of upward piston travel [reverse intake] -- (3.6621 cm of upward travel [compression] remains)
    The intake valve opens with 7.4468 cm of downstroke remaining:
    ∴ air volume ingested before BDC = 69.3978 * 7.4468 = 519.7703 cm³
    However after BDC, on the upstroke, the intake valve remains open for 4.6377 cm of piston travel:
    ∴ 69.3978 * 4.6377 = 323.7013 cm³ of the intake charge is expelled
    Leaving an effective displacement of 196.069 cm³ per cylinder; or just 1176.41 cm³, 1.176 L for all six cylinders--while operating in "Atkinson" mode.
    While 1.2 L is enough to keep a 4,000 truck moving at a constant 60 to 70 mph, but there's not a whole lot extra left...
    If anyone has any specific information regarding the conditions upon which the Atkinson emulation mode is activated I would like to know what has been found. TIA
    sxe4533, BlkTaco47, stun gun and 2 others like this.
  5. Jun 2, 2017 at 4:12 PM
    #2385
    smitty99
    Scottsdale
  6. Jun 7, 2017 at 12:22 PM
    #2386
    ARCOVT16
    ARCOVT16 Well-Known Member
    VT
    2016 DCLB SR5
    Icon ext Travel Coilovers, SPC UCA, SCS 16x8 Wheels, 285/75r16 G003, Toytec 3leaf AAL, Icon 2.0 Remote Reservior, Toytec Axle shims, Toytec Front Diff drop, Timbren U-Bolt flip kit, Clazzio Black Seat covers.
    I have the " waaaaa waaaaaa waaaaaa" very pronounced at 72mph have you determined the cause?
  7. Jun 7, 2017 at 1:15 PM
    #2387
    smitty99
    Scottsdale
    Yeah dealer said it's normal shitty design by Toyota
  8. Jun 7, 2017 at 1:38 PM
    #2388
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    Seems legit. 4 bangers mane. Keep it real.
  9. Jun 23, 2017 at 9:49 AM
    #2389
    ARCOVT16
    VT
    2016 DCLB SR5
    I just got back from the shop, I have a bad right rear wheel bearing, Toyota said they will be replace it under warranty next week.
  10. Jun 23, 2017 at 10:08 AM
    #2390
    tacoskidmarks
    tacoskidmarks Member
    2016 Double Cab TRD
    OME 887-Nitrochargers 3 leaf Progresive AAL over 1 in block, Nitrochargers
  11. Jun 23, 2017 at 10:17 AM
    #2391
    tacoskidmarks
    2016 Double Cab TRD
    Thats exactley what mine does, I also had the ecgs bushing done, and is does sound simmilar to that. And its with slight accelration in 5th speed, when it shifts into 6th it fades away, and will not do it in 4th speed. I thought it was the drive line, as I have a 2 in rear lift, but I took the driveline out and ran it in 4x4 and it made no difference.
    I am convinced its the Transmition.
    As any other wa, wa, wa noise it would still make the noise reguardless of the gear you are in. I even just had the tires reballanced and checked wheel bearings.
    Its the Tranny for sure, drives me nuts.
    smitty99 likes this.
  12. Jul 8, 2017 at 3:14 PM
    #2392
    Old Tundra Guy
    Old Tundra Guy Well-Known Member
    SW Ohio
  13. Jul 8, 2017 at 3:15 PM
    #2393
    Old Tundra Guy
    SW Ohio
    holding out hope for a solution,lol.
    sig916 likes this.
  14. Jul 8, 2017 at 3:29 PM
    #2394
    friendlywithbears
    friendlywithbears a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
    Tell me about your suspension set up. What are you running in the rear? Do you have shims or CB drop?
    In the meantime, embrace the wah wah
  15. Jul 8, 2017 at 9:25 PM
    #2395
    Koitz
    Koitz Well-Known Member
    2016 TRD sport 4x4 DCSB 2" lift 285/65/18 and loaded
    2" lift,18"rims, 32" tires,pro shifknob, black emblems etc
    Not gonna happen
  16. Jul 8, 2017 at 9:53 PM
    #2396
    smitty99
    Scottsdale
    Nope. No shims. It vibrated before just the same as after the lift. Tried a cb drop for kicks and it was a non factor. Removed it.
  17. Jul 23, 2017 at 9:38 AM
    #2397
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
  18. Jul 23, 2017 at 9:46 AM
    #2398
    harrycary
    harrycary Well-Known Member
    Harry
    2016 Tacoma TRD Off Road
    Thanks for your analysis. What is the cause of the buzzing?
  19. Aug 3, 2017 at 7:24 AM
    #2399
    cwolgy88
    cwolgy88 Well-Known Member
    Cody
    2017 Toyota Tacoma TRD Sport
    None as of yet
    I've been experiencing a shimmy in my steering wheel, side to side "play" or "vibration" at 70mph+ since I purchased the vehicle new 3 months ago. It's not constant though, it will be there at some points then not be there at others. I ended up getting aftermarket wheels which magnifies this issue. I had the aftermarket wheels re-balanced and the issue is still present. Have taken my truck to the Dealer twice, once on aftermarket wheels (they blamed the balance) and on stock wheels just yesterday, and they said they couldn't feel anything and I must be just feeling road "noise".
    I'm wondering if this buzzing is similar to what I'm feeling, I can feel the vibration in my hands and cab of the truck, but you can moreso so it in the steering wheel if you let go while on the highway.
  20. Aug 3, 2017 at 7:34 AM
    #2400
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Wider wheels with less backspace and more poke? Wider tires?
    Ever had it aligned?
    Will a bump on one side make it pull a certain direction?
    How's front inside tire wear look?
