Buzzy Vibration at certain RPM's..read before buying!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Doobiewah, Oct 25, 2015.
  1. Aug 1, 2022 at 3:15 PM
    #2601
    Smithmd88
    Smithmd88 Member
    2018 DBL CAB 4x4 TRD OR
    Anyone have success with that exhaust pipe damper?
  2. Aug 26, 2022 at 10:59 AM
    #2602
    PNW08
    PNW08 Active Member
    Washington
    08 Tacoma 4.0l
    I recently bought a 2nd gen 08 Tacoma 4x4 and immediately noticed this buzzing, high frequency vibration in the steering wheel and gas pedal. The truck has 100k miles and is my first Toyota pickup. This only really happens under load and is mostly felt in the 12 o'clock position on the wheel. I thought it was the front diff needle bearing at first. Replaced that with ecgs. Didn't fix it. One thing I have noticed though, the buzzing feeling is almost non existent when the steering wheel is turned. There is a road I drive every day where the speed limit changes from 35 to 50 on a left hand, incline corner. As I'm accelerating up through the corner (around 2k rpm) the vibration isn't felt until after the corner when the steering wheel is straightened out. I can feel it elsewhere is the truck, just not the steering wheel. I'd be interested to know if this is the case with other trucks. I can live with the buzzing in the pedal etc but the steering wheel bugs me the most.
  3. Aug 27, 2022 at 6:35 AM
    #2603
    GPatriot
    GPatriot Well-Known Member
    Cincinnati, Ohio
    2016 Black Tacoma Sport 4x4 V6 DCSB AT Loaded
    KDMaxPro 10.0, OME 2" Med Duty lift, RCI Sliders, RoofRack, Skid Plate, etc.
    Mine is the opposite. It's worse in the gas pedal/floorboard. The steering wheel I can tolerate.
  4. Dec 17, 2024 at 5:21 PM
    #2604
    Woodie
    Woodie Member
    Robert
    2009 green 4dr 4wd Tacoma
    2023 4wd sr with 3500 miles and has the buzz at 2000-2300 rpm regardless of the gear…baffled
