Buzzy Vibration at certain RPM's..read before buying!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Doobiewah, Oct 25, 2015.
  1. Mar 4, 2016 at 12:08 PM
    #741
    friendlywithbears
    friendlywithbears a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
    As an engineer who has to tear down problems and diagnose them, my hope and assumption is that if @DRBANE is able to do this, then Toyota engineering has probably tested this in many more extensive and controlled ways to understand the extent of the issue and where it is originating.
    It seems like a problem which is easily diagnosed, especially by the people who built it.
    TRDSport10 and DRBANE like this.
  2. Mar 4, 2016 at 12:28 PM
    #742
    busticator
    busticator Well-Known Member
    FL
    2016 Tacoma SR5 DCSB
    CPS rev2
    Well, we can't make the assumption that they have made any measurements or started working it in earnest. Other than some verbal acknowledgments of the vibrations during some test drives, there is a whole lot of silence on this. And, realistically, Toyota's team that may work issues like this could be spread pretty thin and not have a lot of time to dig in. That's why I've been looking at it myself a bit. Hopefully, if the source(s) are identified, they can quickly confirm & then fix.
  3. Mar 4, 2016 at 12:54 PM
    #743
    Danielnc06
    Danielnc06 Well-Known Member
    NC
    2016 TRD DCLB
    As a Product Engineer that supports currently manufactured consumer products, I can tell you that unless sales is demanding it be fixed, it saves money, or its a safety issue, it probably isn't top priority.. We have to make sales/customer service push this so that it becomes a priority.
    The engineers hands are probably tied with projects that are scheduled months in advance..
  4. Mar 4, 2016 at 12:59 PM
    #744
    unclemat
    unclemat Well-Known Member
    2012 TX Baja
    If so, it's lousy. I can't see how a reasonable company wouldn't have an engineering group watching and improving existing models, especially ones in the early run of production.
  5. Mar 4, 2016 at 1:00 PM
    #745
    Danielnc06
    NC
    2016 TRD DCLB
    If they care about their reputation they do but all we can do is hope they are working on it..
  6. Mar 4, 2016 at 1:14 PM
    #746
    DesertFish
    DesertFish Active Member
    SLC
    2016 TRD?
    As someone who is waiting for this issue to be resolved before I purchase, I just got off the phone with Toyota for the 2nd time (1800-331-4331). The first time I called back when the number was first posted at the beginning of February, they basically said they didn't know anything about the issue, and thanked me for calling. This time I got someone who took some time to check for TSBs, recalls, or any info they had, still found nothing, but actually offered to open a case file regarding the matter. So apparently even non-owners can get a case opened up. I encourage anyone holding off like myself to take a few minutes to call and get a case opened up, just to add to the pressure.
  7. Mar 4, 2016 at 1:23 PM
    #747
    busticator
    FL
    CPS rev2
    I do product design and also manufacturing support as well. Priorities are always what stops you from shipping things out the door. Otherwise, there are always going to be degrees of "broken" that need attention, and only so many resources you can afford to throw at it.
  8. Mar 4, 2016 at 2:36 PM
    #748
    friendlywithbears
    B
    The Wild
    2016 TRD OR MT
    Yeah that's very understandable. I realize was being overly optimistic and full of high standards. Can't a guy wish on a rainy Friday... :(
    Doobiewah[OP] likes this.
  9. Mar 4, 2016 at 2:51 PM
    #749
    Pportera
    Pportera Well-Known Member
    3rd gen.
    We should start bombarding the Toyota Usa face book page....might hurt sales enough to get heard.
  10. Mar 4, 2016 at 2:51 PM
    #750
    Mr. Torgue
    Mr. Torgue Explosions!!?!!?!?
    2016 7544HHBBP
    LED lighting
    Man that sounds rough after looking at that graph of movement. No pot holes or anything?
    As for my truck only vibration I feel is while braking and it always hits between 25-20 mph. Seems like it might be tire tread or something.
  11. Mar 4, 2016 at 3:15 PM
    #751
    FlyFisher1
    FlyFisher1 Well-Known Member
    NJ
    Thats a good idea. Not sure if it will hurt sales but more exposure is a good thing.
  12. Mar 4, 2016 at 3:44 PM
    #752
    Bob259
    Bob259 Well-Known Member
    Arizona
    2016 Tacoma Limited DCSB 4x4 3.5 V6
    Is anyone reporting this to the NTSB on their site? That will get us quicker resolution I would think as if it's so bad as to cause numbness it is a major safety issue.
  13. Mar 4, 2016 at 3:52 PM
    #753
    Ben91z28
    Ben91z28 Well-Known Member
    16tacotrdsport
    This thread is starting to take off the last few days.. More new buyers looking for answers... Sorry they have to join this club but it's good for everyone as a whole...
    Doobiewah[OP] and Pportera like this.
  14. Mar 4, 2016 at 4:05 PM
    #754
    DRBANE
    DRBANE Well-Known Member
    Denver
    2016 DCSB TRD Sport
    The first several runs I definitely hit small pot-holes, mild inclines, and other bumps that were glaringly obvious in the graph. I threw those out as junk and didn't even include those in the post. Found a nice flat stretch on a two-lane street that was smooth with little to no traffic. Did one with light acceleration in the 1000 RPM range for the base line. Then did the other two stretching into the 2000-2300 RPM ranges. Still looked bumpy on the graph but it was spot on when the vibration intensity peaked through the steering wheel. I could see it jump and knew I wasn't hitting potholes or other road turbulence. I know inclines seem to make the vibration worse, so I wanted to try a run on a hill and found one. That was harder to capture. It was a decent incline but on a major three-lane boulevard with more traffic and no easy U-Turn. Then the transmission was shifting more erratic than usual, so it wanted to constantly jump hard and fast past the 2,000 range no matter how much I tried to ease into it on the gas. Thus the last one was short, but I still hit the mark after a few tries. I really need to take off the heavy phone case and then find a way to mount the phone to the wheel. Weekend project.
  15. Mar 4, 2016 at 4:25 PM
    #755
    Patrick1046
    Patrick1046 Well-Known Member
    05 AC Long Bed - 16 DC Short Bed - 16 4Runner
    I encourage everyone affected [or want to buy a Tacoma] by this defect to notify local media to the potential public safety danger [numbness in extremities] from this vibration. Thanks to DRBANE there is now data that offers a clearer example. We only need one print / video story to alert the public to this serious threat to public safety. I made my notification tonight.
    FlyFisher1 likes this.
  16. Mar 4, 2016 at 4:34 PM
    #756
    nevadabugle
    nevadabugle Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    Glad to see this thread really catching some traction. Again my vibes are exactly like explained in this thread but at a level I can tolerate. I would assume there are many trucks like mine out there where guys have just not really paid attention and feel it as just a characteristic of the truck. Mine is annoying but nothing more. I think I have gotten used to it to some extent. I feel for you guys who have it bad enough to park the truck. There has to be an explanation to this if some trucks simply don't have it. The poster above who has a loaner while his is at the dealer drives this point home.
    Pportera likes this.
  17. Mar 4, 2016 at 5:43 PM
    #757
    Patrick1046
    This is not a "normal operating condition." Come on down and drive my loaner Sport [made in Texas] - smooth as glass-no vibration. Drive my broken Limited [made in Baja]- runs like an excavator.
  18. Mar 4, 2016 at 5:59 PM
    #758
    Patrick1046
    I encourage you to post the NTSB reporting information so we can prevent a fatal crash due to numbness.
  19. Mar 4, 2016 at 5:59 PM
    #759
    Pportera
    3rd gen.
    Mine is like both of these! Half time smooth other times hummmmy. Same with performance also. Half time its responsive, fast and sporty..other times its like sluggesh and non responsive. Crazy.
  20. Mar 4, 2016 at 6:21 PM
    #760
    nevadabugle
    Elko, NV
    Agreed. I was trying to say that your example proves that some trucks have this issue and some don't. This means there is something different. Which means it can be fixed.
