Buzzy Vibration at certain RPM's..read before buying!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Doobiewah, Oct 25, 2015.
  1. Mar 10, 2016 at 7:16 PM
    #881
    LEBM
    LEBM Thread Killer
    Eleanor, WV
    2021 TRD PRO 6MT Midnight Black
    Worst thing ever.
  2. Mar 10, 2016 at 7:37 PM
    #882
    Patrick1046
    Patrick1046 Well-Known Member
    05 AC Long Bed - 16 DC Short Bed - 16 4Runner
    Has anyone taken off / modified the exhaust / replaced engine mounts / brackets --to test vibe?
  3. Mar 10, 2016 at 9:30 PM
    #883
    nevadabugle
    nevadabugle Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    One of the early posters had motor mounts loosened there re torqued and it made the issue worse.
  4. Mar 10, 2016 at 9:34 PM
    #884
    unclemat
    unclemat Well-Known Member
    2012 TX Baja
    I think you may be onto something, however weird. That would be indicative of some knock with regular gas... but knock resulting in sustained vibrations? Very weird.
    Maybe knock causing some sort of switching between two injection systems causing some type of resonance?
    People are saying this issue shows after a while. Wonder if it is related to ECU learning some fuel trims that lead to the vibration. Trying to reset the ECU could confirm this.
    16taco3387 likes this.
  5. Mar 10, 2016 at 10:37 PM
    #885
    16taco3387
    16taco3387 Active Member
    Tbd
    Someone with open source data logging and some experience should be able to look at some data and figure it out, this is a interesting hypothesis indeed
  6. Mar 11, 2016 at 2:58 AM
    #886
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    If this is sustained long term knocking, then it will damage the engine. Most modern engine management systems have a knock sensor that picks up on even slight knock and retards the timing. You lose power [and a slight mileage drop] but that is much more acceptable then internal engine damage.
    I don't think the vibration is knocking, I have thought all along that it is some kind of resonance due to how the engine works in the atkinson cycle. Other then the transmission, not much has changed in the drive train or underpinnings to increase vibration. I still thnk a better engine choice would have been the updated 4.0 found in the FJC in it's later years.
  7. Mar 11, 2016 at 3:03 AM
    #887
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    Could be but...ez check, everyone with the vibe fills up w/ 93 for the
    next 2 fill-ups and reports back here.
  8. Mar 11, 2016 at 4:56 AM
    #888
    16taco3387
    Tbd
    If it's Atkinson cycle related then it would be possible to be tuned out (correct me if I'm wrong) and have the ecu map run only on Otto cycle all the time. I suppose your gas millage would be lower a few mpg tho but better then a buzz.
  9. Mar 11, 2016 at 5:23 AM
    #889
    el_zorro1
    el_zorro1 Well-Known Member
    Zorro
    Northern Virginia
    Hi guys, I have an OR access cab, Magnaflow 19291, and have always used 93 octane since getting the truck in December. Currently ~1200 miles on the odometer. Took it up between 70-80mph this morning steady for about 5-6 miles and had no vibration as described on over 45 pages here. I don't have a comparison from before I had the exhaust installed.
  10. Mar 11, 2016 at 6:54 AM
    #890
    Patrick1046
    Interesting -- my tech had the same suggestion as a possible fix.
  11. Mar 11, 2016 at 7:02 AM
    #891
    BlkTaco47
    BlkTaco47 Unhinged
    I need to find something FAST!! The numbing of the hands suck
  12. Mar 11, 2016 at 7:35 AM
    #892
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    Same truck, bone stock. No vibration. Not saying an exhaust wouldn't matter but without before/after data it your lack of vibes doesn't mean much.
  13. Mar 11, 2016 at 12:59 PM
    #893
    Ben91z28
    Ben91z28 Well-Known Member
    16tacotrdsport
    Called local Ford dealer... trying to get an idea of trade in value. The ship is starting to list...
    Way to go Toyota!
  14. Mar 11, 2016 at 1:04 PM
    #894
    16taco3387
    Tbd
    Did you ever have the vibration at all? I just spoke with a guy who has a 16 trd sport 4x2 and asked about the vibe, he said his is smoth, he has KO2's now but said it was smoth for the 800 miles that it was on the stock wheels and tires and is smoth for another 1000 or so on the Ko2's and aftermarket wheels.
  15. Mar 11, 2016 at 1:06 PM
    #895
    BlkTaco47
    BlkTaco47 Unhinged
    damn, that's painful to trade it so fast...
  16. Mar 11, 2016 at 1:16 PM
    #896
    Ben91z28
    16tacotrdsport
    I'll probably die of shock when I hear what the trade in value is. I'm sure I'll hold on to it for at least 3 or 4 more months hoping that they get this straightened out. My truck stickered for 38 something had pretty many options... I paid 35 plus tax so I'm betting they'll say 31/33. I'll post it when I hear.
  17. Mar 11, 2016 at 2:48 PM
    #897
    Patrick1046
    I think we can rule out the tires. I tried different wheels. The focus now on my truck is the rear engine mounts. Need to rule these out.
  18. Mar 11, 2016 at 2:51 PM
    #898
    Patrick1046
    Hang in there another week before you trade.
    COskimtb likes this.
  19. Mar 11, 2016 at 2:58 PM
    #899
    BlkTaco47
    BlkTaco47 Unhinged
    yup, I'm on KO2's now and same vibe remains
  20. Mar 11, 2016 at 3:55 PM
    #900
    Rupert
    Rupert Member
    Clearly, there are widespread vibration problems with these 2016 3rd gen trucks. Surely, Toyota is now, and has been for some time, well aware of the problem. Forums are shedding light, Toyota is currently in denial. Truck working as intended? Natural characteristics? pfffffffft! I have a $32,000 2016 truck on order to the dealership manufacture date of March 11th 2016 and delivery date of April 5th 2016. This will, for sure, be discussed with the dealership before any paperwork is signed!
    I commend you all on these forums for giving me and everyone else the heads up! Thank You.
    busticator likes this.
