Buzzy Vibration at certain RPM's..read before buying!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Doobiewah, Oct 25, 2015.
  1. Mar 13, 2016 at 1:46 PM
    #941
    Patrick1046
    Patrick1046 Well-Known Member
    05 AC Long Bed - 16 DC Short Bed - 16 4Runner
    FYI - There are modified engine isolators that will fit. Now that I know what the source of the vibe it is only a matter of time to correct it. If the Lexus does not fit I am confident I can locate one or fabricate one that will work.
    Bob259 and friendlywithbears like this.
  2. Mar 13, 2016 at 2:04 PM
    #942
    friendlywithbears
    friendlywithbears a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
    Patrick,
    I just got back from a 200 mile roadtrip, and am hurting and desperate. I just got caught up on your explorations and this is exceptional news. Thank you thank you for all you've been doing.
    B.
  3. Mar 13, 2016 at 2:22 PM
    #943
    Patrick1046
    Totally understand - I am as annoyed [for lack of a better word] as you all. I will say that even with these hydraulic engine mounts we may still feel some vibrations, which is normal resonance from any engine; yet I could not find any in the Canyon.
  4. Mar 13, 2016 at 3:22 PM
    #944
    TinSue
    TinSue Well-Known Member
    Where is there any definitive information that this is indeed the source of the "vibe"?
  5. Mar 13, 2016 at 5:07 PM
    #945
    Tacoski
    Tacoski Member
    Bloomington, Illinois
    2016 Tacoma TRD Sport
    none
    Patrick, I am definately interested in what you find out regarding the motor mounts, this so far makes the most sense to me. OEM mounts must be made of something inferior, and of course over time they start to deteriorate, hence the vibrations being transferred through the frame into the cabin.
  6. Mar 13, 2016 at 5:38 PM
    #946
    friendlywithbears
    B
    The Wild
    2016 TRD OR MT
    To clarify, the engine is likely the source of the vibration, the engine mounts are likely the medium through which it is being transferred into the cabin.
    Looking back, I believe even the engineer who tested @Doobiewah's truck insinuated this.
  7. Mar 13, 2016 at 6:03 PM
    #947
    Patrick1046
    At least one of us should try to get the dealer to remove and replace the rear engine mounts under warranty to test this.
  8. Mar 13, 2016 at 6:20 PM
    #948
    Yellowstone
    Yellowstone New Member
    Hi guys, I need your advice! I put a deposit on a 2106 crew cab off road this past Friday and I'm suppose to seal the deal Monday (tomorrow). This would be my first Toyota! What would you guys do if you were in my shoes? Go ahead and buy it, hold off, or run away from Toyota? I'm at an absolute loss after reading this thread! Thank you!
  9. Mar 13, 2016 at 6:31 PM
    #949
    Patrick1046
    Try and get the dealer to remove and replace the rear motor mounts under warranty. Not "normal" in any vehicle I have ever owned.
  10. Mar 13, 2016 at 7:03 PM
    #950
    TinSue
    I agree that the engine mounts are certainly a plausible source. However, the "engineers" who reviewed Doobiewah's truck made no mention of these as being a possible source of the problem (see post #320 in this thread). Rather they referred to either the manifold and its connection to the exhaust system and/or the exhaust system itself or to the direct injection/ignition dual cycle system itself and the firing sequence and programming of same as possible culprits or perhaps a combination of the two. But then, on another note, the fact that drbane's truck was made worse by loosening and then re-tightening the mounts is certainly suspicious. And then again, last week some members here were pretty sure the exhaust heat shields were the most likely source. The bottom line here, at least for me, is that I don't think that anyone, with the possible exception of some tight-lipped Toyota engineers, knows what the source is at the present time.
    I do appreciate all the time/effort that many members here are putting in toward solving this problem. At present, my Sport with approximately 700 miles has not developed the issue, but I hold my breath every time I drive it.
    16taco3387 likes this.
  11. Mar 13, 2016 at 7:07 PM
    #951
    bulldog
    bulldog Well-Known Member
    SW MO
    2023 Pro
    Umm…it’s a Pro Retired 4/29/2023 Dobinsons MRR Dobinsons UCA Dobinsons C59-314 Front Springs Dobinsons I59-110 Rear Springs 4.88 Yukon Gears CMC MobTown Sliders Line-Xed RCI Aluminum Skid BAMF Recessed Grille WARFAB Rear tube bumper SSO Full Plate Hybrid (sitting in the garage still) TTD Carbon Fiber Steering Wheel Clazzio Dark Gray Seat Covers 35% Tint Vinyl Tailgate Letters Undercover Elite Tonneau Apex Stealth Cali LED 31.5" w/upgrade OPT 7 harness and MicTuning Switch V5 Gemtech Homelink 265/75 16 Mickey Thompson Baja Boss A/T Volk Gloss Black 16” 17' Pro Rigid Fog Lights 17' Pro Tail Lights Complete sound proofing
    I was too, but I pulled the trigger yesterday :)
  12. Mar 13, 2016 at 7:08 PM
    #952
    friendlywithbears
    B
    The Wild
    2016 TRD OR MT
    Please re-read my post, I said the engine is the likely source, as the engineers have stated. Engines vibrate, which is why things like engine mounts are engineered to reduce or remove the vibration.
    Everything is worth trying, except perhaps bashing the constructive work people are doing to help alleviate the problem for others.
    Danielnc06, 16taco3387 and Rupert like this.
  13. Mar 13, 2016 at 7:13 PM
    #953
    TinSue
    Please re-read my post as well: "I do appreciate all the time/effort that many members here are putting in toward solving this problem."
    I certainly am not bashing the constructive work that anyone is doing in this regard.
  14. Mar 13, 2016 at 7:32 PM
    #954
    Patrick1046
    Sir-FYI I have been consulting with "engineers" and I am driving two new Tacomas.
    1- A Sport which failed at 1700 miles
    2 - Limited failed soon after.
  15. Mar 13, 2016 at 7:48 PM
    #955
    TinSue
    Hi Patrick! Yes, I have seen your previous posts in regard to your issues and that is one of the reasons that "I hold my breath" every time I drive mine, wondering if today will be the day that it shows up in mine. I am as anxious, and supportive, as everyone here for this issue to be solved in a timely manner.
  16. Mar 13, 2016 at 7:58 PM
    #956
    TinSue
    So, has anyone put a significant number of miles (say 5,000 or more) on their vehicles without this problem developing as yet?
  17. Mar 13, 2016 at 8:00 PM
    #957
    .280Rem
    .280Rem Well-Known Member
    Jim
    Birmingham, AL
    2016 TRD Off Road 4x4 Dbl. Cab
    I have not read all 955 posts. Was this issue different from the drive line vibration?
  18. Mar 13, 2016 at 8:43 PM
    #958
    bginvestor
    bginvestor Well-Known Member
    :facepalm:This is not the type of thread one wants to see the day after picking up his truck!
  19. Mar 13, 2016 at 8:53 PM
    #959
    Ronin229
    Ronin229 Well-Known Member
    Clearwater, FL
    2016 Limited 4x4 Silver Sky
    Ceramic tint with Air Blue80 on front windshield and sunroof Nfab bars
    I'm sure you will be fine. I still love my rig.
  20. Mar 13, 2016 at 8:53 PM
    #960
    Skinny Dugan
    Skinny Dugan Member
    Dave
    Taco
    I kinda feel your pain. I am dying to pull the trigger on a Sport. I've been without a truck for 4 years, and I'm going nuts. There is no way until some of the issues are dealt with by Toyota.
    Big thanks for everyone's due diligence
