Buzzy Vibration at certain RPM's..read before buying!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Doobiewah, Oct 25, 2015.
  1. Apr 17, 2016 at 12:23 PM
    #1241
    COskimtb
    COskimtb Well-Known Member
    2016 Tacoma OR 4X4 DCSB 6MT MGM
  2. Apr 17, 2016 at 1:07 PM
    #1242
    1ciscokid
    1ciscokid New Member
    tom
    feel your pain,a few years back we had a company truck with similar issues. tons of money thrown at it unsuccesfully. had a hunch, pulled both rear drive shafts (2 piece) took them to a known reputable drive line shop. one shaft was .075 out of round, you could see were balance weights fell off at some point. rebuilt shaft,trued it up ,no balance weights, problem solved ! many times the factory does not true them up well and tries to compensate by slapping weight on to compensate. A shaft trued properly needs no balancing. Just sayin !!!
  3. Apr 18, 2016 at 5:32 AM
    #1243
    Kenster_66
    Kenster_66 Well-Known Member
    Greensboro, NC
    2016 Silver SR5 4x4 Dbl Cab Auto
    Waiting for Customer Service to call me back on Tues, they opened a Case and gave e a case number (False Hope)
    Not sure if I can keep going back to the dealership with the "poke and Hope" methodology of a fix...
    Wheels Re-Balanced, Trans fluid checked, no codes, Dealer computer hows everything working perfectly, been told to "wait for software update"
    Should I keep going back for; Engine Mounts, Rear Carrier, U-joints, etc?
  4. Apr 18, 2016 at 5:42 AM
    #1244
    western88
    western88 Chris b.
    ny countryside
    2014 SR5 4x4 taco Barclona Red
    beather mod Bugsheild backup light mod egr vent
    Best to get it burn then you can get a get truck of your choice. .. j/k.....
    Ya, it sucks to drag on the problem while the company is slow on the fix
    Kenster_66 likes this.
  5. Apr 18, 2016 at 11:54 AM
    #1245
    laggz
    laggz Well-Known Member
    2016 Tacoma TRD Sport 4x4
    just a little FYI..I took off my air dam about a week ago and have noticed that the vibrations are a lot less noticeable. Has anyone else with the vibration taken off their air dam and noticed it's better now? Maybe it's just false hope on my part...:notsure:
  6. Apr 18, 2016 at 6:22 PM
    #1246
    49Tacoma
    49Tacoma Well-Known Member
    2016 Tacoma Limited 4x4
    I drove a 2016 SR5 4x4 and it had the same vibration on acceleration as my 2016 Limited 4x4. The tech wanted me to drive the SR5 to see that it had the same vibration. It also had the shudder on deceleration from 25-0 mph. Appears to be prevalent on all V6 models regardless of trim.
  7. Apr 18, 2016 at 6:42 PM
    #1247
    COskimtb
    I meant the '16 vibration and the prior gen carrier bearing vibration.
  8. Apr 19, 2016 at 4:31 AM
    #1248
    Kenster_66
    Greensboro, NC
    That is unacceptable to me. Just because there is a defect before doesn't mean that it is OK now
  9. Apr 19, 2016 at 6:28 AM
    #1249
    0311K1LL
    0311K1LL The Old Breed
    Curt
    Jupiter, FL
    2016 SR AC 2.7L 4X4
    OME 887 w/Bilstein 5100's, 1.5 AAL, SPC LR UCAs 285/75/r16 Toyo AT2s!
    I have a SR 4X4 2.7 4banger with the 6 speed auto. I just drove a 900 mile trip doing 70-75mph. NO vibrations, no numb hands, no discomfort. It ran like a champ, super smooth, and I don't even have cruise control option on the truck.
  10. Apr 19, 2016 at 7:09 AM
    #1250
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    It doesn't seem to be a problem with the 4 bangers.
  11. Apr 19, 2016 at 7:32 AM
    #1251
    Doobiewah
    Doobiewah [OP] Well-Known Member
    Robert
    Flagstaff, Arizona
    RIP: 2016 Blazing Blue Pearl Tacoma Limited 4x4
    I drove one and didn't feel it one iota....drove like a different truck: no buzziness at all in steeringwheel, footwell, gas pedal....very smooth. If my V6 was like that, I would be in heaven...
  12. Apr 19, 2016 at 6:18 PM
    #1252
    4XO7544
    4XO7544 Active Member
    2016 Inferno TRD Offroad DCSB 4x4
    The needle bearings on the drivers-side carrier of the front differential on the 4x4 is the problem. Got a lift... makes it even worse. Once Toyota is forced to extend the TSB to the 2016 (and they will), they will just replace them with more weak-ass needle bearings. I agree it sucks, but just get the bushing and move on. Mine is being installed tomorrow. I'll post my results. Others that have made the switch are happy with the results.
    Trail boss likes this.
  13. Apr 20, 2016 at 12:17 PM
    #1253
    Danielnc06
    Danielnc06 Well-Known Member
    NC
    2016 TRD DCLB
    I hope it fixes it for you but I believe that is a separate issue. This vibration will happen in each gear at the same rpm each time through all of the gears..meanwhile your needle bearing would just keep increasing in rpm.
    Also switching to 4x4 doesn't help it like it does with a bad dif. needle bearing.
    Hope it works though. Keep us updated.
  14. Apr 20, 2016 at 6:05 PM
    #1254
    4XO7544
    Your right, they may be separate issues. The 4x4 needle bearing grinding/groaning goes away when four wheel drive is engaged, such a 4H. That is a good way to see if the needle bearing issue is impacting your 4x4 truck.
  15. Apr 20, 2016 at 6:17 PM
    #1255
    bulldog
    bulldog Well-Known Member
    SW MO
    2023 Pro
    Umm…it’s a Pro Retired 4/29/2023 Dobinsons MRR Dobinsons UCA Dobinsons C59-314 Front Springs Dobinsons I59-110 Rear Springs 4.88 Yukon Gears CMC MobTown Sliders Line-Xed RCI Aluminum Skid BAMF Recessed Grille WARFAB Rear tube bumper SSO Full Plate Hybrid (sitting in the garage still) TTD Carbon Fiber Steering Wheel Clazzio Dark Gray Seat Covers 35% Tint Vinyl Tailgate Letters Undercover Elite Tonneau Apex Stealth Cali LED 31.5" w/upgrade OPT 7 harness and MicTuning Switch V5 Gemtech Homelink 265/75 16 Mickey Thompson Baja Boss A/T Volk Gloss Black 16” 17' Pro Rigid Fog Lights 17' Pro Tail Lights Complete sound proofing
    Ya, they are separate for me. Mine doesn't go away in 4x4.
  16. Apr 25, 2016 at 2:08 PM
    #1256
    unclemat
    unclemat Well-Known Member
    2012 TX Baja
    Aren't we seeing fewer new reports about this? As much as it disgusts me that Toyota has not admitted the issue and released a fix, I am still hoping they fixed the production line.
  17. Apr 25, 2016 at 2:28 PM
    #1257
    4XO7544
    I hope you are right. My concern is the fix is likely more needle bearings.
  18. Apr 25, 2016 at 2:39 PM
    #1258
    aero90
    After spending every day with the issue now, I am more convinced it is engine component or engine mount related. Only happens in certain RPM range, worse under heavier engine load (ie going uphill), and seems to be independent of what gear you are in (however I need to verify that i actually do feel it in 1st at that RPM range).
    So I am personally leaning towards an unbalanced/out of tolerance engine component or faulty engine mounts/overall alignment in the engine bay.
    But who knows.
    Danielnc06 likes this.
  19. Apr 25, 2016 at 2:52 PM
    #1259
    Doobiewah
    Robert
    Flagstaff, Arizona
    My dealer keeps telling me it's 'normal' and that no one else complains about it....
    I hope they fixed it on the assembly line; however, I just drove a recently built one and it was there, although not as bad as mine...
  20. Apr 25, 2016 at 2:55 PM
    #1260
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    2 different dealers thought the same regarding the engine mounts.
