Buzzy Vibration at certain RPM's..read before buying!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Doobiewah, Oct 25, 2015.
  1. Apr 25, 2016 at 4:08 PM
    #1261
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    Yes, it is also suspicious how it goes away once you release the throttle. I also feel the same type of buzzing in the steering wheel every now and then during idle when I first turn the truck on (but not as intense).
    What gets me though is that some people say they don't feel the vibration at all or that it seems to happen mostly to 4wd owners. Although the extra differential adds more mass and more opportunities for something grounding out.
    You say a couple dealers thought it was the engine mounts. Did they try to replace them and notice any difference whatsoever?
    And Doobie, thanks for keeping up with this, I feel you are the best chance for a fix to show up!
  2. Apr 26, 2016 at 2:32 AM
    #1262
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    lol, nope! guess you didn't hear :D it's normal!! That's actually what
    they both told me. They straight up lied about the service they performed as well
    so I would expect no less from them regarding the vibe.
  3. Apr 28, 2016 at 10:00 AM
    #1263
    wvugis78
    wvugis78 Well-Known Member
    VA
    2016 Sport 4x4 MT 5100's, / 2009 TRD Sport 5100's, Franken Pack Leafs
    Sport 4wd MT. Have the bees under my foot. 2200 miles started around 1800 miles.
  4. Apr 28, 2016 at 10:09 AM
    #1264
    wvugis78
    VA
    On the phone and recording two problems to Customer complaints. The gas pedal vibrations and the extremely thin paint on the super white bumper. Call in guys. She is saying they have very few complaints.
  5. Apr 28, 2016 at 10:21 AM
    #1265
    aero90
    No buzzing vibration in the steering wheel though? Around 2100-2400 rpm
  6. Apr 28, 2016 at 10:50 AM
    #1266
    wvugis78
    VA
    A little. Really just bees in my pedal. I wonder if it is the Harmonic vibration due to the Outer diff Bearing.
  7. Apr 28, 2016 at 12:11 PM
    #1267
    laggz
    laggz Well-Known Member
    2016 Tacoma TRD Sport 4x4
    has anyone who has this issue tried taking off the front air dam? I took mine off and it seems like the vibrations have gotten less noticeable...
  8. Apr 28, 2016 at 12:35 PM
    #1268
    aero90
    Off roads don't have them
  9. Apr 28, 2016 at 1:20 PM
    #1269
    COskimtb
    COskimtb Well-Known Member
    2016 Tacoma OR 4X4 DCSB 6MT MGM
    Anyone notice a difference when putting weight in the back?
  10. Apr 28, 2016 at 1:21 PM
    #1270
    Bob259
    Bob259 Well-Known Member
    Arizona
    2016 Tacoma Limited DCSB 4x4 3.5 V6
    Still think it's harmonics and there would be a simple and quick fix, with oil filled mounts, like they use on the passenger cars/SUV's with the 3.5.
  11. Apr 28, 2016 at 1:24 PM
    #1271
    COskimtb
    Who is willing to be the guinea pig?
  12. Apr 28, 2016 at 1:33 PM
    #1272
    aero90
    No, but a few pages back I asked if anyone measured their driveline angles. I crudely measured mine and they seemed off, so it is going to be something I ask the dealer to check. Especially since I have the low speed vibration as well. And with people saying it changes with load in the bed, all signs point to pinion angle. If I could find a hundred pounds or two I would try it.
    But if it was a motor mount design issue, I would expect every truck to have it in similar severity.
    My three theories are:
    1. Engine/trans assembly not neutralized on mounts properly.
    2. Something is grounding out against the chassis/frame
    3. Oddly coincident harmonics of driveline angles being off.
    I don't really feel it as intensely when reving in neutral which leads me to believe the engine components are fine, and it doesn't change if I turn the wheel back and forth which keeps me from believing it is a power steering issue.
  13. Apr 28, 2016 at 1:40 PM
    #1273
    laggz
    I will if you set up a goFundMe account :thumbsup:
    Kenster_66 likes this.
  14. Apr 28, 2016 at 3:26 PM
    #1274
    49Tacoma
    49Tacoma Well-Known Member
    2016 Tacoma Limited 4x4
    Gotta love Toyota Customer Care. My case manager notified me that the vehicle has "no defect" and the dealership seconded that (even though the tech documented that the vibration was felt and present). I kinda assumed this was going to be the outcome. The case manager was nice but when asked if she ever heard of this issue, she said she didn't. I've already had (3) customer reps admit that they've heard this complaint from customers. In conclusion, she said my case will remain open and that encourage others to call into complain so Toyota is aware.
    On another note, I am going to throw some weight in the bed (about 200 lbs) to see if it affects the driveline angle (and the corresponding vibration). Can't hurt to try. I know when others have put the truck in neutral and revved the engine, they feel zero vibration in the pedal or steering wheel (including myself).
    Does this rule out the driveline or by contrast, does it narrow it down to the driveline? I'm new to all of this so sorry for the seemingly simple question.
  15. Apr 28, 2016 at 3:37 PM
    #1275
    akax50
    akax50 New Member
    2016 Tacoma Sport AT V 6
    My truck has a buzz that seems lessened when running 93 octane fuel. Not gone but more tolerable.
    I also discovered over 6k miles that wearing different shoes made a difference in the gas pedal buzz. Seemed that the softer the sole the less buzziness felt in the foot. My observations indicated that the gas pedal does not buzz much, but the floor under the gas pedal does. I tried many things to dampen the buzz and found the best result by removing the floormat and replacing it with a piece of the "anti-fatigue" foam runner used commercially. This simple thing dramatically reduced the remaining gas pedal vibration feeling on my truck.
  16. Apr 28, 2016 at 3:57 PM
    #1276
    wvugis78
    VA
    Has to be a wearable part. I had no vibes until the past couple weeks. Dropping off my truck now monday. See what they say.
  17. Apr 28, 2016 at 4:09 PM
    #1277
    COskimtb
    Interesting... while my vibration isn't too bad just yet, I had thought about putting some dampener material on the pedal itself.
  18. Apr 28, 2016 at 4:25 PM
    #1278
    aero90
    I revved to 2100 in neutral and could barely feel it in the steering wheel, but it was there. I wouldn't notice it though if I wasn't searching hard for it.
    Typically engine related issues are RPM related. Driveline issues tend to be linked to vehicle speed or certain conditions like acceleration/deceleration. The fact that it shows up at 2100 rpm or so in any gear (however, a lot LESS in 1st, actually similar to revving in neutral) makes me hesitant to say driveline for sure.
    I would check motor and transmission mount torques, but somebody already said a tech adjusted theirs and it didn't make it better.
    Neutralizing the mounts, by slightly loosening the engine and transmission mounts and then putting it in drive then park (or slipping the clutch for manuals) would be the next thing I'd try if I could not find anything possibly grounding out on the frame or chassis.
    However, I would much rather Toyota figure out what's wrong than messing around with my truck still under warranty.
    Here is what I've found:
    1. Occurs at 2000/2100-2400 RPM
    2. Occurs at a much, much higher intensity when on a slight incline or going up hill
    3. Significantly decreases when releasing the throttle.
    4. The highest intensity transfers from the pedals/floor to the steering wheel at certain RPMs
    5. Hardly noticeable in neutral or 1st gear.
  19. Apr 28, 2016 at 5:06 PM
    #1279
    kona7
    kona7 New Member
    Dave
    CA
    10 Tacoma
    Have the same issue (mfg Jan 2016, 4WD, Off Road, Access Cab, 6 cyl automatic)- vibration in steering wheel and gas pedal especially noticeable at higher speeds. Just took to Toyota of Oxnard, have never heard of the issue, of course. The mechanic assigned to the issue could not finds anything (although it appeared he only looked for codes) and ended up testing a similar Tacoma . He discovered that both Tacomas had similar issues and determined it to be "normal operation". I should note the only difference is that my truck was outfitted with a Snugtop. I kind of find it hard to believe that Toyota is not stepping up to the plate to address this issue. Several of you have mentioned contacting Toyota Customer Care - which I think is a great idea - how did you go about making that contact without going through the dealer? If there is anything else I can do to escalate this issue please advise.
  20. Apr 28, 2016 at 5:10 PM
    #1280
    laggz
    Call Toyota at 800-331-4331 and open a case! Everyone should be doing this that has the issue.
