Buzzy Vibration at certain RPM's..read before buying!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Doobiewah, Oct 25, 2015.
  1. Dec 5, 2015 at 11:36 AM
    #121
    busticator
    busticator Well-Known Member
    FL
    2016 Tacoma SR5 DCSB
    CPS rev2
    I still need to call about mine. I just haven't done any long drives or interstate driving, other than to verify that the issue is worse at higher sustained rpms/speeds. I felt it in the seat too, if you sit the right way it'll put your rear end to sleep most likely. o_O
  2. Dec 5, 2015 at 8:56 PM
    #122
    Doobiewah
    Doobiewah [OP] Well-Known Member
    Robert
    Flagstaff, Arizona
    RIP: 2016 Blazing Blue Pearl Tacoma Limited 4x4
    Definitely call! The more voices in the collective, the better chance we have to get this resolved and just enjoy our trucks!
  3. Dec 5, 2015 at 9:57 PM
    #123
    mandavdle
    mandavdle Well-Known Member
    Dave
    PA and CT
    2016 TRD OFF ROAD V6 DCSB AT
    I have not noticed any abnormal vibrations at any rpm with my 2016 OR DC AT SB.
  4. Dec 7, 2015 at 11:53 AM
    #124
    ToyFXR88
    ToyFXR88 Well-Known Member
    WI
    2016 MGM DCSB TRD Sport 6MT
    any updates on this yet?
  5. Dec 7, 2015 at 2:09 PM
    #125
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    Read post 117
  6. Dec 7, 2015 at 6:20 PM
    #126
    busticator
    FL
    CPS rev2
    I tried the dealer approach. 2nd dealer I've been to, I let both of them know I'd like to go along for the ride to help the tech diagnose it. Both times they let me know when they were done that everything was normal. :facepalm: Both times I had somewhere else to be, so couldn't make a fuss and wait for them to take another ride with me.
    I'll do the phone call to Toyota tomorrow since the dealer technicians are not that helpful and I don't have hours to sit and wait for someone to tell me that everything is normal.
  7. Dec 8, 2015 at 2:28 PM
    #127
    DRBANE
    DRBANE Well-Known Member
    Denver
    2016 DCSB TRD Sport
    As swimmer points out, the most substantive progress is OP’s post 117. I don’t have much more on my case after the shop re-torqued the engine mounts several weeks ago and an Field Technical Specialist (not RFT, sorry) sent me on my way with “we’ll monitor and keep you in the loop.” Since then, the issue has worsened. I now have the vibs in the 1,000-2,000 RPM range just cruising around at low speeds, whereas I didn’t have them in that range before the procedure. And the vibs in the 2,000-2,300 RPM range have gotten stronger and taken on a different, rougher charectaristic. Feels like something is broken and getting worse the more I drive it. I reported the deterioration yesterday. Don’t know what will happen next but still hoping for the best.
  8. Dec 8, 2015 at 3:26 PM
    #128
    ToyFXR88
    WI
    RFT?
  9. Dec 8, 2015 at 3:27 PM
    #129
    DRBANE
    Denver
    2016 DCSB TRD Sport
    Sorry, RFT = Regional Field Technician.
  10. Dec 8, 2015 at 3:33 PM
    #130
    Aaronp18
    Aaronp18 Well-Known Member
    Vancouver, BC
    2016 White Tacoma TRD Sport 4x4 DCLB
    I thought he was really pissed off and it stood for Retard From Toyota!
    :D
    bajabenny and Doggman like this.
  11. Dec 8, 2015 at 3:36 PM
    #131
    ToyFXR88
    WI
    Us techs know them as FTS - field technical specialist. RFT = run flat technology lol
  12. Dec 8, 2015 at 3:38 PM
    #132
    DRBANE
    Denver
    2016 DCSB TRD Sport
    Good to know. :thumbsup: I guess RFT does sound bad now.:rolleyes: Edited my post.
  13. Dec 8, 2015 at 8:02 PM
    #133
    Doobiewah
    Robert
    Flagstaff, Arizona
    Interesting. When I went in, originally, the Master Tech at my dealership was told to loosen and re-torque all mounts to spec. He told me that he didn't do it because he felt that was not the problem, and wrote it up that way. After reading your problems, I'm glad he left that alone.....very glad.
  14. Dec 9, 2015 at 3:54 PM
    #134
    DRBANE
    Denver
    2016 DCSB TRD Sport
    Well a close relative just took delivery of his new 4x4 AT Limited today and I just took it on a spin with him. Nada. Perfect, smooth as butter. :confused: Not a hint of this issue.
  15. Dec 9, 2015 at 5:51 PM
    #135
    alexderaven
    alexderaven Well-Known Member
    Alex
    Albuquerque, NM
    2016 MGM Tacoma Limited 4x4 (sold)
    I'm taking delivery of my 4x4 limited next week and I'm hoping this is the case for me as well.
  16. Dec 9, 2015 at 7:16 PM
    #136
    Doobiewah
    Robert
    Flagstaff, Arizona
    I so wish......maybe they have figured it out and have the problem solved on the assembly line? Only time will tell.... One would think they could figure out why one was perfect (the relative's) and ours sucked with the vibration problem... I'm suspicious that Toyota pushed my test to mid-January as they may have a fix published by then?
    We can only dream that the fix is enroute...
  17. Dec 11, 2015 at 11:47 PM
    #137
    DRBANE
    Denver
    2016 DCSB TRD Sport
    Unfortunately two days in and my relative started noticing the issue in the Limited today. It started after a few long drives back and forth to work 20 miles each way. I took it for another spin tonight. It's sure enough there now right at 2,100 RPMs, although not as pronounced (yet) as in my Sport.
    I've got an hour commute to work and noticed on mine that the the issue doesn't show up for the first 5 minutes after I get going first thing in the morning. Then it creeps in slowly after 30 minutes of driving--very subtle and slowly intensifies. It's pretty much full on and pretty rough by the time I get close to work on the hour mark. I then take a few road trips during the day for site visits and it's there full force, no need for warm up. Stays in full force the rest of the day. This behavior seems like a mechanical clue...
  18. Dec 12, 2015 at 9:34 AM
    #138
    TinSue
    TinSue Well-Known Member
    So has it been determined that this problem is limited to 4x4's exclusively??
  19. Dec 12, 2015 at 9:49 AM
    #139
    CAM37
    CAM37 Well-Known Member
    2016 Black TRD Sport
    I love how they say it's "Normal" just because all of them do it. Like it wouldn't be possible for Toyota to have an engineering problem and they would actually need to fix it.
  20. Dec 12, 2015 at 9:52 AM
    #140
    BlazingInfernoTaco
    BlazingInfernoTaco Well-Known Member
    Fort Worth, TX
    2016 Inferno Tacoma TRD Sport SB/AT "PreRunner"
    The "new normal"! ;) And, if you say it often enough people start to believe!
    bajabenny likes this.
