Buzzy Vibration at certain RPM's..read before buying!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Doobiewah, Oct 25, 2015.
  1. May 17, 2016 at 11:16 AM
    #1521
    stan23
    stan23 Well-Known Member
    stan
    Santa Clara, CA
    2025 DCSB TRD Sport 4x4
    I know I have commented negatively here before regarding this issue.
    But.. I just experienced this, and YES, it will annoy me too. So those of you with this issue, I apologize for my past comments about picky owners. This definitely does not feel normal and is very obvious.
    I was at my local dealer today killing some time and test drove a DC long bed Sport 4x4. Right about 2K RPMs, you get an annoying buzzing and you can feel it on the floorboard and steering wheel. I drove my truck immediately afterwards and it was 100X smoother in the 2K RPM range.
    So there you have it - I was wrong to chastise some of the folks here.
    I hope Toyota acknowledges this and releases a fix. If I was buying a Tacoma and test drove the truck that I did w/o ever reading about the vibration issue, I would have immediately thought there was something wrong with the truck - it's that bad.
  2. May 17, 2016 at 12:25 PM
    #1522
    COskimtb
    COskimtb Well-Known Member
    2016 Tacoma OR 4X4 DCSB 6MT MGM
    And you currently own a '16 Tacoma that does not have this buzzing at all?
  3. May 17, 2016 at 12:29 PM
    #1523
    Danielnc06
    Danielnc06 Well-Known Member
    NC
    2016 TRD DCLB
    Thanks for the honesty,
    Now if only the customer service reps personal vehicles did this..then we would get somewhere..
  4. May 17, 2016 at 12:33 PM
    #1524
    stan23
    stan
    Santa Clara, CA
    No, my truck does not exhibit this issue. I drove them back to back. The new one on the lot had a very distinctive buzz starting at 1900 to about 2300 RPM. The motor sounded different and you can feel a high frequency buzzing sensation both on the accelerator pedal and steering wheel. From what I remembered, it didn't matter what gear it was in. I drove the truck both on local streets and the freeway.
  5. May 17, 2016 at 1:39 PM
    #1525
    hr206
    hr206 Well-Known Member
    Western Washington
    '16 DCSB TRD OR, '98 regular cab 4x4
    I think it's completely plausible that different trucks could exhibit different behaviors.
    The first '16 I drove was a SR5 DCSB. I put about 5 miles on it. It was great - nice and smooth - pretty much what you'd expect from a test drive. I largely based my final purchase decision on that drive. The day I put down my deposit, my wife wanted a test drive as well before committing to $37k. The only '16 they had in stock was a extended cab TRD sport. I drove that for less than 1000 feet before my wife took over. The TRD sport had gravely exhaust note and felt a little touchy off idle, kind of like my TRD OR. I had caulked it up to different cab configuration and that it hadn't warmed up. Was I wrong.
    Which makes me wonder, do all the V6 DCSB and extended cab trucks have the same exhaust hardware. I still haven't found an on-line Toyota dealer with an on-line parts search for the '16 to check configurations and part numbers.
  6. May 17, 2016 at 1:54 PM
    #1526
    Doobiewah
    Doobiewah [OP] Well-Known Member
    Robert
    Flagstaff, Arizona
    RIP: 2016 Blazing Blue Pearl Tacoma Limited 4x4
    I have a parts guy that I can ask. I will check and report.
    GPatriot and hr206[QUOTED] like this.
  7. May 17, 2016 at 2:06 PM
    #1527
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    I'm sure they do. Have any DCLB owners reported having the buzz?
  8. May 17, 2016 at 2:39 PM
    #1528
    Old Tundra Guy
    Old Tundra Guy Well-Known Member
    SW Ohio
    I do,also seems to be getting worse.I buy new and keep my stuff forever,still have my 2000 Tundra.Am seriously thinking about getting rid of mine.
  9. May 17, 2016 at 2:46 PM
    #1529
    stan23
    stan
    Santa Clara, CA
    The one I drove was dclb
  10. May 17, 2016 at 8:11 PM
    #1530
    wvugis78
    wvugis78 Well-Known Member
    VA
    2016 Sport 4x4 MT 5100's, / 2009 TRD Sport 5100's, Franken Pack Leafs
    Dblc v6 mt. Buzzer
  11. May 17, 2016 at 8:56 PM
    #1531
    nevadabugle
    nevadabugle Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    I feel that we are getting somewhere. Even if Toyota is no help. Let's keep this dialogue going and see if we can pinpoint the problem and find a fix.
    Look at the needle bearing issue. It is a known problem with a TSB that does not fix it, but a private company ECBS found a fix and that fix is readily available. If we all keep after trouble shooting this TW will find the fix and we can all love our trucks. This is the only issue with mine that truly bothers me, overall I love the truck.
    COskimtb likes this.
  12. May 18, 2016 at 4:32 AM
    #1532
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    I'm with you, other than the vibe, love the truck.
  13. May 18, 2016 at 4:57 AM
    #1533
    Negro_Taco
    Negro_Taco Member
    Zach
    2016 TRD SPORT black ACLB
    Have 250 miles on my 16 and no issue yet. I am going on a 180 mile road trip this weekend. Hopefully all is well. Will report back.
  14. May 18, 2016 at 6:52 AM
    #1534
    harryk
    harryk Well-Known Member
    Maryland, near Chesapeake Bay
    2016 Tacoma V6, MT, 4WD, Blue
    Has anyone considered the engine mounts might be the problem?
  15. May 18, 2016 at 7:11 AM
    #1535
    COskimtb
    Yup, but no one has swapped them out yet to see if it fixes the buzz.
  16. May 18, 2016 at 7:14 AM
    #1536
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    Rather than mess with weights or dampers which could be luck of the draw if they work (I've done a lot of thinking over it these past few days. Also, guess and check is the most tedious way to solve something) I've decided the easiest way to confirm or deny the rear portion of the exhaust is to purchase the magnaflow 19291 system. This is the same system the previous member said lowered his vibration significantly.
    Now, before I spend 600 or something on this, has ANYBODY else replaced their exhaust and noticed their buzzing stayed the same?
    Otherwise I guess I'll be the guinea pig.
  17. May 18, 2016 at 7:22 AM
    #1537
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Does that one come with a new y-pipe?
  18. May 18, 2016 at 7:27 AM
    #1538
    aero90
    No, it is just the rear portion after the y pipe. The rear furthest 2 bolts on the exhaust are what you disconnect to install it. It's just 2 new pipes and a muffler. The stock one has the two pipes welded to the muffler though if you are looking at it.
  19. May 18, 2016 at 7:48 AM
    #1539
    Doobiewah
    Robert
    Flagstaff, Arizona
    Here's the response from the Parts Manager that I know:
    "there are differences in the exhaust depending on whether it is a double cab or extended cab. It's weird though, because the right pipe off of the right side manifold and the Y pipe are the same regardless. The only difference is the left side pipe off of the left manifold, and the tail pipe. Those two parts of the exhaust are different depending on the cab."
  20. May 18, 2016 at 7:58 AM
    #1540
    swimmer
    Tucson
    2016 TRDORAC4WD
    So, are there access cab owners with this problem in a significant way? Mine has this buzz but its very slight and nearly a non-issue. I also don't spend much time in that rev range.
